Like Tree5Likes
Old 03-13-2005, 10:13 AM   #10456
hi
can someone with a pro 4 please measure the length of the centre shaft ( pin to pin) and the widths of the pin.
hope thats clear enough,
thanks
A Gower
agower is offline   Reply With Quote
Old 03-13-2005, 11:32 AM   #10457
Trader Rating: 37 (100%+)
Originally posted by pro4racer
hi
my club changes to carpet soon and i was wondering with the current gear ratio i am using now would i have to change that wen the carpet goes down.
also would i want a harder suspension on carpet or soft
thanks
what are you running now? outdoor asphault?
if the track is a lot smaller just go down 3-4 teeth on the pinion to start with. if you give the dimensions of your track and if you're running rubber or foam tires some of the people on this thread might be able to give more specific feedback.
some people say that an indoor carpet setup and an outdoor asphault setup can be somewhat close.
this is all on rubber tires.....if you run foams with an entirely different setup.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 03-13-2005, 11:52 AM   #10458
Trinity2's Avatar
Post
Originally posted by agower
hi
thanks
A Gower
Hi you
I measured that and lenght of center shaft pin to pin = 16.3cm
Width of the pin = 2.5mm
Hope that help
Trinity2 is offline   Reply With Quote
Old 03-13-2005, 01:06 PM   #10459
scoobydo's Avatar
Originally posted by RC_Mice
DHI-CUP 2005, Odense, Danmark
Is it a Atsushi Hara car ? check the link below.
http://www.e-image.dk/gallery/2005/20050115/default.asp
The Number 7 car is Hara's.
scoobydo is offline   Reply With Quote
Old 03-13-2005, 01:37 PM   #10460
Default dogbone
I remember reading somewhere on this thread that you can replace Pro4's dogbone with the stronger one from TC3 or something? but i can't find that post again even using the search function.
so is it true? and what's the part# for the TC3 dogbone ?
btw, i've already broke two dogbones in 3 months time, i'm just racing it with a silver can motor. no big crash or anything, both of the dogbones broke at the "round" bit near the wheel side if you know what i mean. it appears to me that area got worn out and become very thin by the time it was broken... is it usual? what can i do to prevent it?
yellow15 is offline   Reply With Quote
Old 03-13-2005, 08:09 PM   #10461
rc-zombies's Avatar
I replaced my front bones with the MIP shiny TC3 bones
#1481
Old 03-13-2005, 09:24 PM   #10462
this one?
http://www2.towerhobbies.com/cgi-bin...?&I=LXSR37&P=7
it'll be a direct replacement? no mods needed i suppose? Thanks
Old 03-13-2005, 09:25 PM   #10463
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by yellow15
this one?
Thats the ones you need
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 03-13-2005, 09:29 PM   #10464
axel's Avatar
are those ones suppose to be better?
axel is offline   Reply With Quote
Old 03-13-2005, 09:45 PM   #10465
Vance's Avatar
Yellow15,
The MIP TC3 bones are crap. Try the new upgraded AE TC3 thick blue bones. They are stronger & lighter than the steel MIP's.
Cheers.
Vance is offline   Reply With Quote
Old 03-13-2005, 09:59 PM   #10466
Mal
Registered User
IRS big dawg bones for the TC3 work really good. They are bigger in diameter so they're much more resistant to bending. They also have pin cushins and 2 sets of coupler pin holes when your first set wears out.
Mal is offline   Reply With Quote
Old 03-13-2005, 11:11 PM   #10467
Originally posted by Vance
Yellow15,
Cheers.
do you got a link to those bones? does towerhobbies have them?
Old 03-14-2005, 03:08 AM   #10468
adamkerrnz's Avatar
i am interested too
adamkerrnz is offline   Reply With Quote
Old 03-14-2005, 04:14 AM   #10469
any idea when the 2005 version comes out?
Totalfixation is offline   Reply With Quote
Old 03-14-2005, 05:32 AM   #10470
jt6
jt6's Avatar
Send a message via ICQ to jt6 Send a message via AIM to jt6
Or if it will be released in the states or not?
jt6 is offline   Reply With Quote
