Like Tree5Likes
Old 01-30-2005, 09:26 AM   #9886
Merciless's Avatar
Send a message via ICQ to Merciless
Originally posted by Nexus
merciless
This was previously posted on the Pro4 forum by Erik S. designer of the Pro4....
"The settings (steering) go in this order from most aggressive feel to least aggressive: 1, 3, 2, 4.
1 and 2 are with the slanted edges of the plate facing forward, and 3 and 4 have the slanted edges pointing to the rear. The main difference is that 1 and 3 have a lot of initial steering, but 1 has more steering at full throw. 2 and 4 will calm down turn in quite a bit, possibly even causing understeer."
Thanks man exactly what i needed to know.
Merciless is offline   Reply With Quote
Old 01-30-2005, 10:15 AM   #9887
lee
I just got a Pro 4. Where is the best place to order parts. I want to get some of the pivot block and spare parts.
lee is offline   Reply With Quote
Old 01-30-2005, 10:47 AM   #9888
trueracefan's Avatar
Send a message via AIM to trueracefan
KThobbies
http://www.kthobbies.com
trueracefan is offline   Reply With Quote
Old 01-30-2005, 01:14 PM   #9889
J-P
J-P's Avatar
merciless,
Run the tamiya number 3 pistons today at west london, found them to be real nice and smooth, used 50w losi oil in the front and 40w losi oil in the rear and found the car to to be really good with a little drift /loose on the rear with is good there as it helps using the power to "steer" around the corner. will get some orion oil soon as thats what andy moore said to run. some one said that the tamiya pistons are better because they are machined and not moulded like the pro4 ones.
J-P
J-P is offline   Reply With Quote
Old 01-30-2005, 03:24 PM   #9890
Merciless's Avatar
Originally posted by J-P
merciless,
J-P
Humm, i got to have a quick spin friday night with mine.
Followed the Andy moore set-up baring the pistons which i used hpi No.4 at the front and No.2 on the rear with 60wt ass. oil fr and 50wt rear.
The car ran very flat through the corners but pushed terribly and i had to ease off through the sweeper and also to get through a number of the corners i can normally take flat out.
Sticking with the Hpi pistons i think i'll have to at least go down 10wt front and rear and also reduce the spring rates to say 25lb front and 20/22 on the rear.
I don't know if you guys have any better ideas but the car just suffered with a lack of turn in and also wouldn't hold a line through the corners either washing out each time. It was balanced though just didn't steer well enough on our track.
Old 01-30-2005, 03:26 PM   #9891
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by trueracefan
KThobbies
Ditto
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 01-30-2005, 05:08 PM   #9892
Company Representative
Tres's Avatar
R/C Tech Charter Subscriber
Trader Rating: 14 (100%+)
JDM_DOHC_SiR : drop me an email.....
Tre's
TnT-Fx Custom Graphics
www.tnt-fx.com
Tres is offline   Reply With Quote
Old 01-31-2005, 02:44 AM   #9893
got a question about the pinion gear for Pro4
on the manual, it says we can only use the "HPI Racing pinion gears" and cannot use the "HPI pinion gear", whats the difference and why i can't use the "normal" hpi pinion gear?
is that i can use any brand's 64pitch pinion gear when using the stock spur gear?
yellow15 is offline   Reply With Quote
Old 01-31-2005, 02:47 AM   #9894
azenis's Avatar
i have been but not been having much luck...
Originally posted by tony2
do any of you guys run your pro4 on asphaly with foam tyres?? if you got any setups, i have a set up for a track sprayed with VHT but i need one without VHT
Nige
X-Ray T4 '14 | 3Racing Sakura D3 CS | Durango DEX410v4 | HPI Blitz | Tamiya WR-02 VW Bus
azenis is offline   Reply With Quote
Old 01-31-2005, 03:16 AM   #9895
tony2's Avatar
yellow -
Mate i think the HPI pinions are 48 pitch, and the racing are 64 Pitch. if you change the spur to 48 there is no reason that you cant you HPI normal pinions
tony2 is offline   Reply With Quote
Old 01-31-2005, 05:21 AM   #9896
Geetoo's Avatar
Send a message via AIM to Geetoo Send a message via Yahoo to Geetoo
The HPI pinion gears are the old version pinions that have thicker backing, it actually won't fit the pro 4. Aftermarket pinions will do
www.hpiracing.com
www.hotbodiesonline.net
www.nosram.com
www.team-durango.com
www.actionhobbiesonline.net
Geetoo is offline   Reply With Quote
Old 01-31-2005, 05:43 AM   #9897
Nipple's Avatar
I'm just wondering if any of you guys has problem with the rear diff screw. I kept breaking my........
Nipple is offline   Reply With Quote
Old 01-31-2005, 06:09 AM   #9898
jhigga15's Avatar
What hop-ups would you guys (and girls) recomend getting...I know that skill is better than any hop-up...but I still want my car to look cool
jhigga15 is offline   Reply With Quote
Old 01-31-2005, 06:21 AM   #9899
tel
Nipple,
Yes, the diff screws easily break and the rear diff tends to loosen as you race. To avoid breaking them using a very small diameter screw driver when tightening the diff and go slowly.
The real fix is doing the TC3 diff mod. Buy a tc3 diff rebuild kit (Associated part #3926) that includes the screw, spring and T-nut. You can use the thrust plates and balls if you want but they are slightly smaller than the metric HPI parts. Modify the diff halves and assemble as in the picture.
I didn't make the pic and I don't remember who did. Many props to the guy that did.
Travis Lewis
Team Kyosho, Orion, KO Propo America, Avid RC
tel is offline   Reply With Quote
Old 01-31-2005, 06:34 AM   #9900
Nipple's Avatar
Originally posted by tel
Nipple,
Thanz........maybe I'll try Tamiya ones. They are metric size so I dun have to change much stuffs.
