Old 01-31-2005, 07:45 AM   #9901
Company Representative
Tres's Avatar
R/C Tech Charter Subscriber
Trader Rating: 14 (100%+)
I had my first breakahge on my car this weekend....
Front c-hub
It should have broke WAY before that, but is a tank!
That is one of the great things about the car.
Less breakage = more finishes and you have to finish to win!!
Tre's
TnT-Fx Custom Graphics
www.tnt-fx.com
Tres is offline   Reply With Quote
Old 01-31-2005, 08:17 AM   #9902
Exe
Exe's Avatar
Send a message via ICQ to Exe Send a message via Yahoo to Exe
this is too difficult
just buy this nut with bolt and replace the hpi one.. works perfect, no cutting, nothing.http://www2.towerhobbies.com/cgi-bin...p?&I=LX2869&P=
Exe is offline   Reply With Quote
Old 01-31-2005, 08:21 AM   #9903
Tres's Avatar
doesn't the "T" on the T-nut bottom out?
That is the reason for cutting the slots in the diff housing.
Tre's
www.tnt-fx.com
Old 01-31-2005, 08:25 AM   #9904
Nipple's Avatar
Can I fit the AE nut into the original HPI T housing?
Nipple is offline   Reply With Quote
Old 01-31-2005, 08:28 AM   #9905
Exe
Exe's Avatar
you don't have to cut anything, you buy this team associated bolt with nut for 1.9$ and directly change it. This white nut is better, because it has more plastic and hold better, so it will not loosen when you driving.
Old 01-31-2005, 08:31 AM   #9906
Nipple's Avatar
OK.
Thanz a lot.
Old 01-31-2005, 08:32 AM   #9907
Nipple's Avatar
BTW Tres, can you guys do face plate for the new APS Dyno-charge.....
Old 01-31-2005, 08:37 AM   #9908
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
Originally posted by Merciless
Humm, i got to have a quick spin friday night with mine.
Followed the Andy moore set-up baring the pistons which i used hpi No.4 at the front and No.2 on the rear with 60wt ass. oil fr and 50wt rear.
The car ran very flat through the corners but pushed terribly and i had to ease off through the sweeper and also to get through a number of the corners i can normally take flat out.
Sticking with the Hpi pistons i think i'll have to at least go down 10wt front and rear and also reduce the spring rates to say 25lb front and 20/22 on the rear.
I don't know if you guys have any better ideas but the car just suffered with a lack of turn in and also wouldn't hold a line through the corners either washing out each time. It was balanced though just didn't steer well enough on our track.
thats called pushing dude
floodo1 is offline   Reply With Quote
Old 01-31-2005, 08:43 AM   #9909
Tres's Avatar
Nipple: they are on the way...
drop me an email, I don't want to hijack the Pro thread...
tres@tresleoanrd.com
Tre's
www.tnt-fx.com
Old 01-31-2005, 08:53 AM   #9910
Trader Rating: 36 (100%+)
just buy this nut with bolt and replace the hpi one.. works perfect, no cutting, nothing.http://www2.towerhobbies.com/cgi-bi...I=LX2869&P=
this method works really well. i have my diffs built up this way and have never had any of them go bad. several of the people in the area running pro4s built their diffs this way also with zero problems.
like the post stated...just replace the HPI bolt, nut, and spring with the AE parts.
What hop-ups would you guys (and girls) recomend getting...I know that skill is better than any hop-up...but I still want my car to look cool
jhigga15
these are things i would recommend getting....they will help you tune the car better...
Pivot Block Spacer #75144
Spring Set #75175
Pivot Blocks - get some of the ones that didn't come in the kit.
Aluminum Washer 3x6x .75 or 2.0 or 3.0
Ball Diff #75141
C- Hubs - get optional ones that didn't come with kit
these pieces should help you test different setups or copy setups posted on the web.
if you're looking for purple aluminum pieces i would buy the camber link pieces and maybe the aluminum heatsink/motor mount.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 01-31-2005, 09:20 AM   #9911
Send a message via AIM to Proteus
Default RACE REPORT
Just wanted to let all you Pro4 drivers know:
This past weekend we had our annual Mid Atlantic Carpet Clash at www.rctrack.com. Competition was pretty tough. We had close to 60 drivers. Top 5 or 6 were all seperated by about 4 sec or so. I had trouble during the first two qualifers. I was having some serious glitching problems. First qual....I only did 3 laps and pulled it. 2nd qual, I kept getting glitches but only at the far ends of the track and occasionally in the infield. Now the pressure was on for the 3rd qual. You talk about being nervous!!!! I managed to put it deep into the A at the 3rd position. I had the run of my life. The A main was filled with many sponsored people. I think there were only 3 or so people not sponsored.
Thanks to Fukuyama and EAMotorsports for the power. I needed all that I could get as many of the people in the show were all running Express motors....very fast. I finally got my car to where I wanted it. This setup should be very close to Snowbirds setup....hopefully.
Jeff B
Proteus is offline   Reply With Quote
Old 01-31-2005, 09:51 AM   #9912
Jeff Werner's Avatar
Send a message via Yahoo to Jeff Werner
Well I too ran what I thought was the Moore carpet setup...I noticed later that I did not have the correct or equvilant pistons. I was running #3 in the rear...someone told me to run #1 instead. What characteristic will I get going from #3 to #1 on carpet?
Thanks for any input.
Jeff
Jeff Werner is offline   Reply With Quote
Old 01-31-2005, 10:09 AM   #9913
purplepro3's Avatar
Default Box/Kit setting
Can anyone tell me what to expect with the stock kit setting for the pro4. I had mine built 6 months ago but never had time to run it. Thanks.
purplepro3 is offline   Reply With Quote
Old 01-31-2005, 10:12 AM   #9914
Tres's Avatar
box stock is not bad at all...
very easy to drive.....
However, I did pick up and .5 sec per lap with some Eli help..
Tre's
www.tnt-fx.com
Old 01-31-2005, 10:28 AM   #9915
NVisible's Avatar
i see a lot of pro4s with a good deal of the shaft drive worn away, from what i believe is part of the steering. Is this unavoidable or something a little tweaking or proper setup can avoid?
NVisible is offline   Reply With Quote
