Like Tree5Likes
Old 02-08-2005, 12:55 PM   #10036
Trader Rating: 2 (75%+)
Originally posted by Exe
i don't get people.. why would you want to put weigt on drivetrain? if you need weight, put it on th chassis betterr..
by the way, talking about weight, can anyone tell me how much your pro4 weights?
i have pro4 with novak ss5800 brushless, futaba 9451 digital servo, hpi rubber advan tires with dish wheels and profotorm
stratus body, total weight 1520 , isn't that too much?
That sounds about right with a brushless system.
Mine is way under weight with normal esc and motor (1460ish).
This isn't a bad thing for you can put the weight were it needs it on the chassis with lead weights.
PUNISHER is offline   Reply With Quote
Old 02-08-2005, 01:17 PM   #10037
rc-zombies's Avatar
Originally posted by J-P
Hey guys,
is anyone running high traction arms on tarmac?? can anyone give me any feedback on them??
J-P
installing mine tonight...
made of a softer material giving it more flex.
Old 02-08-2005, 01:24 PM   #10038
J-P
J-P's Avatar
rc-zombies,
when you run it can you let me know how you get on with them? i might fit mine on tommorow and run them sunday.
J-P
J-P is offline   Reply With Quote
Old 02-08-2005, 01:26 PM   #10039
rc-zombies's Avatar
rc-zombies,
J-P
may not be able to run til the weekend... the weather has not been cooperating lately...
Old 02-08-2005, 03:24 PM   #10040
does anyone have the part number for the high traction arms what are they made of.
sportracer is offline   Reply With Quote
Old 02-08-2005, 03:31 PM   #10041
rc-zombies's Avatar
HPI 31420 PRO4 HIGHT TRACTION SUSPENSION ARM SET
1 set is enough to do 1 car...2F and 2R.
made of plastic material..not carbon.
Old 02-08-2005, 08:07 PM   #10042
thanks zombie so they have just a little flex in them should they be boiled like the old rs4 pro's.
Old 02-08-2005, 09:28 PM   #10043
rc-zombies's Avatar
I haven't boiled mine...
I think boiling them would add more flex...
Eric would be better to answere that...
to boil or not to boil....
Old 02-08-2005, 10:14 PM   #10044
Pro4's Avatar
Default Re: Spool
Originally posted by fire929
Does anyone currently utilize the front spool for the pro 4. Like or Dislike?????
A very strong LIKE from me. I have used the titanium racing spool and I loved it. Getting the HPI one in a few days and will be putting it straight in for where I race.
Pro4 is offline   Reply With Quote
Old 02-10-2005, 08:02 AM   #10045
Merciless's Avatar
Send a message via ICQ to Merciless
Originally posted by Nexus
If you look at HPI Team Drivers setup sheets like Andy Moore, Hara, ect....they all seem to use Delrin outdrives running low turn mods.
One of the drivers locally ran Delrin outdrives running stock, 19T, and Mod and never complained about them.
I'm using them in 19t and i'd say the wear rate is high, even compared to the std. parts
Merciless is offline   Reply With Quote
Old 02-10-2005, 08:06 AM   #10046
Skill's Avatar
I've been running mine in mod and 19t ever since they came out, every week, and there aren't any signs of wear...
Skill is offline   Reply With Quote
Old 02-10-2005, 10:02 AM   #10047
Twin-Kyle's Avatar
I run stock...same here NO wear.Gota love it!!!
Twin-Kyle is offline   Reply With Quote
Old 02-10-2005, 01:37 PM   #10048
Default High Traction Arms
From my understanding the only reason the new arms have come out is that they were breaking at the worlds. The extreme bite that the track gave and the INSANE motors being used meant that corner speed was ridiculous and since the compressive force in the lower wishbone is about 3x higher than that in the turnbuckle, it was causing them to literally break! i heard that some of the FAST teams drivers would go on practice runs and without any collisions arms were breaking. Guess these less rigid new arms will help, maybe it was just a bad batch though that were a little too brittle, i think that the team just replaced all wishbones and the problem went away, maybe they got a bit worried and thought the problem should be sorted.
Just my thoughts,
Rob
Robz is offline   Reply With Quote
Old 02-10-2005, 01:40 PM   #10049
Trader Rating: 37 (100%+)
Default Re: High Traction Arms
Just my thoughts,
Rob
I can't imagine they were just snapping arms because of the power in their cars...
It has more to do with having a softer arm to run on asphault.....which since are softer have a little more flex which would possibly give you better traction. Same reason they use a 2mm chassis instead of a thicker.
Once we can get them here in the U.S. I'll probably buy some...pricewise it's a pretty good deal because you get all four arms for only about $3-4 more dollars.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 02-10-2005, 01:51 PM   #10050
Mal
Registered User
I would think that foam tire mod has much more stress loads to the arm than rubber tire racing on any surface. Plus this is the first time I had hear of arms breaking at the worlds during no contact situations.
Mal is offline   Reply With Quote
