Like Tree5Likes
Old 04-12-2005, 09:52 PM   #10876
rc-zombies's Avatar
Originally posted by axel
Hey my pro4 is using a fantom stock motor... I have a 48p 70t spur gear and a 28t pinion... My final gear ratio is about 6.02. Should i gear down?
Which Fantom Stock Motor? MVP based? P2k2? Monster Stock?
Old 04-12-2005, 09:58 PM   #10877
jihernandez's Avatar
Originally posted by Barger
Hernandez...Get someone who knows about motors to check your timing.My motors are 2nd to last line on the RIGHT hand side.The end bell screw on the positive side is in line with the2nd to last line on the can.Hope this helps.
confirmed that it is at 12 degrees
jihernandez is offline   Reply With Quote
Old 04-13-2005, 02:20 AM   #10878
Hernandez....My suggestion is.....Cut the com,new brushes(I use the enduro brushes as they last a hell of a lot longer than the sprints and for club racing they are fine) and gear down the two pinions I suggested before.
DO NOT use com drops,This could be another reason for lack of power as they tend to gum up the com giving a poor contact for the brushes
Try that and let me know how you go.
Barger is offline   Reply With Quote
Old 04-13-2005, 06:45 AM   #10879
axel's Avatar
Fantom monster
axel is offline   Reply With Quote
Old 04-13-2005, 07:53 AM   #10880
rc-zombies's Avatar
Fantom monster
around 7+/- final drive
Old 04-13-2005, 09:41 AM   #10881
OSherman's Avatar
Default Carbon Main Shaft..
Anyone know where i can get a crabon main shaft for the PRO4??..
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 04-13-2005, 09:51 AM   #10882
rc-zombies's Avatar
Default Re: Carbon Main Shaft..
From this guy...
http://www.rctech.net/forum/showthre...06#post1513406
cost is quite less then the HPI's and only available overseas and cost over $55+ shipping.
Old 04-13-2005, 02:37 PM   #10883
moot's Avatar
i'm running 7.48 with a monster stock.but i might try high 6's to see if i can get more out of it
moot is offline   Reply With Quote
Old 04-13-2005, 03:30 PM   #10884
Does anyone have more info on the new hotbodies car? I've been told that it's being sold as a conversion for the pro4.
Also have you guys done a back to back test with the 2mm and 2.5mm chassis out doors, i'm not too sure that the 2mm is that much faster than the 2.5mm chassis, in fact it may me quicker with the 2.5mm one?
TheGod is offline   Reply With Quote
Old 04-13-2005, 03:36 PM   #10885
Send a message via AIM to jumbo360
Well im sure the hotbodies tc isnt a conversion but to make sure go to the hotbodies tc thread.
jumbo360 is offline   Reply With Quote
Old 04-13-2005, 08:26 PM   #10886
Thanks, so let me just recap coz am getting a bit confused:
As stated earlier, I have 2 V2s:
9x2 hara edition and 10x2 black endbell.
So far, the black end-bell out performns my 9x2 hara!
10x2 settings:
hard springs
12 degrees timing
Enduro brushes
69spur/26pinion = 6.47 ratio or 30.60 roll-out
I get about 9.5-10 amps output during motor run-in at 2V.
so far, am happy with the settings but 1 or 2 guys still faster than me in the insides of the track but my speed in the straights is at par with them.
9x2 settings:
hard springs
12 degrees timing
Enduro brushes
69spur/22pinion = 7.64 ratio or 25.89 roll-out
I get only about 5-5.5 amps output during motor run-in at 2V.
Dunno why the output of the 9x2 is only 5amps. Could it be the timing in degrees?
Your recommendation for 9x2:
75spur/21pinion = 8.71 ratio or 22.74 roll-out
75spur/20pinion = 9.14 ratio or 21.65 roll-out
On comm drops, I though it was supposed to increase voltage and output? Also, shouldn't I use comm drops while running-in my motor after lathing?
Old 04-13-2005, 11:00 PM   #10887
sweet wasabi's Avatar
ran pro4 first time past weekend, I felt a bit of torque steer. anyway to fix that?
I run rubber tires.
sweet wasabi is offline   Reply With Quote
Old 04-13-2005, 11:27 PM   #10888
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
Try taking the timing out to 20degrees. You will notice how much faster the motor will be.
dontfeelcold is offline   Reply With Quote
Old 04-14-2005, 01:27 AM   #10889
Hernandez...I agree,I use 18degree timing on all my v2 motors.I find in mod you do not need com drops at all.If you want more power...turn the timing up!!I did an experiment with a 540 motor...using com drops it was faster at first but as the race progressed it got slower(The com became black and burned)I would recomend you do not use them when running a motor in .Try advancing the timing/cut com/new brushes/no drops and see the difference.
Old 04-14-2005, 02:14 AM   #10890
Thanks to all for the assistance.
Have my big race 2 days from now and will let you guys know how I fared (especially with your valuable inputs).
Thanks again =)
