Like Tree5Likes
Old 03-22-2005, 09:27 PM   #10546
jihernandez's Avatar
Originally posted by Barger
Beware!!!!! I used a HPI carbon shaft with an Orion V2 9x1 on tarmac with foams.....in 3 runs it twisted the shaft 1/4 turn.I know of 2 other guys have had the same problem.I put a post on this thread for Thad but he must of missed it.I also emailed HPI USA but never got a reply.They might be okay for stock or19 turn but DO NOT use them for mod.
My experience is totally different. I bought a carbon fiber shaft right after I got my kit. Have been using it for Stock 23T and Mod Races (Orion V2 10x2 and 9x2 and 8x1) and have no problems thus far.
We race rubber on cement surface and rubber on asphalt surface.
jihernandez is offline   Reply With Quote
Old 03-23-2005, 06:32 AM   #10547
ExcelRC's Avatar
Send a message via Yahoo to ExcelRC
Also have a questions about pistons and their hole sizes. I see on some setups that some are using 3 hole pistons with 1.3mm hole size. Have these been drilled or are they the #5 3 hole pistons that come with the kit? Thanks
ExcelRC is offline   Reply With Quote
Old 03-23-2005, 06:35 AM   #10548
Nipple's Avatar
Yes, they have being drilled.
I have tried 2 x 1.3, and 3 x 1.0.
Personally, I like 3 x 1.0. The original HPI ones are 3 x 0.8. So you still need to drill the holes.
Nipple is offline   Reply With Quote
Old 03-23-2005, 07:38 AM   #10549
Thad Garner's Avatar
Default Re: O-rings on 'other' portion of setup sheet
Originally posted by ExcelRC
I am following some setup sheet and under the shock setup it has a section for other. Most sheets have two o-rings, or some kind of spacers....where are these pieces going?? Inside the shock as a down travel limiter?? Or outside the shock as a down stop?? Any help would be appreciated.
On the outside, limiting up travel.
R1Wurks - Awesomatix USA
Thad Garner is offline   Reply With Quote
Old 03-23-2005, 08:13 AM   #10550
The Evicerator
Thad, we missed you Saturday. Did you not recieve my message?
There were taters left unattended that could have used your minding!
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 03-23-2005, 08:20 AM   #10551
rc-zombies's Avatar
Originally posted by jihernandez
PRP CHASSIS IS SO, SO, FANTASTIC!!!
Was prompted to order at once but unfortunately the site uses PayPal. PayPal does not support yet the Philippines where I a from. If only they accepted Mastercard without paypal - I would've ordered already.
If I knew you were looking for a chassis... I would have offered to sell you my BMI... and send it with my Mother in law that recently flew back last sunday...
btw...Paypal does take Mastercard.
Old 03-23-2005, 09:05 AM   #10552
dizzy1's Avatar
Trader Rating: 24 (100%+)
Thad,
I thought when they wrote in 1 o-ring they were replacing the rebound foam above the bladder? Ex. Your setup sheet from last years reedy you have 1 oring, so you put this on the outside of the shock shaft next to the spring retainer? Just would like to clear this up. Thanks
No more hot pockets, Russian rocket time again.
Hobbywing- Schuurspeed
dizzy1 is offline   Reply With Quote
Old 03-23-2005, 09:09 AM   #10553
Barry White's Avatar
Is there anyone that has bought the Hirosaka version? Or isn't it come out yet.
Barry White is offline   Reply With Quote
Old 03-23-2005, 11:36 AM   #10554
stonedgti's Avatar
Trader Rating: 15 (100%+)
ti screw set, if anyone is interested.
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
Team Powers | ORCA | OD 12 Racing | NorCal Hobbies | JWerks | Sonic Racing | Team Gayzer | AYO Racing | Team Hastings | Uncle Larry Concepts | Moonlight Toys
stonedgti is offline   Reply With Quote
Old 03-23-2005, 01:30 PM   #10555
Evicerator,
I am without a "real" car for a while, little bit of an accident. Should get it back on a few weeks, its is currently being repaired.
dizzy1,
You are correct, one o-ring above the bladder. The carpet set-up required external limiters, but not for asphalt.
Old 03-23-2005, 02:26 PM   #10556
The Evicerator
Yes, I heard that someone went monster trucking over you while at speed... not good! Maybe danger?
Steve Weiss
Old 03-23-2005, 04:18 PM   #10557
Default Re: wheel spacers
Originally posted by yellow15
do you guys use the kit supplied wheel spacers when using the 24mm slick tyres (Sorex 28R)?
i found that my front wheels's hub thread starts to round off after 20 packs or so if i use the spacers but it's okie if i don't use any spacers. I've tried the Hotbodies white rim, tamiya one and another brand and they all have the same problem. My rear wheels seem don't have this problem.. Do you guys have the same problems?
and what is the pros/cons if i don't install the spacers?
thanks
p.s.I'm racing outdoor btw.
anyone?
yellow15 is offline   Reply With Quote
Old 03-23-2005, 04:25 PM   #10558
rc-zombies's Avatar
a wider front would be more stable and faster cornering.
haven't had any problems...
I don't use spacers..but a wider hex hub in front and the stock hubs in the rear w/o spacers.
wider hex hubs can be purchased from the Integy website and available in purple..
Old 03-23-2005, 06:07 PM   #10559
rc-zombies, thanks for your reply.
So you are running wider front than rear right? what's the downside when you have wider front? (or rear)
and since i'm not living in US, which website i can order those wide hex hub? will it work if i order some wider tamiya hex hub?
Old 03-23-2005, 07:14 PM   #10560
Registered User
I thought he was Yokomo but ummmmmmmmmm.........
v2_drag is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
