Old 04-01-2005, 10:42 AM   #10681
Mach10_shooter's Avatar
Trader Rating: 36 (100%+)
Default Re: Re: Bumper brace
Originally posted by jt6
When will these be available?
I am going to try to start cutting them tomorrow.
I'll post pictures of the real thing Asap.
Mach10_shooter is offline   Reply With Quote
Old 04-01-2005, 10:48 AM   #10682
Originally posted by EngTat
How Much would the Bumper brace cost???
I am not wanting to make a profit on these items. I originally only wanted to make a few items for myself. As long as I can pay for material & tooling I will sell them cheap.
Old 04-01-2005, 11:36 AM   #10683
Pezz's Avatar
Send a message via Yahoo to Pezz
Default Battry strap
Put me down for one of each. Being a machinist myself I always think about making this stuff. What software are you using? that looks like solid works.
Pezz is offline   Reply With Quote
Old 04-01-2005, 11:39 AM   #10684
jt6
jt6's Avatar
Send a message via ICQ to jt6 Send a message via AIM to jt6
Default Re: Re: Re: Bumper brace
put me down for one each too.
jt6 is offline   Reply With Quote
Old 04-01-2005, 11:45 AM   #10685
Default Re: Battry strap
Autodesk Inventor 9
I'll let you know when they are done.
Chris
Old 04-01-2005, 02:26 PM   #10686
moot's Avatar
Originally posted by Vance
Moot : For a normal Tamiya type 540 2xvent Johnson motor, I used from 47-51mm rollout ... depending on track. Using 60T(48P) spur & from 36T-40T(48P) on Jaco Nitro Shoes foams. Further 60wt-front&50wt-rear oil with AE red-front&AE gold-rear springs. Remember that especially with stock your drive-train has to be 200% effiecient as every little part has an influence. If you are looking at hop-ups, definitely consider the Square TI input shafts; carbon drive shaft; ceramic bearings (I like ACER). Use a piece of car shammy with the vent holes cut open and keep it wet before going on the track(I use a mediacal syringe with water). This is cheap, ligther than a heatsink and even try Nitro Freeze spray to keep it really cool. Also change you pivot blocks from the stock set to 0deg-front & 1deg-rear.
Hope it helps!
Vance
Originally posted by Barger
Moot ....Na Stock gearing is to low...On a fast flowing track guys at our track run up to 50mm rollout.
thanks for the info guys!
moot is offline   Reply With Quote
Old 04-01-2005, 04:44 PM   #10687
put me down for a set of inner camber links
sportracer is offline   Reply With Quote
Old 04-01-2005, 05:11 PM   #10688
rc-zombies's Avatar
This one of the battery brace I used;
Old 04-01-2005, 05:13 PM   #10689
rc-zombies's Avatar
the other a modified Xray battery strap...
Old 04-01-2005, 05:51 PM   #10690
I like to work on my whole hopups. How u use to cut them?
ah_liang is offline   Reply With Quote
Old 04-01-2005, 07:12 PM   #10691
axel's Avatar
What's a good tire combo to use for racing indoors, another pro4 driver at my track said 22's in the rear and 27's in the front. But that was when i had the standard chassis. I now have a bmi 3mm chassis.
axel is offline   Reply With Quote
Old 04-01-2005, 07:42 PM   #10692
Send a message via Yahoo to nomaak
that goes double for me. trying to hunt down some med bite asphalt set-ups with take-off tires. i've often read that base set-up is very good for mod. i'd like to try it out. i've also bought a 0 degree pivot block for the front and a 2 degree pivot block for the rear. too bad we've got rain coming in our area......sure need some out-door rubber testing!
nomaak is offline   Reply With Quote
Old 04-01-2005, 08:16 PM   #10693
axel's Avatar
O.k. i was realy bored one day and i tried coming up with a new way to warm up my tires. When i just got my duratrax ice i decided to test the motor break in, so i grabbed a stock tamiya motor. So what i did was use the part of the armature that you put the pinion on and started sliding it over the tires slowly. I would do it til the tire stated smoking a little bit. Then i'd wait for it to cool down a little bit. After i was done i tested the warmed (now soft tires). It turns out it works. I was really bored just remember.
Old 04-01-2005, 08:38 PM   #10694
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
hey does anyone know how many degree are the rear hub carrier? izzit 1 degree? thanks
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 04-01-2005, 08:47 PM   #10695
Trader Rating: 17 (100%+)
hei guo chen wat setup are u using?
EngTat is offline   Reply With Quote
SEO by vBSEO 3.5.0
