Old 04-05-2005, 10:16 PM   #10741
loopedeloop's Avatar
umm heres mine, square rc one peice shaft set to be fitted.
loopedeloop is offline   Reply With Quote
Old 04-06-2005, 01:16 AM   #10742
jihernandez's Avatar
Originally posted by kewdawg
You don't have to do any mods, to get the car, "race-ready". The car's "race-ready" out of the box. The upper deck mod is done to reduce the risk of chassis tweak, but not necessary for the car to perform properly. Purely a precautionary measure.
Is there anyone out there who remembers what page number this upper deck mod is at? Pleeeease inform.
jihernandez is offline   Reply With Quote
Old 04-06-2005, 01:19 AM   #10743
kewdawg's Avatar
That was a long time ago. might be a hundred or so pages, back. Someone who definitely knows, may post a link.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 04-06-2005, 04:56 AM   #10744
Mach10_shooter's Avatar
Trader Rating: 36 (100%+)
Default Re: Re: Battry strap
Originally posted by Mach10_shooter
Autodesk Inventor 9
I'll let you know when they are done.
Chris
Here is the first part I decided to start with. Front sway bar mount. This one is one of three prototypes. I am going to manufacture and sell these if anyone is interested. I am including the mount, longer mounting screws, and longer rods for the links themself. No sway bar is included or rod ends. The mount is sway bar diameter specific so I will need to know what bar you want the mount cut for. If you want one for each size. I can do that too. $10.00 shipped. Paypal csimpson@tls.net Put in the subject line Sway bar mount. Also note the diameter of mount you want.
Mach10_shooter is offline   Reply With Quote
Old 04-06-2005, 04:57 AM   #10745
another pic
Old 04-06-2005, 04:58 AM   #10746
last one
Old 04-06-2005, 07:59 AM   #10747
rc-zombies's Avatar
Default Re: Re: Re: Battry strap
Mach10_shooter
nice swaybar mount...
doesn't that defeat the purpose of the o-ring upperdeck mod?
unless under the CF is a countsunk hole for the o-ring to fit in.
Old 04-06-2005, 08:16 AM   #10748
The bottom is countersunk for that very reason.
Old 04-06-2005, 08:22 AM   #10749
fire929's Avatar
Default Mach 10
Check PM
Trex 450
Trex 600
EFL Heli's
Futaba 8fg
Align 3gx
fire929 is offline   Reply With Quote
Old 04-06-2005, 01:55 PM   #10750
kewdawg's Avatar
Default Re: Re: Re: Re: Battry strap
Originally posted by rc-zombies
Mach10_shooter
Man, I'm behind the times, too. Where's the page for the "o-ring" upperdeck mod?
Quinn Moon
Old 04-06-2005, 01:59 PM   #10751
rc-zombies's Avatar
Default Re: Re: Re: Re: Re: Battry strap
I recently just found out about too...
it's basically a countersunk washer turned upside down placed over the o-ring and secured with the flat buttonhead screw.... the 2 screws on the steering post. do not tighten all the way down. just enough to secure.. approx equal pressure on both sides...
Old 04-06-2005, 02:09 PM   #10752
kewdawg's Avatar
Default Re: Re: Re: Re: Re: Re: Battry strap
it's basically a countersunk washer turned upside down placed over the o-ring and secured with the flat head screw.... the 2 screws on the steering post. do not tighten all the way down. just enough to secure.. approx equal pressure on both sides...
If, you turn the countersunk washer upside down, how can you still use a flat head screw? Also, are doing this in conjunction with the upper deck mod?
Quinn Moon
Old 04-06-2005, 02:11 PM   #10753
rc-zombies's Avatar
oops... not flat headscrew...I ment a buttonhead screw...
and yes... done along with the upper deck mod.
Old 04-06-2005, 02:12 PM   #10754
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
i think you should be make a cone shape at the down side of the carbon fiber so it can put o-ring and also can used it as the stabalizer
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 04-06-2005, 02:13 PM   #10755
kewdawg's Avatar
Okay. Now it makes sense. Does this mod also reduce the chances for tweak?
Quinn Moon
