Like Tree6Likes
Old 04-25-2005, 08:47 AM   #10966
brushless's Avatar
Default Glitching
I am having a major problem with glitching. I have an Airtronics MX3-S transmitter and the Airtronics Synthesized receiver. I race on an outside asphalt track and I am the only one having this issue. Sometimes, while running the car, it will almost turn 90 degrees by itself and it totally screws my driving up. Other times, the throttle will blip to full throttle for about a second. I have tried changing channels and even tried a totally different receiver that is not synthesized. It only happens on certain areas of the track too. I've also tried moving my receiver and antenna to the top chassis plate, but it still glitches. I do have a personal transponder, but I moved that to my front bumper. What else can I try? I have the Novak SS5800 brushless motor system.
brushless is offline   Reply With Quote
Old 04-25-2005, 09:13 AM   #10967
Default Re: Glitching
Make sure your motor has capasitors on it, then check and make sure that your antenna wire isnt touching anything carbon in the car, and make sure it wont when going over bumps.
ATXPro4 is offline   Reply With Quote
Old 04-25-2005, 09:20 AM   #10968
Solara's Avatar
Trader Rating: 16 (100%+)
Can someone help....
Can someone point me to the page # (from this PRO 4 thread) pertaining to the HPI springs rate in LBS/Inch rate......I knew someone listed that more then 1 time, but with almost 400 pages to search.....it is almost impossible for me to do it with very limited computer knowledge....
I do not have HPI springs set, but do have AE and LOSI springs set, just want to get some reference and compare....thanks.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 04-25-2005, 09:21 AM   #10969
brushless's Avatar
My motor doesn't need capacitors on it. The antenna wire is not touching the carbon fiber top plate and is very close to the receiver.
Old 04-25-2005, 09:24 AM   #10970
Solara's Avatar
Add extra padding underneath your recevier....the way I would do, add 2 or 3 extra layers of doubleside tape....
Old 04-25-2005, 09:25 AM   #10971
brushless's Avatar
That's a good idea. I was trying to think of a material that would block interference between the carbon fiber and the receiver, but I guess the further it is away, the less interference you'll have.
Old 04-25-2005, 09:26 AM   #10972
rc-zombies's Avatar
gr/mm(lbs/inch)
273(16.3) #6542 BLUE
302(16.9) #6543 SILVER
320(18.0) #6548 PINK
340(19.0) #6544 GOLD
363(20.3) #6545 WHITE
388(21.7) #6546 YELLOW
400(22.4) #6542 RED
Old 04-25-2005, 09:27 AM   #10973
TFR
TFR's Avatar
Originally posted by rc-zombies
ebay... $12.99 + shipping
made by Eagle racing..or check out the Integy website.
Thanks Ramon, hopefully he got a purple one in stock...
Muchmore l AHRP l Xenon l Futaba
TFR is offline   Reply With Quote
Old 04-25-2005, 09:27 AM   #10974
rc-zombies's Avatar
copper tape from the art/craft store will work as well.
Old 04-25-2005, 09:28 AM   #10975
brushless's Avatar
Copper tape?? That sounds like it would create a better flow for interference.
Old 04-25-2005, 09:37 AM   #10976
rc-zombies's Avatar
it act like a shield for interference...
but if you have extra $$$...
there's this shielding tape you can get from Japan...
Old 04-25-2005, 09:53 AM   #10977
Exe
Exe's Avatar
Send a message via ICQ to Exe Send a message via Yahoo to Exe
Originally posted by TFR
Does anybody know what brand is the purple motor heatsink that is on Hara pro 4? Where can I get it, link?
don't put a heatsink on, unless you plan on making additional airflow like hara has on the car, cause heatsink alone without additional airflow or cooler does not help, even more, it keeps the motor more hot. the only thing is heat dissipates faster after you stop racing.
Exe is offline   Reply With Quote
Old 04-25-2005, 09:57 AM   #10978
brushless's Avatar
That doesn't sound right. How could adding more surface area not help cooling? More air would be able to flow over more surface area even if he didn't have a direct method of air flow.
Old 04-25-2005, 10:04 AM   #10979
TFR
TFR's Avatar
I don't think that's right, when the car is running, thats where the airflow passes the fins to cool the motor, I also have a fan behind the motor.
Old 04-25-2005, 10:04 AM   #10980
Exe
Exe's Avatar
i have tested with termometer, furthermore, i read the same stuff on some rc team's from uk website. putting on a good cooler really helps. put on a good sunon maglev cooler.
