Old 04-26-2005, 08:14 PM   #11011
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
Originally posted by rc-zombies
I filed a channel under the chassis to improve airflow to the motor.
Hey Zombie,
hey how much you filed the chassis that you used? izzit just a small slope? after you filed it did you using CA Glue to gum it? thanks
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 04-26-2005, 10:42 PM   #11012
rc-zombies's Avatar
Originally posted by Guo Chean
Hey Zombie,
it was alot faster with a dremel and small sanding drum... after that used a file to make it flat.
right now it's only .75" long sloping channel... might re-do it and make it a little longer to around 1".
instead of CA... I may mask out the rest of the chassis and spray on some Clear Laquer paint. it will give it more professional look..
CA won't dry flat.
if you try it... mask out the area you want to cut with some masking tape as guide.
Old 04-26-2005, 11:53 PM   #11013
Guo Chean's Avatar
CA won't dry flat.
oic. did you using the air scoop too? did you get some pro 4 2005 spec parts from rainbow 10? i get i set for my pro 4 i think mostly i will get it during this friday or saturday. but will it easy to break if you do a slope and spray clear laquer instead of CA glue??
Old 04-27-2005, 09:23 AM   #11014
rc-zombies's Avatar
no air scoop... not yet..
have a fan instead.
yup getting some '05 spec parts...should be arriving this week:
new 2.25 upperdeck
1piece front bevel gear/input shaft
new threaded shocks.
once installed by car should be 99% US spec pro4.
unfortunately they do not have the new longer diff t-nut or motor mount.
the slope area still very strong. laquer or CA. to me about the same...both will penetrate the CF for a stronger bond.
most weaved CF parts are sprayed with laquere to give it's shiney finish.
Old 04-27-2005, 02:31 PM   #11015
zombie what the difference between the old shocks and the new ones.
sportracer is offline   Reply With Quote
Old 04-27-2005, 02:35 PM   #11016
rc-zombies's Avatar
Haven't seen the new one..yet to arrive...but from what I've seen it's similar to the Yok shocks...the bottom of the shock has a screw on cap. making it easier to replace o-rings instead of using those wire retainer clips. also it's florine coated, has new flat type bladder, and machined pistons.
Old 04-27-2005, 03:55 PM   #11017
Has anyone here raced with the metal input shafts yet? if so, are u using the metal dif gear or stock plastic. I was wondering if the metal on metal gears cause any interfearence.
ATXPro4 is offline   Reply With Quote
Old 04-27-2005, 03:59 PM   #11018
rc-zombies's Avatar
when I get mine I'll let you know... and I'll be using the V1.1 plastic diff gear... for now I don't see any interfearence problems problem with matal on metal gears... more friction and heat buildup is the only problem I see...
Old 04-27-2005, 06:54 PM   #11019
Guo Chean's Avatar
i think it should be more smoother than the old shock. i will get my new pro 4 2005 spec parts from tomorrow.
Old 04-27-2005, 06:55 PM   #11020
Guo Chean's Avatar
can it be using the low friction o ring and the competition blader?
Old 04-27-2005, 07:01 PM   #11021
blue hornet.'s Avatar
looks very much like another popular shock, made by some company called tamiya or something
Durango DEX210
Speed Passion
Traxxas Monster Jam
blue hornet. is offline   Reply With Quote
Old 04-27-2005, 07:05 PM   #11022
Guo Chean's Avatar
hahahaa i think it not make by tamiya factory but the design almost samiliar with tamiya only
Old 04-27-2005, 08:54 PM   #11023
Guo Chean's Avatar
Hey zombie,
any idea of which type foam tire runing in carpet? i plan to used JAco brand which type of foam tire you recomemded? thanks
Old 04-27-2005, 09:04 PM   #11024
axel's Avatar
i heard pro4's aren't that good with foams.
axel is offline   Reply With Quote
Old 04-27-2005, 09:07 PM   #11025
BlackKat's Avatar
Either: Double Pink Rear and Double Pink/Orange (Cyan) Front
or: Purple Rear and Purple/Orange (Plaid) Front
Personally I like TRC's much more than the JACO's. JACO's are a bit grippier but chunk a LOT easier.
BlackKat is offline   Reply With Quote
