Like Tree6Likes
Old 04-06-2005, 02:14 PM   #10756
kewdawg's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Battry strap
Originally posted by Guo Chean
i think you should be make a cone shape at the down side of the carbon fiber so it can put o-ring and also can used it as the stabalizer
So you're saying, insert the o-ring in the screw hole of the upper deck?
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 04-06-2005, 02:36 PM   #10757
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
Hey Ramon,
did you think that if you put 3 degree pivot block at back and compare you put 1 degree rear hub and 2 degree pivot block the wheel base will be difference.
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 04-06-2005, 02:37 PM   #10758
Guo Chean's Avatar
for 3 degree pivot block it will shorter wheel base and if you used 1 degree rear hub and 2 degree pivot block the wheel base will longer
Old 04-06-2005, 02:42 PM   #10759
rc-zombies's Avatar
approx. about the same... wheelbase is adjusted with the 2 spacers on the rear hub.
Old 04-06-2005, 03:03 PM   #10760
Guo Chean's Avatar
ok thanks ramon
Old 04-06-2005, 05:10 PM   #10761
will the 3 degree block in the front give more steering or less
sportracer is offline   Reply With Quote
Old 04-06-2005, 05:37 PM   #10762
kewdawg's Avatar
When running a diff up front, it increases your steering.
Quinn Moon
Old 04-06-2005, 06:40 PM   #10763
Kenneth Tan's Avatar
Why is that so?
Kenneth Tan is offline   Reply With Quote
Old 04-06-2005, 07:27 PM   #10764
Guo Chean's Avatar
how a bout running spool or one way? thanks
Old 04-06-2005, 07:55 PM   #10765
thanks kewdawg
Old 04-06-2005, 08:02 PM   #10766
kewdawg's Avatar
Originally posted by Kenneth Tan
Why is that so?
The car corners harder due to the wider suspension arm angle.
Quinn Moon
Old 04-06-2005, 08:15 PM   #10767
kewdawg's Avatar
The increase in steering is across the board (diff,spool,one-way). The spool allows you to use your breaks to go into a corner with a lot of speed, but your car will "push". The increase in steering should help reduce the "push". The one-way gives the most agressive steering, due to the wheels spinning independent of each other. The stock setting calls for the 2.5 pivot block. If, you've tried the stock setting and found it didn't have enough steering (or the steering wasn't aggressive enough), then try the 3.0 pivot block.
Quinn Moon
Old 04-06-2005, 08:15 PM   #10768
kewdawg's Avatar
thanks kewdawg
Glad I could help.
Quinn Moon
Old 04-06-2005, 08:18 PM   #10769
axel's Avatar
would this apply to carpet as well?
axel is offline   Reply With Quote
Old 04-06-2005, 08:23 PM   #10770
olhipster1's Avatar
Trader Rating: 97 (100%+)
Send a message via Yahoo to olhipster1
Default Selling my spare Pro 4
Hey guys, just a heads up.....posted on the For Sale forum...I'm selling my backup Pro4.
Thanks guys.
olhipster1 is offline   Reply With Quote
