Old 04-11-2005, 05:41 AM   #10846
Send a message via AIM to jumbo360
lol thats really funny. Umm seems like all you need is a BMI or PRP or some other chassis
jumbo360 is offline   Reply With Quote
Old 04-11-2005, 05:52 AM   #10847
Mach10_shooter's Avatar
Trader Rating: 35 (100%+)
If I could find some 2mm carbon fiber, I'd cut my own...
Mach10_shooter is offline   Reply With Quote
Old 04-11-2005, 06:08 AM   #10848
hi everybody
sorry to ask this question again (i bet it has been asked a billion times allready). does anybody make a reliable bevel gear set for the one-way / spool?
i know rc square makes an alluminum large gear, which should be bulletproof. also, it shouldn't flex, so would that prevent the small gear from breaking in an impact?
how about a pair of delrin gears? these should be much stronger than the originals. does anybody make such a set?
finally, is it worth at all upgrading the pro4? i'm afraid a pro5 will be released soon (or has it been already? (cyclone))
thanx
billtc3 is offline   Reply With Quote
Old 04-11-2005, 07:36 AM   #10849
dizzy1's Avatar
Trader Rating: 23 (100%+)
hernandez- you are way over geared. I run my V2 8x1 with a 74/19 on a midsize track, 50% technical. I run my V2 9x1 usually 74/20, sometimes 74/21. Your comm probably looks cherry red after one race.
All about that Hot Pockets again! Woot Woot! Tried the Russian rocket but tired of the 'part of the week'. All gold everything '15 only made a weekend, such a numb and overpriced car!
Team Hot Bodies- Hobbywing- Schuurspeed
dizzy1 is offline   Reply With Quote
Old 04-11-2005, 08:55 AM   #10850
Originally posted by billtc3
hi everybody
thanx
I would say just to get eethe square aluminum bevel gear. I havent had a problem with my plastic one on my one-way but im taking the one way out anyways.
Old 04-11-2005, 12:33 PM   #10851
Ok here is my problem. First off im running on asphalt. The car is having some issues with left had turns. Everything in fine when turning right. But the rear end gets really loose in almost every left turn. the problem is accentuated in slower corners.
Im running the stock setup on the car, spool up front and CS27 tires.
This is a new problem that has only come to light in the past 2 weekends i have raced.
ATXPro4 is offline   Reply With Quote
Old 04-11-2005, 12:37 PM   #10852
rc-zombies's Avatar
check for :
chassis tweak
droop settings Hara runs different hts for L/R sides.
Old 04-11-2005, 12:44 PM   #10853
already checked for tweek as well as my droop setting. front droop is at 7mm rear is at 6mm. but ill double check those #s
Old 04-11-2005, 03:16 PM   #10854
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
Originally posted by rc-zombies
cone washer? OIC... I use a countersink washer for flathead screws mounted upside down so that the o-ring sits inside the bevel and secured with the original button head screw.
is that i doing that i show in pic si correct? thanks
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 04-11-2005, 03:16 PM   #10855
Guo Chean's Avatar
Old 04-11-2005, 03:16 PM   #10856
Guo Chean's Avatar
check for :
chassis tweak
will it be possible that set diff for left and right droop setting? thanks
Old 04-11-2005, 03:22 PM   #10857
rc-zombies's Avatar
you're using washers like these right? but mounted upside down and the o-rings sits inside the countersunk area.. on my car.. the o-ring doesn't show as much...
Old 04-11-2005, 03:23 PM   #10858
rc-zombies's Avatar
I've seen Hara use 5 on the left and 6 on the right.
Old 04-11-2005, 03:33 PM   #10859
Guo Chean's Avatar
got any difference for this setting is that counter back the steering?
Old 04-11-2005, 03:35 PM   #10860
Guo Chean's Avatar
i using hpi original countersink washer so do i need to tighten it much? bacause that day i read from this forum they say do not tighten too much. so i just leave it free abit.
can you send me your pic how much you tighten it until little bit. thanks
SEO by vBSEO 3.5.0
