Like Tree5Likes
Old 01-14-2004, 11:34 AM   #1006
rc-zombies's Avatar
Default Re: Re: **WARNING**
Originally posted by Randman
lol, nice job Ramon! I'm sure that's the dialed setup
Old 01-14-2004, 11:53 AM   #1007
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
With gears like that you will have the smoothest diff possible and it will also be the smoothest spinning trans to.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 01-14-2004, 11:57 AM   #1008
rc-zombies's Avatar
It's also super lightweight...
Old 01-14-2004, 12:31 PM   #1009
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Default Re: Re: Re: **WARNING**
Originally posted by rc-zombies
BTW, what's the deal with boiling the gears?
Old 01-14-2004, 01:11 PM   #1010
rc-zombies's Avatar
Default Re: Re: Re: Re: **WARNING**
To add moisture to the gears making it more durable... not doing so...result in the gears breaking up, it was to brittle...I'm sure HPI has a new updated gear in the works.
Transmission cases and shaft installed...(still gearless )
Old 01-14-2004, 01:12 PM   #1011
rc-zombies's Avatar
Originally posted by forty6
Cool. Are the body post 55 or 60mm? Also, let us know about the question regarding the countersink being not deep enough as mentioned by Kenneth. Thanks rc-z!
No problem with countersink depth... all screws flat with the chassis. :
Old 01-14-2004, 01:33 PM   #1012
lazyboy's Avatar
Send a message via AIM to lazyboy
Post
the car looks really good
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 01-14-2004, 03:16 PM   #1013
rc-zombies's Avatar
My only dislikes so far are the suspension shaft mounting balls.
they are made of steel... They are very smooth now...but I could see these made of Delrin, lighter and even smoother.
I'm sure Square RC, HB, Jet, Tobee will come up with alot of option parts for this car. ie. steering bell cranks, camber link mounts, servo post, Ti input shafts, tranmission case like the Evo's. etc. etc...
Old 01-14-2004, 03:20 PM   #1014
JohnA's Avatar
I'm sure Square RC will come up with alot of option parts for this car. ie. steering bell cranks, camber link mounts, servo post, tranmission case like the Evo's. etc. etc...
That's pretty good if that's the only dislike, not an expensive thing to change!
I'm sure you're right about Square, and pobably HB, wonder if we'll see a Hara Pro-4?
JohnA is offline   Reply With Quote
Old 01-14-2004, 03:34 PM   #1015
rc-zombies's Avatar
Haven't fully assembled the car yet...may run across other thinks. My other concern is changing Spur gears...looks like a handfull of screws and upperdeck removal to get the little bugger out... the SD did a great job in designing this area...
Hara Pro-4... if it wins the worlds this year...most probably.
Old 01-14-2004, 04:19 PM   #1016
Does anybody know what the spring rates of the kit springs are ?
(lbs/inch if possible)
C.L.1. is offline   Reply With Quote
Old 01-14-2004, 05:34 PM   #1017
Vince's Avatar
Default Re: **WARNING**
Don't do what I did
When boiling your bevel gears...do NOT!
leave them unattended.
What does boiling the gears do???????
Capricorn
Murnan Modified Motors
RC Target
Signature space for sale
Vince is offline   Reply With Quote
Old 01-14-2004, 05:39 PM   #1018
Vince's Avatar
Default Question
Do you have to modify the diff cases to keep the bearings from binding like you do the tc3??????
Capricorn
RC Target
Old 01-14-2004, 07:10 PM   #1019
Erik Shauver's Avatar
Erik Shauver is offline   Reply With Quote
Old 01-14-2004, 07:20 PM   #1020
Vince's Avatar
Thanks Erik!
Capricorn
RC Target
