Like Tree5Likes
Old 03-07-2005, 12:45 PM   #10396
tc3stocker's Avatar
Send a message via AIM to tc3stocker Send a message via Yahoo to tc3stocker
Which means that you can run the new HD CVD's through AE. The thick ones that come on the TC4.
tc3stocker is offline   Reply With Quote
Old 03-07-2005, 01:02 PM   #10397
"And i'd have to say no way go with the steels if your bouncing of things "
Hi, I am not that bad, it is just the wear on the standard driveshafts with a spool is shocking. They have not broken because of a crash, just because of use and poor design (though not poor design from a business point of view). Jonathan.
jonny69 is offline   Reply With Quote
Old 03-07-2005, 01:17 PM   #10398
rc-zombies's Avatar
if you're running the spool. recommend changing the pins on the CVDS to the IRS pin Cushions. This will help minimize the excessive wear on the aluminum spools.
http://www2.towerhobbies.com/cgi-bin...?&I=LXWH70&P=7
Old 03-07-2005, 02:15 PM   #10399
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
hey Zombies,
did you experience that your pro 4 rear diff slip and even you tighten it very much but it still feel lossen? i had tighten until break 2 diff screw already but still feel the rear diff still lossen and it causing rear spining when on power connering. thanks
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 03-07-2005, 02:39 PM   #10400
rc-zombies's Avatar
Originally posted by Guo Chean
hey Zombies,
yea...that just happened to my on Sat... I tighten the diff before going out onto the track...it felt tight but after 2 laps..the car was totatly undrivable... dnf... going to take the diff apart this week and see what's going on...
and more bad luck on the next round...the bevel gear in front came loose... lucky I didn't break the one-way...just lost the e-clip and strip the mounting area on the small bevel gear.
hopefully next race I'll do better...
Old 03-07-2005, 02:49 PM   #10401
Guo Chean's Avatar
if you found out that any solution please tell me i already tighten until break 2 diff screw. and still cant find out anything hapen on my pro 4.
Old 03-07-2005, 02:51 PM   #10402
rc-zombies's Avatar
let you know what I find...if any...
also using the TC3 diff screw/spring mod that is supposedly solve the diff problems...
other wise the car handles great when everything is working properly.
Old 03-07-2005, 02:57 PM   #10403
jt6
jt6's Avatar
Send a message via ICQ to jt6 Send a message via AIM to jt6
hey Zombies,
I have had the same problem with the rear diff loosening after a rebuild, I would tighten it back up but it would loosen up again. I ended up taking it apart - rebuilding it and then using Loctite on it, and it holds.
jt6 is offline   Reply With Quote
Old 03-07-2005, 04:07 PM   #10404
Trader Rating: 37 (100%+)
rebuild your diff using the AE's TC3 diff rebuild kit.
just replace the HPI bolt, spring, and t-nut with the AE pieces. for extra security use blue loctite on the screw.
i've been running my Pro4 like this with zero problems.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 03-07-2005, 05:42 PM   #10405
Trader Rating: 2 (75%+)
Default Click, click, click
Guys,
I had a problem this weekend with my Pro4..........A lound clicking noise is coming from the the diffs. Yes, I have done the AE bolt & t-nut mod on both diffs......I'm useing two ball diff (front and rear)on my Pro4. To tell yall the truth I just rebuilt my rear diff with the AE mod and it just started to make that noise when I did that...and only that!! That means I put everything back when I did the rebuild (same shimming and gears). So I'm at lost to know what is going on with my Pro4..........the sound sounds like a strip gear but it not.
Please Help!!!
PUNISHER is offline   Reply With Quote
Old 03-07-2005, 05:50 PM   #10406
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: Click, click, click
Originally posted by PUNISHER
Guys,
Please Help!!!
Loud Clicking noise..
I had a similar problem with the white diffs when I rebuilt them... but to my surprise what I found was the diff ring gear bearing spacer had a lot of play between the gear and the bearing... I replace the gear and bearing black ring and glued them in place... and BAM... rear diff no longer clicks .... some small thing to look at because I too thought that the rear diff ring gear/bevel gears were broken
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 03-07-2005, 06:20 PM   #10407
Default Re: Re: Click, click, click
-Dave
Awesome Dave.......thanks for the reply!!
Ok, that might be it...I did not glue that bearing ring.
I check it out and let you know..........
Thanks again,
Mike
Old 03-07-2005, 08:43 PM   #10408
ngo8's Avatar
Send a message via ICQ to ngo8
i tried the associated diff screw spring, nut combo on my diffs and it works mirackles i havent touched my diffs in a month they dont loosen up and dont get gritty and i do check my diffs every run and they are super smooth and yeah i do run on carpet where they get more stress than asphalt.
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 03-07-2005, 11:30 PM   #10409
chaini's Avatar
No problem... I`m tring to get some pic`s now
-Dave
Hi there
Any news about this car?
Any links where this info is comming from?
chaini is offline   Reply With Quote
Old 03-08-2005, 02:51 AM   #10410
Pro4's Avatar
When ever I rebuild my diff I ALWAYS replace the little lock nut. What I think happens, is that constant turning, on the small nut wears the nylon very easily. Yea sure it is the same as the wheel lock nuts but these are a lot smaller. Since I started replacing the lock nuts...no problems at all!!!
Pro4 is offline   Reply With Quote
