Old 02-04-2005, 08:32 AM   #9991
rc-zombies's Avatar
Originally posted by coastaltony
picture of pinion gear
I had the problem too when I first got my car...the gears not aligning correctly...
I fixed that by adding a round motor heatsink plate between the motor and motor mount. found it on RcModel made by Speedmind.... and it's purple...
Old 02-04-2005, 10:55 AM   #9992
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
Post
hi does anyone who know where to get the straight carbon chassis and upper deck that hara used in JMRCA and DHI cup? how much will it cost to make this two piece of chassis. thanks
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 02-04-2005, 10:59 AM   #9993
rc-zombies's Avatar
not available to the public...
if you're racing asphalt just get the regular 2mm chassis plate
Old 02-04-2005, 12:03 PM   #9994
coastaltony's Avatar
Anyone remember who makes the little metal (golf tee) thingys to set the Pro 4 on?
Meucci pool cue collector
coastaltony is offline   Reply With Quote
Old 02-04-2005, 12:32 PM   #9995
Trinity2's Avatar
Post
You mean balance of the car? HUDY makes them.
Trinity2 is offline   Reply With Quote
Old 02-04-2005, 12:56 PM   #9996
rc-zombies's Avatar
Xray / Hudy
Old 02-04-2005, 01:27 PM   #9997
Thanks guys.
Old 02-04-2005, 04:32 PM   #9998
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: Re: Re: Re: Re: Hara's bodyshells
Originally posted by scoobydo
Do the RIDE bodies come with overspray film?
Sure do
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 02-04-2005, 04:32 PM   #9999
crACkeD ChaSsiS's Avatar
Send a message via AIM to crACkeD ChaSsiS Send a message via Yahoo to crACkeD ChaSsiS
Default pro4 shaft
will the pro4 shaft fit on a tc3/vice versa?
crACkeD ChaSsiS is offline   Reply With Quote
Old 02-04-2005, 04:34 PM   #10000
HPI doesn`t make one ..Yet... but TECH Racing Has a STRAIGHT CARBON Chassis set for the Pro4 that might be worth looking into
-Dave
Old 02-04-2005, 04:35 PM   #10001
Default Re: pro4 shaft
Nope too short
Old 02-04-2005, 04:40 PM   #10002
Default aww
dang it
Old 02-04-2005, 09:13 PM   #10003
azenis's Avatar
can anyone recommend a good setup for asphalt, for rubbers or foams, that will suit a track made up mainly of hairpins connected by short straights only about 5 meters long?
Nige
X-Ray T4 '14 | 3Racing Sakura D3 CS | Durango DEX410v4 | HPI Blitz | Tamiya WR-02 VW Bus
azenis is offline   Reply With Quote
Old 02-04-2005, 10:22 PM   #10004
ChameleonFB's Avatar
Thats very short. Try using 2 degrees caster hub. for off power cornering.
ChameleonFB is offline   Reply With Quote
Old 02-05-2005, 03:50 AM   #10005
Exe
Exe's Avatar
Send a message via ICQ to Exe Send a message via Yahoo to Exe
can someone tell me what's the difference between usual hpi chassis and tech racing straight chassis ?
Exe is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
