Hpi Pro 4
#9826
ok i found the reason!
it was the tyres. His tyres got a larger diameter than mine so i tried some new tyres which is the same size as his and we are dead even now
so.. anyone got a setup for outdoor track with foam tyres?
#9827
Originally posted by yellow15
Ok finally found the TC3 T nuts and bolt and looks like it fixed my problem!
#9828
I thought that Hara was supposed to be at the birds. I was just browsing the entry list and didn't see any HPI drivers except for Andy. I wonder if they are able to get their entries in on time.
#9829
thanks for the reply guys.(sry for the repeat posts) but NOBODY has replied about indoor carpet. i "wanna" run indoor carpet with plaid fronts/purple rears. i've played with this car for over a month. i'm having a hard time getting this thing to work. people say andy moore's set-up is good but i disagree. i'm on a tight track that allows NO traction compound. surely somebody can help.........i'm about to trade this thing out.
#9830
I would go more for a setup like they use for rubber tires on carpet. A little softer and more droop. I've yet to see situation where the Pro 4 didn't work. Try something along these lines and let us how it works, or excatly what the car is doing that you don't like (i.e., loose into the corner, push out of the corner, etc):
http://www.hpieurope.com/graphics/se...re_DHI2005.pdf
http://www.hpieurope.com/graphics/se...witzCarpet.pdf
#9831
Hey Pete - have you tried the Ezrow setup someone posted a few pages back? I followed it exactly except the front Springs...I ran Associated yellows.
Seems way more planted at the Wood than the Moore setup was.....I was running 10.9 - 11 flats and on the TQ pace in the 3rd round until I broke after hitting Chris J. when he spun in front of me.....
Oh yeah.....put a diff in the front!!!
#9832
jt6...thanks bro! no i don't have that set-up. do you mind postin or pm'ing it?
#9834
#9835
#9836
#9837
Hi,
I bought a version 1.1 pro4 kit a while ago from Hong Kong and it seems to have a dud rear differential.
I built the diff exactly how the manual says except i used ceramic balls. When i was finished I rotated the two outdrives in opposite directions and it wasn't smoothe like you would expect. It had a high spot where the action would be tight then you would pass it and it would be loose. Basically it had inconsistent action. At that time I just ran it hoping that it would get better but it didn't.
The ceramic bearings eventually wore out and the diff clicked so i changed to the standard diff balls. There was no more clicking but the action still had hard spots every revolution. This is not the drivetrain action binding but occurs when the diff is out and you just turn the outdrives.
The car has been handling badly for a while and i think the diff may have some part to play in this.
I got annoyed at the car and decided to rebuild it. This time i tried many things to try to fix the diff.
At first i thought it was the spring and screw so i changed them to tamiya ones but he action was the same. Then i changed the gear itself, but again it was the same. Then i thought it may be dodgey outdrives. So i bought some more carbon one and a delrin set.
I was wrong, even with the delrin outdrives the diff still had the same problem. I changed every other part of the diff such as the bearings and nut etc. The last thing to change was the diff plates.
I put in new plates but yet again the problem was not solved. I was talking with my dad and he looked at the plates to find that they were warped, on a flat table they could be rocked. This must be the problem. I checked my other 3 spare plates and found that they were warped also and as expected they all made the diff bad.
Has anyone else come across this problem and found a solution? At this point i will have to buy a whole new diff and hope it works.
The other problem i had was the diff coming loose all the time, i read about it on this forum but have only tried to replace the nut without much luck. Something interesting i found was that my rear right universal was very warn on the end of the T section where the diff outdrive is. This is an unusual place for wear and none of the other universals had even a scratch near that area (the very end). My therory is that the universal was rubbing against the diff screw and undoing it (its the right direction). What i have just done is cut the end off the crew enough so that it still sticks out of the nut but hardly as far. Im hoping this will fix the problem, i will find out friday.
Can someone else please check their universal to see if they have the same problem, as this may be the reason for the undoing of the diff.
I also found another problem lol, when i put a HPI spool diff into the front the wheels vibrated badly when at full steering lock. On the track it made the car spin out all the time and very hard to drive. I put lots of grease like the manual says but still have the problem, my friends also does the same thing. But my other friends with the Titanium racing spool didn't. Could this be the delrin outdrives fixing the binding problem?
sorry for the long post but thanks for your time.
Gerard
Gerard
#9838
regg...i really don't see where you have room to crack..you didn't race your car for MONTHS!!! "naw...it's not ready yet....naw, it's not ready yet.." yo....gimme some slack! at least i raced mine as soon as it was built. can't say it's too bad tho. 2 tq's and a track record. not bad for a car outta tha box.
#9839
well guys just got back from the summer nats here in aust. any way surikarn and muria(the pro 4 designer not sure of spelling) were out here having a play. surikarn won, but only casue he had the best cells! no he is prity damn good, but i learnt a couple things about the car like the shims of the diff anyway those hpi/HB guys are top fellas
#9840
hope something works out for you.
do yourself a favor and build the diffs up with a AE TC3 screw and t-nut...then just a dab of locktight on the end of the screw before you tighten it up....works awesome.
tony2.
any pics or links to images of that race with surikarn?
