Like Tree5Likes
Old 03-20-2005, 02:53 PM   #10531
Trader Rating: 37 (100%+)
Do any of you on this thread have the following pieces from the plastic parts tree #73510.
I attached a pic with the pieces I'm looking for highlighted in blue.
please pm/email if you have any you want to get rid of. i'd be open to paypal you a small amount for them.
thanks.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 03-20-2005, 03:57 PM   #10532
Nexus I've got a tree with those parts still on it pm me.
sportracer is offline   Reply With Quote
Old 03-20-2005, 07:05 PM   #10533
axel's Avatar
How do you take out a completely stripped screw from the upper deck without having to use a dremel? I already scuffed up a part of my upper deck.
axel is offline   Reply With Quote
Old 03-20-2005, 10:21 PM   #10534
R40Victim's Avatar
You can pick up a screw extraction kit for about $10 at Sears. Once you see it, it's self explanitory.
R40Victim is offline   Reply With Quote
Old 03-20-2005, 10:26 PM   #10535
murfy's Avatar
Trader Rating: 9 (92%+)
go to your local hardware shop and ask for an easy out. it is the easiest and best screw extraction tool i have used. all you do is drill out the screw enough for the easy out bit to grab abd all you do is keep twisting the easy out bit and the screw comes out no hassel.
try it it cost me about 5 bucks to buy.
Justin Murphy
Team Xray | Hudy | Hobbywing | Sanwa
murfy is offline   Reply With Quote
Old 03-21-2005, 02:58 AM   #10536
Pro4's Avatar
Originally posted by Barger
Beware!!!!! I used a HPI carbon shaft with an Orion V2 9x1 on tarmac with foams.....in 3 runs it twisted the shaft 1/4 turn.I know of 2 other guys have had the same problem.I put a post on this thread for Thad but he must of missed it.I also emailed HPI USA but never got a reply.They might be okay for stock or19 turn but DO NOT use them for mod.
That is why it is not recommeneded for mod!!!
Pro4 is offline   Reply With Quote
Old 03-21-2005, 08:13 AM   #10537
rc-zombies's Avatar
I came across another MIP bone that will fit the the Pro4 and it's for the TC3. ..RS4 nitro rear bone. it's in Black.
http://www2.towerhobbies.com/cgi-bin...?&I=LXFRC7&P=7
Old 03-21-2005, 09:10 AM   #10538
coastaltony's Avatar
COOL
Meucci pool cue collector
coastaltony is offline   Reply With Quote
Old 03-21-2005, 04:39 PM   #10539
how is it compare to the other TC3 bones the other guys suggested? I see that this is not made of aluninium, so would it be much heavier than the other ones? or the difference isn't really noticable
yellow15 is offline   Reply With Quote
Old 03-21-2005, 04:47 PM   #10540
rc-zombies's Avatar
Made of steel...more durable than aluminum. better suited for the front bone replacement. The TC3 Shiny bones is a notch higher than these black ones.
Old 03-21-2005, 07:41 PM   #10541
axel's Avatar
What do i have to do to make the upper deck "tweak mod"?
Old 03-22-2005, 06:58 AM   #10542
jihernandez's Avatar
Default Re: Re: Weights
Originally posted by scoobydo
any hobby store has them.
They are "lead chassis weights"
Small hunks of lead that look like chicklets gum.
HPI makes some niffty looking brass ones that you need to screw down, but weights are weights.
1/4th of an ounce equals about 7 grams.
funny you guys have mentioned this.
I too noticed that due to the batts on one side, the battery side of the chassis sits lower or closer to the ground.
However, I did not use weights to correct this. Rather, I used the tweak board and balanced the car by adjusting the shock threads making sure that the car remained balanced.
Is there a negative to this approach? So far, the car seems to be driving well.
jihernandez is offline   Reply With Quote
Old 03-22-2005, 12:45 PM   #10543
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
hey Ramon,
how a u? did you get some parts from Rcmodel now? it seem that they do not want to do business with me i already send them more than 15 email ask them whether have any stock or not already pass 1 and half week they still havent reply me even i send to this email terencel@rcmodel.com.hk he also wont reply me.
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 03-22-2005, 05:57 PM   #10544
ExcelRC's Avatar
Send a message via Yahoo to ExcelRC
Default O-rings on 'other' portion of setup sheet
I am following some setup sheet and under the shock setup it has a section for other. Most sheets have two o-rings, or some kind of spacers....where are these pieces going?? Inside the shock as a down travel limiter?? Or outside the shock as a down stop?? Any help would be appreciated.
ExcelRC is offline   Reply With Quote
Old 03-22-2005, 09:21 PM   #10545
Originally posted by lee
dmatter
Take a look at the Team Prp Chassis. It gives you a longer wheel base option, top plate that acepts larger spur gears, side gaurds and a plate to keep the spur gear from flexing. It is one of if not the stiffest chassis for the pro 4
Here is a link http://www.teamprpracing.com/
PRP CHASSIS IS SO, SO, FANTASTIC!!!
Was prompted to order at once but unfortunately the site uses PayPal. PayPal does not support yet the Philippines where I a from. If only they accepted Mastercard without paypal - I would've ordered already.
