Old 02-25-2005, 03:03 PM   #10276
Suspended
tjcdas1212's Avatar
Spam deleted.
-Speedo
tjcdas1212 is offline   Reply With Quote
Old 02-25-2005, 03:31 PM   #10277
J_Longbrake's Avatar
Trader Rating: 20 (100%+)
Originally posted by rayhuang
Hey Longsnake-I hear your laying it down in mod-whats up with that?
The TC4 doesn't work, period. The Pro 4 does.
J_Longbrake is offline   Reply With Quote
Old 02-25-2005, 05:13 PM   #10278
Send a message via Yahoo to nomaak
macnkitty, you still out there?. march is almost here. do you have your pro4 yet? i was hoping your R/C club has got together a strong electric class this year. cause i don't have a nitro yet.
nomaak is offline   Reply With Quote
Old 02-25-2005, 06:21 PM   #10279
racer's Avatar
Originally posted by kewdawg
In my experience with the Pro 4, adding kick-up increases front traction which translates into more overall steering. Not sure how much kick-up you'll need. I'm using .5mm of kick-up and 2* castor blacks for stock racing on carpet w/ foam tires. I'm considering going to 0* castor blocks to increase on-power steering. I guess the question is: what are you trying to achieve by reaching 3* of castor? Also, your set-up info. and track conditions would help others to help you.
one of the racers at my local track said that 3 degrees is ideal for any car, whether foam or rubber.
for setup i'm running a stock motor with rubber on carpet.
racer is offline   Reply With Quote
Old 02-26-2005, 08:18 AM   #10280
kewdawg's Avatar
Ok, but... you still haven't said what you're trying to achieve by getting 3 degrees of castor? Depending on your answer, you could be going the wrong way.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 02-26-2005, 09:29 AM   #10281
dizzy1's Avatar
Trader Rating: 23 (100%+)
Sounds like the guy giving the advice drives and Xray since I believe they have 3 and 6 degree blocks. If you can tell the difference between 2 and 3 degrees, then your name must be Hara, Baker or Masami.
All about that Hot Pockets again! Woot Woot! Tried the Russian rocket but tired of the 'part of the week'. All gold everything '15 only made a weekend, such a numb and overpriced car!
Team Hot Bodies- Hobbywing- Schuurspeed
dizzy1 is offline   Reply With Quote
Old 02-26-2005, 10:06 AM   #10282
kewdawg's Avatar
Yeah... you do have a point. Although, I'm really courious as to what he's trying to do with his set-up???
Quinn Moon
Old 02-26-2005, 12:35 PM   #10283
pro4racer's Avatar
hi
on march the 18 my club is moving over to carpet racing over the crappy wooden floor we currently race on.
jus wondering is there any1 out there that could supply me with a decent setup for the pro4 running stock on cs-22 but with mostly kit items as i have not purchased any other parts yet.
thanks
pro4racer is offline   Reply With Quote
Old 02-26-2005, 12:57 PM   #10284
The Hara DHI 2004 setup shuld be a good starting point for rubber racing. Uses stock suspention-blocks and springs, you probably only need some shims.
Erlend is offline   Reply With Quote
Old 02-26-2005, 01:38 PM   #10285
Trinity2's Avatar
Arrow
Jeah, and after that, when you`ll got some option springs etc. you can try Andy Moore`s carpet world set-up which is much more easier to drive
Trinity2 is offline   Reply With Quote
Old 02-26-2005, 01:44 PM   #10286
racer's Avatar
i wasn't really wanting to achieve anything. just wanted to know how to get 3 degrees of castor on the car.
sorry,
Old 02-26-2005, 02:40 PM   #10287
pro4racer's Avatar
dont supose any one would b able to post the setup on here but not in a pdf format my computer wont print from that program mfor sum unknown reason
thanks
Old 02-26-2005, 04:47 PM   #10288
lunytune's Avatar
Originally posted by blast
does anybody know someone that can make me a 3mm. chassis for my PRO2 please PM me.
Patrick
HPI now maks a 3 mm pro 4 chassie
lunytune is offline   Reply With Quote
Old 02-26-2005, 05:52 PM   #10289
SchuMi2's Avatar
Trader Rating: 34 (100%+)
Pro 2 not Pro4 I dont know of anyone....maybe you could glue 2 x Pro 2 chassis together
SchuMi2 is offline   Reply With Quote
Old 02-26-2005, 06:34 PM   #10290
lunytune's Avatar
HPI part# for pro 4 3.0mm chassie #73826
SEO by vBSEO 3.5.0
