Old 02-23-2005, 07:57 AM   #10201
Trader Rating: 17 (100%+)
Send a message via AIM to Roberto Falcon
Can someone tell me how much are these shocks a set of 4 . the original kit ones not the Hara upgraded ones . Thanks
Roberto Falcon is offline   Reply With Quote
Old 02-23-2005, 08:06 AM   #10202
rc-zombies's Avatar
Hara uses the stock kit shocks...
Old 02-23-2005, 08:10 AM   #10203
OH! How much are the kit ones those are the ones im looking for anyways.
Old 02-23-2005, 08:31 AM   #10204
jhigga15's Avatar
Do you guys normally use HPI body's on the Pro 4? I am loking to get a new body and I would like to know if Tamiya body's would fit? Thanks
jhigga15 is offline   Reply With Quote
Old 02-23-2005, 08:41 AM   #10205
rc-zombies's Avatar
any 190mm body will fit. most Tamiya will fit.except those that have a really low hood. front shock towers are a little high on the pro4. LIke hpi bodies.... tamiya bodies have the body hole dimples on them... only the front ones line up.
Old 02-23-2005, 08:44 AM   #10206
Frank McKinney's Avatar
75142 THREADED ALUMINUM SHOCK SET (48-60mm)
Minimal signature to save screen space! Big sigs suX0r
Frank McKinney is offline   Reply With Quote
Old 02-23-2005, 09:08 AM   #10207
Nipple's Avatar
Hi guys,
Just wondering if any of you Pro4 drivers had tried using a screw to hold the bevel gear to the input shaft instead of the e-clip.
Well I did, and it works great!!
I taped a hole and used a square 2.6x4 titanium screw.
And the reason I did this mod is because, I find that after I correctly shim the gears, they will not break, instead somehow the e-clip will fly off the input shaft causing other damages......
It is something like Yokomo SD's input shaft except we still use the spring pin to drive the bevel gear.
Hope this help.
Nipple is offline   Reply With Quote
Old 02-23-2005, 09:11 AM   #10208
rc-zombies's Avatar
I've had my car for over a year now...and never had a problem with the e-clip coming off...
hope you lock-tite the screw to prevent it from coming loose...
Old 02-23-2005, 09:28 AM   #10209
Erik Shauver's Avatar
Originally posted by Frank McKinney
72170 THREADED ALUMINUM SHOCK SET (45-56mm)
Nope, use the 75142 shock set. The 75142 set is the standard shock that comes with the Pro 4. They come with the Pro 4 plastic shock parts and the correct length springs for a Pro 4. 72170 are not going to help much, the spring is too long, the plastic parts will be incompatible with Pro 4. Also this set includes rebound foams and the firm bladders. They would be good for your Pro 2 however. Street Price for the 75142 is roughly $35 per pair. They will also be easier to fit to other makes as the shock ends mate up to a plastic ball that slides over a 3mm screw, much smoother is use and easier to install and take off than a ball end that snaps on.
Erik Shauver is offline   Reply With Quote
Old 02-23-2005, 09:39 AM   #10210
Trader Rating: 36 (100%+)
Erik Shauver.
Do you know when the HPI will be selling the aluminum camber link mounts and high traction arms?
I see them on the overseas sites and on japanese websites....but nothing here in the US.
Thanks.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 02-23-2005, 09:43 AM   #10211
mmm leave that one alone, E! haha
I've corrected my original post, thanks dude.
Old 02-23-2005, 09:45 AM   #10212
Nexus, I'm not sure about the dates for the arms, but the aluminum camber mounts are too expensive to import. The street price would be extremely high (likely more than a main chassis for one!). The only camber mount option for the US market will be the carbon fiber version.
Old 02-23-2005, 09:47 AM   #10213
No problem OG! haha, don't forget the stroke is now 48-60mm instead of 45-56mm
Old 02-23-2005, 09:52 AM   #10214
The Evicerator
How would you gear using shocks with only a 45-56 mm stroke as opposed to the 48-60 mm stroke?
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 02-23-2005, 10:05 AM   #10215
rc-zombies's Avatar
Erik..
ETA on the new belt car?
did you do the design on that car? either way...the car looks great.
