Like Tree6Likes
Old 02-26-2005, 05:37 PM   #10291
murfy's Avatar
Trader Rating: 9 (92%+)
Originally posted by pro4racer
dont supose any one would b able to post the setup on here but not in a pdf format my computer wont print from that program mfor sum unknown reason
thanks
look in the back of your Pro 4 manual it has the set ups there.
Justin Murphy
Team Xray | Hudy | Hobbywing | Sanwa
murfy is offline   Reply With Quote
Old 02-26-2005, 05:40 PM   #10292
lunytune's Avatar
any one know why HPI discontinued part # 75053 ceramic nitride diff balls and part # A756 ceramic diff balls
lunytune is offline   Reply With Quote
Old 02-27-2005, 12:24 PM   #10293
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
i need help does anyone know where can i get aluminium purplr screw for hpi pro 4? i need metric size screw thanks
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 02-27-2005, 12:33 PM   #10294
Probably due to inconsistent durability of the balls (a common problem with non-certified ceramic bearings).
lunytune if you need a souce for certified ceramic bearings (for only $1 per ball) email and I'll send full info. We've been buying the certified grade three silicon nitride diff & thrust ball sizes in bulk for about five years now. JRX-S Bill and a few of the other rctech members have been using them (in fact Bill just posted another recommendation in the forum today---thanks Bill!)
ZoomAddict is offline   Reply With Quote
Old 02-27-2005, 02:59 PM   #10295
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Square them in Purple now.... in all the sizes you would need
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 02-27-2005, 03:14 PM   #10296
ChadCapece's Avatar
Does anybody a set of 4 Pro 4 shocks. I need to buy them asap. LMK what you have at [email protected]
thank you
chad
ChadCapece is offline   Reply With Quote
Old 02-27-2005, 03:50 PM   #10297
How many degrees is the original rear hub on the pro4 ??
Snikkari is offline   Reply With Quote
Old 02-27-2005, 04:44 PM   #10298
fire929's Avatar
Default Difference
Does anyone have a solution for the weight difference a battery puts on the chassis fully loaded. Battery side sits 1.5mm lower then the electronic side...... Maybe chassis weights just do not know how much and where to place??????
Trex 450
Trex 600
EFL Heli's
Futaba 8fg
Align 3gx
fire929 is offline   Reply With Quote
Old 02-27-2005, 05:01 PM   #10299
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Set your ride height first and then check the spacing of the collars on the shocks. If they are way out of range from each other then maybe the chassis has a slight tweak in it. Take the wheels off and the shocks and put the chassis on something that you know is flat. The loosen the top deck and position the chassis and then tighten down the top deck.
Other things to check:
Make sure your shocks are equal length.
Measure your spring length to make sure they are equal.
Try a different set of springs as well.
Make sure the bottom spring retainers are seated properly on the end of the shock shaft.
Hopefully it is something really easy to see but at least this should help get you going in the right direction.
Kraig
KT Hobbies
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 02-27-2005, 05:06 PM   #10300
scoobydo's Avatar
Default Re: Difference
anywhere between 84-100grams usually will balance it out.
Depends on your layout.
about 21-28 grams next to your motor on the outside part of chassis.
about 14 grams in between your main shaft and your esc
another 14-28 grams next to your reciver on the outside part of the chassis.
I put 7-14 grams between my motor and my esc.
Don't stack weight. Distribute it evenly on the electrics side.
Again, this all depends on your layout, but if you stick to around 84-100 grams you should be close.
scoobydo is offline   Reply With Quote
Old 02-27-2005, 06:04 PM   #10301
fire929's Avatar
Default Weights
Where can you purchase the weights?????
Trex 450
Trex 600
EFL Heli's
Futaba 8fg
Align 3gx
Old 02-27-2005, 06:07 PM   #10302
scoobydo's Avatar
Default Re: Weights
any hobby store has them.
They are "lead chassis weights"
Small hunks of lead that look like chicklets gum.
HPI makes some niffty looking brass ones that you need to screw down, but weights are weights.
1/4th of an ounce equals about 7 grams.
Old 02-27-2005, 06:12 PM   #10303
ChadCapece's Avatar
At any hobby shop or golf store. It is lead tape that has an adhesive side.
Old 02-27-2005, 06:17 PM   #10304
fire929's Avatar
Default Thank you
You guys answer questions better then the company that makes the chassis. Should be paid thnx a lot scoobydo and pro4capece rolling now
Trex 450
Trex 600
EFL Heli's
Futaba 8fg
Align 3gx
Old 02-28-2005, 10:11 PM   #10305
rc-zombies's Avatar
wow.. a full day without any new info... must be a very slow day...
back to page 1
