Old 01-13-2004, 03:55 PM   #991
rc-zombies's Avatar
Originally posted by forty6
C'mon take some pix to tide us over.
Here ya go..
Old 01-13-2004, 03:56 PM   #992
rc-zombies's Avatar
The Catalog is very nice...
Maybe I'll post pics throughout the whole building process...
Old 01-13-2004, 04:08 PM   #993
JohnA's Avatar
They had better be more interesting than that one
JohnA is offline   Reply With Quote
Old 01-13-2004, 05:56 PM   #994
forty6's Avatar
Here ya go..
Cool. Are the body post 55 or 60mm? Also, let us know about the question regarding the countersink being not deep enough as mentioned by Kenneth. Thanks rc-z!
forty6 is offline   Reply With Quote
Old 01-13-2004, 06:57 PM   #995
rc-zombie how does the chasis compair to the evo 3 is ti a litttle wider or is it the same size , looking for more room for electornics.
sportracer is offline   Reply With Quote
Old 01-14-2004, 09:00 AM   #996
rc-zombies's Avatar
body post...don't know yet... but I do have both 55 & 60mm HB purple body post ready to mount... I think both should work fine depending on how high you body hood is...
Countersink...I'm using Ti Screws from Alex Racing..tons left over from my 'Cuda. and all the screws are flat with the chassis.
Old 01-14-2004, 09:19 AM   #997
rc-zombies's Avatar
don't have an Evo3...so I can't compare... but to me they look about the same. After I installed the Futaba S9550 digital low profile servo...there is plenty of room for the electronics. I think even with a regular servo...there's still plenty of room.
At this point of assembly...the arms and steering linkage is the smoothest I've ever seen. THe fit is perfect!... the arms are very stiff...very little to no flex at all. with the 2.5mm chassis there is very little lateral flex... I can imagine there will be very minimal flex when when the car is fully assembled with the upperdeck.
As you can see...plenty of room for electronics:
Old 01-14-2004, 09:53 AM   #998
rc-zombies's Avatar
Exclamation **WARNING**
Don't do what I did
When boiling your bevel gears...do NOT!
leave them unattended. In the midst of assembling the car...forgot about the gears in the pan...and this is the result...
Good thing I order a lot of extra gears from RainbowTen...
Old 01-14-2004, 09:58 AM   #999
Send a message via ICQ to lawndoggie Send a message via Yahoo to lawndoggie
I am new to RC, and very new to EP, have no experience with shaft cars, are you suppose to boil your bevel gears???? Why?
lawndoggie is offline   Reply With Quote
Old 01-14-2004, 09:59 AM   #1000
Regional Moderator
R/C Tech Charter Subscriber
LOL Ramon that is to funny man
Ko Racer is offline   Reply With Quote
Old 01-14-2004, 10:01 AM   #1001
rc-zombies's Avatar
I never had to with my other cars like the TC3 or Yok SD's. In it's current state..the bevel gears are dry & brittle and may break when racing... boiling the gears softens them up and makes them more durable... It's stated in the HPI japan R&D cafe. I"m sure HPI will address the problem with a new set of bevel gears.
Old 01-14-2004, 10:01 AM   #1002
rc-zombies's Avatar
You said it! ....
Old 01-14-2004, 11:25 AM   #1003
pucho's Avatar
Send a message via AIM to pucho
When boiling the gears I would recomend you string them together and place a shishkabob stick over the top so that they are not sitting on the bottom of the pot.
pucho is offline   Reply With Quote
Old 01-14-2004, 11:26 AM   #1004
rc-zombies's Avatar
I will have to try that next time..
don't want any more well-done gears...
Old 01-14-2004, 11:30 AM   #1005
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Default Re: **WARNING**
Don't do what I did
lol, nice job Ramon! I'm sure that's the dialed setup
