Like Tree5Likes
Old 01-16-2004, 08:06 AM   #1066
rc-zombies's Avatar
Originally posted by RCCadet
So what is the lastest release date for the Pro4.
I heard end of Jan.
Old 01-16-2004, 08:08 AM   #1067
rc-zombies's Avatar
Originally posted by Mr_Orange
So Tamiya bladders is included in the kit
NO! HPI firm bladders are included in the kit. Rayspeed bladders may fit as well and available in soft, med, and hard compounds to suit your track conditions.
Old 01-16-2004, 08:12 AM   #1068
burito's Avatar
@Mr_Orange: bladders are like shock-oil nowadays, just needed for fine-tuning. And who runs the kits shock oil...
His car was actually really stock as far as I could see, only that purple clamp on heatsink and a delrin diff (don't know why this was needed tough) were options!
Reto Koenig
burito is offline   Reply With Quote
Old 01-16-2004, 08:57 AM   #1069
rc-zombies's Avatar
Originally posted by racer
Kingcrab & RC-zombies,
since both of you i know have the HB graphite bumper brace.
did any one have problems installing it?
i have tried installed the stock plastic pegs on to the graphite brace. and when trying to install the pegs on to the lower bumper frame, it does not align properly. my pegs are slightly bent.
anything we can do to fix this?
any help would be appreciated.
Thanks!
Here's a pic of mine installed..
Old 01-16-2004, 09:09 AM   #1070
No problem, for build the Hot Bodies bumper carbon plate, i use the 65mm front body post of hot bodies it's perfect.
Yann.
Neosaka is offline   Reply With Quote
Old 01-16-2004, 10:22 AM   #1071
rc-zombies's Avatar
Default CHASSIS FLEX
can you guys say..."Flexy flier II"
j/k
with the concern of the 2.5mm chassis thickness...I'll have to say the chassis is rock solid! Virtually no lateral flex at all.
I'll have pics of the chassis with all the electronics installed this weekend.
so far this is the option parts I've used:
HB60116 Shock Shaft L (2 pks)
HB60106 60mm alum. body mounts or
HB60107 65mm
HB61131 Nitro 3 graphite bumber support
HPI72422 Aluminum spring perch
#10732 Ofna purple aluminum servo arm.
T3844P Eagle racing purple motor heatsink
Trinity shock mounts (no longer in production)
Alex Racing Ti screws. (left overs from my 'Cuda)
Electronics:
Futaba S9550 Digital low profile servo. Since there is plenty of room may switch to the faster S9541
HB Hara Twister Esc. (KO VSF-2000)
Futaba 3PK HRS system
the car doesn't really need any option parts...the car is great out of the box.
Old 01-16-2004, 10:39 AM   #1072
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Re: CHASSIS FLEX
[/B]
purple twister must look nice in the Pro4. i know it looks nice in my barracuda R2. always have to match right?
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 01-16-2004, 10:40 AM   #1073
rc-zombies's Avatar
Default Re: Re: CHASSIS FLEX
Old 01-16-2004, 11:26 AM   #1074
racer's Avatar
Default motor heatsink
rc-zombies,
where did you get your motor heatsink?
racer is offline   Reply With Quote
Old 01-16-2004, 11:31 AM   #1075
rc-zombies's Avatar
Default Re: motor heatsink
rc-zombies,
contact this seller on ebay...he's got purple available...if not you can order them from Integy.
http://cgi.ebay.com/ws/eBayISAPI.dll...category=44023
HPI or HB will probably release their version one-day...
Old 01-16-2004, 01:16 PM   #1076
rc-zombies's Avatar
Default HUDY BALANCING TOOL
The bottom of the Pro4 chassis has 2 very small holes to fine tune the balance of the car. The Hudy balance tools works just fine... #10880
http://www.mytsn.com/products/prodin...ppid=HUD107880
Old 01-16-2004, 04:59 PM   #1077
racer's Avatar
rc-zombies,
have you tried placing Xrays balancing weights on the car? just wondering if they would fit.
Old 01-16-2004, 09:40 PM   #1078
rc-zombies's Avatar
rc-zombies,
I have the long center weights...but only can use 1 of the 2 mounting holes...I thing HPI will be releasing a weight set for car..not for sure though... but it would be great if they did.
Old 01-18-2004, 06:31 AM   #1079
tcdrvr's Avatar
Default Carpet Setup?
Does anyone have a starting point for a carpet setup on the car yet?
tcdrvr is offline   Reply With Quote
Old 01-18-2004, 07:07 AM   #1080
kentech's Avatar
Default Re: Carpet Setup?
For carpet racing with rubber tyres I would think this would be a good starting point setup:
http://www.lrp-electronic.de/d/uploa...Hara_DHI04.pdf
kentech.wordpress.com
kentech is offline   Reply With Quote
