Old 02-18-2005, 11:49 AM   #10156
Trader Rating: 36 (100%+)
Originally posted by rc-zombies
let's keep this thread pro4 specific....
there is HB TC thread already started...
On that note...
Is anyone using the Pro4 graphite or aluminum HPI camber link holders yet?
Just wondering what people thought was more rigid and durable.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 02-18-2005, 12:31 PM   #10157
rc-zombies's Avatar
Originally posted by Nexus
On that note...
the aluminum one will be more rigid and durable....and racer friendly... the CF one uses a locknut to hold the ball in place which can be a pain in the butt holding in place and trying to thread the balls in...
Old 02-18-2005, 12:34 PM   #10158
scoobydo's Avatar
Originally posted by axel
the car basically is a belt version of the pro 4, with more aluminum parts. I think the HPI should make aluminum transmission hubs for the pro 4 just like the pro 4 prototype.
Is their any pics of the proto with the alum bulks?
I've been advocating alum bulks forever now, but I would hate to have the car weigh a ton. It would just be nice since you have to wrench to much with the pro4 to have alum bulks. The graphite bulk heads strip so easy. And I don't apply much pressure, just enough to where they are snug.
scoobydo is offline   Reply With Quote
Old 02-18-2005, 12:43 PM   #10159
rc-zombies's Avatar
haven't had any problems the graphite bulkheads stripping. did you lube the screw threads before installing?
here's a pic of the proto w/alum. bulkheads
Old 02-18-2005, 07:14 PM   #10160
TRF Drive Hard's Avatar
Send a message via AIM to TRF Drive Hard Send a message via Yahoo to TRF Drive Hard
Sweet lookin but just another 415 concept... per say tech racing...
TRF Drive Hard is offline   Reply With Quote
Old 02-18-2005, 09:12 PM   #10161
rice's Avatar
Originally posted by JDM_DOHC_SiR
Here we go again... One year ago it was battle for the best Shaft drive.. now it looks like 2005 will be battle of the belts
-Dave
ur rite. id like the belt of hpi compare to fk05. the spur is more accessible..
rice is offline   Reply With Quote
Old 02-18-2005, 09:20 PM   #10162
murfy's Avatar
Trader Rating: 9 (92%+)
i agree aswell. but saying that one cars is better than an other buy the way u can change the spur gear is bs.
i think that i would definatly go the hpi/ HB over the new fk05 but as far as proformance goes thats how i will pick which car i want.
Justin Murphy
Team Xray | Hudy | Hobbywing | Sanwa
murfy is offline   Reply With Quote
Old 02-18-2005, 10:02 PM   #10163
scoobydo's Avatar
Dude, I keep saying the same thing. But......that FK05 looks really nice.
Besides the T1 series is proven already.
I may just have to buy all of them!
I know for a fact this summer I am running:
Pro 4 and T1FK05
Old 02-19-2005, 01:05 AM   #10164
414m2's Avatar
After looking at the new HPI car it reminded me of another car i saw a while ago on rczone.net.
http://www.rczone.net/modules.php?na...rticle&sid=432
Similar Idea. And probably balanced better too.
I think the servo should face forward like the pro4 so people with short servos (e.g. futaba s9550) can keep their advantage.
414m2 is offline   Reply With Quote
Old 02-19-2005, 02:56 AM   #10165
Send a message via MSN to Grindog001
Is it possible to widen the car? My car is only 184.5 mmm wide. If i put washers by the hex to widen it, not enough hex is sitting in the wheel. Is it possible to get a wider wheel hex?
Grindog001 is offline   Reply With Quote
Old 02-19-2005, 04:36 AM   #10166
azenis's Avatar
Default swaybars
hi guys
i am half way through rebuilding one of my 4's and i have fitted the sway bar up to the front.
there are no shocks mounted up yet and i was testing the sway bar by moving the suspension.
when i move the RHS arm the sway bar pulls the LHS up as it should, but when i move the LHS the RHS barely moves. Anyone know why this would occur?
Nige
X-Ray T4 '14 | 3Racing Sakura D3 CS | Durango DEX410v4 | HPI Blitz | Tamiya WR-02 VW Bus
azenis is offline   Reply With Quote
Old 02-19-2005, 05:08 AM   #10167
Thraex's Avatar
That's A Andreas Myrberg design, and Anders (father of Andreas) told me that it's one of the best handling car he'd ever driven.
Though, I don't think they go on with that design.
Since Andreas is driving for Xray now (and I thought he owns it), and Anders was very clear to me that they won't put any effort and energie in it.
So donīt expect much of it...
Thijs van M[HPI/HB]
Thraex is offline   Reply With Quote
Old 02-19-2005, 05:16 AM   #10168
Thraex's Avatar
By the way, the link with the pics on it says `Hot Bodies Touring Car Prototype`, maybe this design/lay-out isn't going to replace the Pro 4, but will be available by Hot Bodies (hpi's side company)???
Thijs van M[HPI/HB]
Old 02-19-2005, 07:05 AM   #10169
JohnB's Avatar
R/C Tech Charter Subscriber
Default Re: swaybars
Originally posted by azenis
hi guys
Sounds like both sides are not equal or something on the RHS side is binding. Try taking the bar off, lay it on a table and see if it is tweaked. Both tips and entire flat between the bends should be touching. If not, bend it back where it's correct.
Then make sure the length of the two tie rods is the same. That's really about it. When you have the bar off, the RHS suspension moves free and drops under it's own weight, doesn't it?
take care
john
JohnB is offline   Reply With Quote
Old 02-19-2005, 07:15 AM   #10170
azenis's Avatar
Default Re: Re: swaybars
yeah it does drop under its own weight, and i dont think its tweaked, i will have to pull it out to check...
ahh just fixed it
I tightened up the LHS grub screw a half turn more and now it works fine!
take care
john
Nige
