Like Tree6Likes
Old 04-10-2005, 10:10 AM   #10831
rc-zombies's Avatar
RcMOdel...their email server went down..and everything was lost... you may want to contact them again.
yes..the speedmind heatsink spacer is the best.. you can try Rainbowten... btw they have the new aluminum one piece bevel gear/input shaft instock...
Old 04-10-2005, 12:25 PM   #10832
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
hey ramon i think this should be more than last time pic izzit the cone washer with o-ring is put like that? thanks
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 04-10-2005, 12:25 PM   #10833
Guo Chean's Avatar
second pic
Old 04-10-2005, 02:41 PM   #10834
Skill's Avatar
Yep, I ordered from RC Model about a week and a half ago now and got my bits yesterday in the post which included the high traction arms and Speedmind motor heatsink plate. Now let's hope the high traction arms are a little more forgiving than the standard graphite ones
Skill is offline   Reply With Quote
Old 04-10-2005, 06:27 PM   #10835
Default My almost hopped up Pro
Whats missing?
ah_liang is offline   Reply With Quote
Old 04-10-2005, 06:28 PM   #10836
Send a message via AIM to jumbo360
A carbon fiber bumper brace
jumbo360 is offline   Reply With Quote
Old 04-10-2005, 06:30 PM   #10837
Default Look wats happening
My novak ss5800 caused this?
Old 04-10-2005, 06:32 PM   #10838
WOW..........thats crazy. I see you also didnt properly shave down the servo ear and it started to grind up the shaft.
Old 04-10-2005, 06:53 PM   #10839
Its not the servo ear, its the turnbuckle rod when steering does to xtreme positions that grind the shaft.
Old 04-10-2005, 08:05 PM   #10840
Guo Chean's Avatar
i think should be the steel ball leg that from the servo saver causing you having this problem did you trim your steering properly? imposible to had this problem. the set screw of the ball stud that your screw on the servo savor too low
Old 04-10-2005, 08:32 PM   #10841
no I still think its the servo ear i mean i might be wrong but i used to have that problem on my old pro 4 and it was because of the servo ear.
Old 04-10-2005, 08:36 PM   #10842
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
Default Re: Look wats happening
OUCH
dontfeelcold is offline   Reply With Quote
Old 04-10-2005, 10:01 PM   #10843
jihernandez's Avatar
Default pro4 gear ratios
I see a lot of pro4 racers use the 64 pitch gears.
Where I race, it gets a bit dusty at times and even just a very small rock destroys the teeth of the 64 pitch gears.
Decided to go 48 pitch and to date, no problems except for getting to the best gear ratio for me. It is in this light that I am asking everyone's comment on:
WHAT IS THE BEST GEAR RATIO FOR THE FOLLOWING CONDITIONS:
Medium Bite, Bumpy, Cement finish track
V2 10x2
V2 9x2
Track is a bit technical, leaning lots of curves and turns - not flowing
Thus far, what I use are:
V2 10x2 = 69/27 * 2.4375 = 6.23
V2 9x2 = 69/22 * 2.4375 = 7.64
Can anyone assist by stating what gear ratio they have used successfully???
jihernandez is offline   Reply With Quote
Old 04-10-2005, 11:45 PM   #10844
rc-zombies's Avatar
cone washer? OIC... I use a countersink washer for flathead screws mounted upside down so that the o-ring sits inside the bevel and secured with the original button head screw.
Old 04-11-2005, 05:25 AM   #10845
Mach10_shooter's Avatar
Trader Rating: 37 (100%+)
That's funny. I just got these done. Carbon fiber bumper braces. If anyone is interested in one send me a PM.
Chris
Mach10_shooter is offline   Reply With Quote
