Like Tree6Likes
Old 04-01-2005, 08:50 PM   #10696
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
currently using carpet setting
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 04-01-2005, 08:51 PM   #10697
Trader Rating: 17 (100%+)
are u running in carpet? hei any good asphalt or tarmac setting?
EngTat is offline   Reply With Quote
Old 04-01-2005, 08:55 PM   #10698
Guo Chean's Avatar
hey dun play me lar eng tat you are champian driver. hahahahr
Old 04-01-2005, 08:56 PM   #10699
Guo Chean's Avatar
got got got dun worried later i will clearly tell you how to set hahahar
Old 04-01-2005, 08:57 PM   #10700
Guo Chean's Avatar
hey does anyone know how many degree for the stock rear hub carrier? izzit 1 degree? thanks
Old 04-01-2005, 09:07 PM   #10701
Send a message via AIM to jumbo360
Doesnt the stock Pro 4 come with 0,2,4,and 6 or are u talking about some other car because im not really reading the thread i pay more attention to the 2005 edition
jumbo360 is offline   Reply With Quote
Old 04-01-2005, 09:17 PM   #10702
Guo Chean's Avatar
what i means what degree of rear hub come with the original graphite is it 1 degree or 0 degree because the alum rear hud is 1 degree so does it same with stock? thanks
Old 04-01-2005, 09:21 PM   #10703
Oh sorry, where did you order ur aluminum rear hub from (Company), because they should tell you if its from square then its 0 but then there is a choice for .5 and the HPI one it should be 0 or you can get the 1,1.5,and i think thats it
Old 04-01-2005, 09:24 PM   #10704
TFR
TFR's Avatar
Hey guys, I'm building a brand new Pro 4 as we speak. I'm at the shock section right now, I want to run the kit set up and using their 50wt oil. Is the rebound suppose to be slow? After a while without the springs and when I put the shaft in, it doesn't bounce back. Is this normal for this weight of oil?
Muchmore l AHRP l Xenon l Futaba
TFR is offline   Reply With Quote
Old 04-01-2005, 09:24 PM   #10705
Guo Chean's Avatar
what i means the stock original carbon graphite rear hub is what degree?
Old 04-01-2005, 09:44 PM   #10706
its 0
Old 04-01-2005, 09:47 PM   #10707
Guo Chean's Avatar
thanks jumbo, does it have any different for 0 degree or 1 degree?
Old 04-01-2005, 09:49 PM   #10708
I pretty sure it wont have much of an affect if you have a 1 degree in
Old 04-02-2005, 02:49 AM   #10709
Is the 1degree going to provide more stability??? or wat are their efects???
Tamiya TB Evo 5
Spektrum DX3R 2.4Ghz, Sanwa ERG-VX, VFS-1
Old 04-02-2005, 04:14 AM   #10710
Mach10_shooter's Avatar
Trader Rating: 37 (100%+)
Default Re: Re: Re: Re: Bumper brace
Originally posted by ah_liang
I like to work on my whole hopups. How u use to cut them?
CNC mill with carbide tooling.
Mach10_shooter is offline   Reply With Quote
