Old 02-01-2005, 01:01 PM   #9931
J-P
J-P's Avatar
stewertfan20,
yeah they are, give it a try and let me know how you get on!
J-P
J-P is offline   Reply With Quote
Old 02-01-2005, 01:13 PM   #9932
StewartFan20's Avatar
Originally posted by J-P
stewertfan20,
J-P
I will give it a try tomorrow night.
Devil Dog Racing | HobbyTown USA (Kansas City,North) | Fastlane Raceway | Matrix Tires
Someday, I hope to be the man my dog thinks I am.
StewartFan20 is offline   Reply With Quote
Old 02-01-2005, 05:23 PM   #9933
Send a message via Yahoo to nomaak
i agree with j-p. the stock set-up was near PERFECT ( for my driving style) on asphalt. and this was on a non-preped, un-even track. all i did was reset ride height for scrapping, put on fresh take-off 27's, and servo-taped two quaters on the rear of the chassis. (in front of the front-rear pivot block). the car felt so good that i hated it was carpet season. this was unusual for me cause i LOVE the carpet! i can't imagine how well this car is gonna work when the temp gets above 50 degrees F.
BTW...can anyone recommend a rubber tire that rivals or near surrpasses a foam tire on low-bite carpet? thanks.
nomaak is offline   Reply With Quote
Old 02-01-2005, 05:26 PM   #9934
macnkitty2002. i would love to visit your track sometime.is there a website i can go to to get more info and possibly directions?
Old 02-01-2005, 05:33 PM   #9935
macnkitty2002's Avatar
nomaak-i see you live nearby. it would be awesome if you could visit my track sometime during the season. we begin racing sometime in march and go through november. we race every first and third sunday of each month during the season, and the turnout is usually good. the dominant force at my track is the nitro tc's, which i race, and soon i will race a pro 4 in the electric class. our electric class is a little less serious unfortunately, i race my mini-t in it and some other micros and electric 2wd trucks race aswell. though they are slow and i am sure that you will be able to surpass them. there are about 3-4 serious tc racers in the class that you can compete against. the website for my track is here:
www.vorra.org
i think the directions are there.
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 02-01-2005, 06:10 PM   #9936
tc3 racer sc's Avatar
hey answer ur phone nomak trying to cal you dude
tc3 racer sc is offline   Reply With Quote
Old 02-01-2005, 06:13 PM   #9937
Default what going to be the set up for pro4 at the snowbirds
what going to be the setup at the birds nxt week will be the andy moore set up or thad set up to start up let hear it guys i will be lvng saturday me and the wife hang around till check in on sunday
Old 02-01-2005, 06:22 PM   #9938
ooops! ringer was off.
Old 02-01-2005, 06:41 PM   #9939
nomaak-what ya say about racing at my track? if interested let me know.
Losi Rock Rey
Old 02-01-2005, 06:50 PM   #9940
Default out drives
Any one know what the weight of the Delrin out drives and stock out drives are thanks
Hacksavv is offline   Reply With Quote
Old 02-01-2005, 09:15 PM   #9941
StewartFan20 the o ring or the foam increases the pack of the shock which gives you better rebound and keeps the bladder from inverting into the cap and that keeps the shock more consistant
from what I've read and gotten from fellow racers more pack quicker rebound ,lesspack slower rebound
also you need two O rings inthe cap to equal the thickness of the foam spacer.
sportracer is offline   Reply With Quote
Old 02-02-2005, 12:09 AM   #9942
Send a message via AIM to Proteus
I was running two o rings but found that my car became to unstable though chicanes. However I did find a sweetspot with one O ring and foam.
Proteus is offline   Reply With Quote
Old 02-02-2005, 02:54 AM   #9943
Default spur gear stripping and shimming the spur gear shaft?
I've stripped my spur gear last weekend.. so i bought a new spur gear and installed it and took my car to the track again today.. and guess what? i strip the spur gear again after only 5 laps or so!!!???
Both time, only half the spur gear (approx 180degree) was stripped while the other half was almost perfect. I noticed that the shim on the spur gear shaft (don't know if it's the right name, but it's the metal shaft that the spur gear is attached to) was bent quite a bit...and one of the shim is sitting half way between the slot between the two bearings. Probably my fault that i didn't place the shims correctly when i put the gearbox back together after maintainence. Would this be the reason why i keep stripping half the spur gear? if not, what is it? i don't really want to keep buying more spur gears even they are not very expensive.
i was using the same spur gear (stock one) and pinion gear (64pitch 34 teeth) for quite a while with no problem until last weekend.
another thing, in the manual, it ask us to put 3 8x10x0.2mm washers between the two bearings on the spur gear shaft.. and i notice there is still quite a bit of play after that... so should i add more shims to make it tight? and should i do the same thing to the front gear box? i've already adjusted the backlash of the ball diff gear and the front one way so they both sitting tight (but not too tight) in the gearbox. any help would be really appreciated.
yellow15 is offline   Reply With Quote
Old 02-02-2005, 03:08 AM   #9944
Merciless's Avatar
Send a message via ICQ to Merciless
Default Re: spur gear stripping and shimming the spur gear shaft?
check the building of those shafts again m8, as when i finished mine there is no play all all. If anything i'd say the fit is alittle on the tight side and i can't imagine there quality control is such that it could ever get from tight to needing more spacers !!
You have got the purple shims on there as well as the washers haven't you ??
As for spacing the pinion and spur. A friend showed me a really easy way to get that perfect every time . Just put 1 size bigger than you want to use on the motor. Tighten the motor up with the pinion tight on the spur. now instal the pinion you wanted to use !! PERFECT mesh !! (64dp only)
Merciless is offline   Reply With Quote
Old 02-02-2005, 03:14 AM   #9945
the play on the rear input shaft is only less than 1mm.. and when i put the ball diff in, then there is actually no play at all.
so is it normal?
the purple shims? that's the two about 3mm thick or so which a bearing is sitting in between right? or is that something else you are talking about?
