Like Tree6Likes
Old 02-21-2005, 06:46 PM   #10186
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by rc-zombies
don't waist your time and money on the Kai parts...not worth the money.
... way over priced..... but very good quality carbon fiber
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 02-21-2005, 08:21 PM   #10187
Trader Rating: 37 (100%+)
Originally posted by NVisible
Im wondering about the durability of the Pro4. is there any item that breaks frequently? thanks for any info you guys can provide
With the BRP Bumper mod you really shouldn't break much.......the car is pretty durable.
10th Yamayama Cup in Japan. 23T 8min asphalt race. Front gold, Rear silver springs. Rubber tires.
Ken...thanks!!
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 02-22-2005, 10:08 AM   #10188
Mach10_shooter's Avatar
Default PRO 4 CHASSIS THICKNESS
I have just reciently picked up my first Pro 4. I got it used with alot of spares and 2 chassis plates one new 3mm and a very used 2mm stock plate. I plan on running this car outdoors and I know that most people run the 3 indoors. How can I expect the car to handle if I run the thick plate outdoors compared to the stock plate? Also if anyone has a good stock plate I would be interested in it.
Thank you
Chris
Mach10_shooter is offline   Reply With Quote
Old 02-22-2005, 10:15 AM   #10189
Trinity2's Avatar
Post
I had problem with bewel gears up front at first, but now that is history.
I managed to broke a couple of shaft drive cups in some major hits, when i raced our "demolition derby club races"
Trinity2 is offline   Reply With Quote
Old 02-22-2005, 10:16 AM   #10190
rc-zombies's Avatar
Default Re: PRO 4 CHASSIS THICKNESS
Thank you
Chris
you will loose some traction using the thicker 3mm chassis. most racers run the stock 2.5 or optional 2mm chassis outdoors.
Old 02-22-2005, 10:22 AM   #10191
Trinity2's Avatar
Thank you
Chris
Hey Chris
Did you mean at stock chassis is 2.5mm?
Top guys use that 2.0mm chassis in asphalt racing, because it give more grip.
Old 02-22-2005, 10:27 AM   #10192
Yes I meant 2.5mm.
Old 02-22-2005, 10:45 AM   #10193
Yes I meant 2.5mm.
I'd run the stock 2.5 for asphault or carpet rubber tires.
If you do have the optional 2mm lower and run outdoors I would definitely use it.
Only time I would use the 3mm is if you are running carpet w/ foams.
Old 02-22-2005, 10:52 AM   #10194
axel's Avatar
I just stick to the 2.5mm chassis because There are races indoor and outdoor where i live .
axel is offline   Reply With Quote
Old 02-22-2005, 01:24 PM   #10195
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
Hi KingCrab,
so how was the straight carbon chassis work? is that better of same? so did you plan to sell in market?
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 02-22-2005, 01:37 PM   #10196
Trinity2's Avatar
Post
That`s wright to you axel. When we start here outdoor season in may, i`ll change that 2.0mm chassis to my Pro4
Old 02-22-2005, 07:05 PM   #10197
axel's Avatar
Just cusrious are there any good sites with race videos particularly having pro 4's
Old 02-22-2005, 07:40 PM   #10198
axel's Avatar
is a 48p 38t pinion good for a pk2 pro?
Old 02-22-2005, 09:56 PM   #10199
Pro4's Avatar
Thats way too big...I was using a 29t with a 70t spur with a race prep p2k2 pro
Pro4 is offline   Reply With Quote
Old 02-23-2005, 12:36 AM   #10200
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
Hey Fastfart,
checked my front CVD's, they have "twisted a bit aswell"
90 degrees
dontfeelcold is offline   Reply With Quote
