Hpi Pro 4
Originally posted by kewdawg
The increase in steering is across the board (diff,spool,one-way). The spool allows you to use your breaks to go into a corner with a lot of speed, but your car will "push". The increase in steering should help reduce the "push". The one-way gives the most agressive steering, due to the wheels spinning independent of each other. The stock setting calls for the 2.5 pivot block. If, you've tried the stock setting and found it didn't have enough steering (or the steering wasn't aggressive enough), then try the 3.0 pivot block.
Originally posted by axel
would this apply to carpet as well?
Re: Selling my spare Pro 4
Originally posted by olhipster1
Hey guys, just a heads up.....posted on the For Sale forum...I'm selling my backup Pro4.
Thanks guys.
Thanks guys.
it's very close to 2005 spec.
needs good home... taking a short break from racing...
(just until I assemble something new.... )
chassis was protected with AE chassis protector.
in excellent condition, well maintained, very clean.
almost to 2005 spec car
standard pro4 kit.
Upperdeck mod w/o-rings and washers.
TC3 diff mod.
new V1.1 bevel gears and back plate.
Delrin rear diff
includes Spool and one-way.
Aluminum servo & transponder mounts
Aluminum servo saver and steering link
Aluminum front body post.
Aluminum one-piece rear spur gear mount input shaft
Aluminum front input shaft.
Aluminum antenna mount.
Pivot block spacers.
Various pivot blocks.
Spare parts.
original parts
manual.
Re: Re: Selling my spare Pro 4
Originally posted by rc-zombies
my cars will be up for sale as well...
standard pro4 kit.
TC3 diff mod.
Delrin rear diff
Spare parts.
original parts
manual.
standard pro4 kit.
TC3 diff mod.
Delrin rear diff
Spare parts.
original parts
manual.
jumbo360 & SOuthernFRIED
you both have mail
you both have mail
I would like pics and a price also......
giving the car a complete make-over..
new gears front and rear
new spur gear
shocks emptied and cleaned
bearings re-oiled
cvd's cleaned and lubed.
shoot me a pm with your email... soon as I'm done I'll send..
hopefully by this weekend.
thanks.
Thanks Ramon got the mail just let me know when you get the prices
servo horn
hey anybody got a servo horn for a PRO 4 & HITEC servo they don't need??
may i know that izit the cone washer modification is like that? thanks
second pic of cone washer
it should look clear
I want to race pro my pro4 in 19t and mod maybe in the near future. Is mod class only 11t and below, or anything below 19t?
this is what my whole pro 4
