Old 04-02-2005, 07:21 AM   #10711
pro4racer's Avatar
hi
my club is moving over to carpet and i was wondering which front drive id be better off using ive got a one way, ball diff and another one way flooded with super glue so that its a spool.
my track is roughly 20m long and 11.5m wide
if this helps
thanks
pro4racer is offline   Reply With Quote
Old 04-02-2005, 01:15 PM   #10712
rc-zombies's Avatar
Originally posted by EngTat
Is the 1degree going to provide more stability??? or wat are their efects???
1 degree or 0 degree...does not matter... toe-in is adjusted with the toe-in blocks.
Old 04-02-2005, 03:58 PM   #10713
Send a message via AIM to jumbo360
Originally posted by pro4racer
hi
if this helps
thanks
I would say a regular diff but thats just my opinion
jumbo360 is offline   Reply With Quote
Old 04-03-2005, 12:14 AM   #10714
Skill's Avatar
I use a normal ball diff on carpet, but part of the reason for that is that I still have problems with the one-way gears breaking. A lot of it depends on your driving style but I would say that it's easiest to drive with a ball diff, a one-way diff needs a certain different driving style.
Skill is offline   Reply With Quote
Old 04-03-2005, 12:17 AM   #10715
axel's Avatar
when you use the the diff do you find it easier to brake at high speeds?
axel is offline   Reply With Quote
Old 04-03-2005, 12:31 AM   #10716
Skill's Avatar
Braking with a one-way diff is very difficult unless you are on a very high grip surface, you can brake with a one-way on carpet but not too hard or the car will just spin out, braking with a ball diff is much easier and if you're a heavy braker then I wouldn't consider a one-way diff, but maybe a spool.
Old 04-03-2005, 05:58 AM   #10717
Trader Rating: 17 (100%+)
yes
Tamiya TB Evo 5
Spektrum DX3R 2.4Ghz, Sanwa ERG-VX, VFS-1
EngTat is offline   Reply With Quote
Old 04-03-2005, 11:09 AM   #10718
pro4racer's Avatar
thanks for ur replys guys i think i will keep the diff in to see how it goes but i may try a spool to see if thats any better.
but i think i will deffo stick with the diff as i like to brake hard at high speeds.
thanks
also im using lrp top traction additive but on the bottle it says apply to tyres 30 min before ur heat but between that 30 min 10 min before ur heats starts wip eof with a towel
do i actually have to do this or can i jus apply 30 min before then jus leave on
thanks
Old 04-03-2005, 12:40 PM   #10719
Merciless's Avatar
Send a message via ICQ to Merciless
thanks
thanks
No you really do need to wipe it off you#ll have no grip at all if you don't !!
Merciless is offline   Reply With Quote
Old 04-03-2005, 01:35 PM   #10720
Skill's Avatar
Plus if you don't wipe it off you'll probably put black "11's" on your clubs new carpet and probably not be so popular....
Old 04-03-2005, 08:36 PM   #10721
Originally posted by Vance
Moot : For a normal Tamiya type 540 2xvent Johnson motor.............
Also change you pivot blocks from the stock set to 0deg-front & 1deg-rear.
Would 0 deg front and 1 deg rear too small ?? even it's just for Johnson 540?
yellow15 is offline   Reply With Quote
Old 04-04-2005, 07:35 AM   #10722
vulso's Avatar
Hello,
What are the parts needed to build a front spool? I also really need some help with my batteries staying in the car and/or not shifting. I use fiber re-enforced tape from SpeedTechRC. It works OK. However the asphalt I run on takes it's toll. Does any one have a better way?
vulso is offline   Reply With Quote
Old 04-04-2005, 08:58 AM   #10723
rc-zombies's Avatar
Originally posted by vulso
Hello,
no need to build your own spool... an aluminum spool is being sold already.
use the stock battery strap..that should keep your batteries in place if you're having broblems.
Old 04-04-2005, 08:23 PM   #10724
vulso's Avatar
Thanks rc-zombies. I have the spool, so I won't need anything but the gear and bearings? I just want to make sure I get the right parts. As far as the battery pack goes it has been a thorn in my side since I got the car. It's kind of embarrasing racing and seeing you battery pack flinging around outside the car! I used the stock piece and it didn't last half a lap. Fiber tape is good until I have to change batteries! I just wanted to know if there were some alternatives.
DFS
Old 04-04-2005, 08:38 PM   #10725
DFS
I had the same problem so wat i did was i double wrapped the batteries in then when changing the batteries just cut the middle of the tape then have little pieces of tape waiting on the side and then put your batteries in using the same tape after that just put the little pieces of tape over the part you cut and it should stay in.
