Old 01-23-2005, 08:27 AM   #9796
PMR
For a free drivetrain it should spin for about 8-9 seconds by hand.
For the meshing to be its quietest you should use Kimbroughs spurs which has a softer material than other brands.
PMR is offline   Reply With Quote
Old 01-23-2005, 08:44 AM   #9797
Company Representative
Tres's Avatar
R/C Tech Charter Subscriber
Trader Rating: 14 (100%+)
They are correct...
My Pro4 out of the box was as free as a TC3 that has been "blue printed"
Don't know about the dead fly, but they are very quite....
Shhhh, you hear that...That was a pro4 passing....
hang on, there it is again....
Tre's
TnT-Fx Custom Graphics
www.tnt-fx.com
Tres is offline   Reply With Quote
Old 01-23-2005, 09:48 AM   #9798
Default Thanks for Answering....
8-9 seconds that's a LOT!!
My evo3 SL I have at the moment doesn't spin more than 2-3 secs and my bearings are fine...
I guess it's all about how you manage to get the bevel gear/diff gear correctly meshed...if I get this right (I hate being french sometimes..) a good MESH is when the gears aren't too tight nor too loose, is that correct?
AGAIN,Thanks for the help!!!!!!!!!!!!!!!!!!!!
Tbevofreak is offline   Reply With Quote
Old 01-23-2005, 11:32 AM   #9799
Skill's Avatar
Basically its the same principle as the spur and pinion mesh, you want some play, but really, as little as possible.
Skill is offline   Reply With Quote
Old 01-23-2005, 12:45 PM   #9800
AMGRacer's Avatar
Default Re: Before Buying PRO4...
Originally posted by Tbevofreak
Hi,
I'm new to this forum I'd like to know if The pro4 has any STRIPPING problem since it's a shaft drive car
I have a EVO3 Surikarn an this was a BIG problem with the car so I don't want to go thru all the shimming again
Does the pro4 needs any shimming?
Thanks for answering!!!
Yes you can strip the front bevel gear, I have eaten two of them. My front diff is properly shimmed but if you hit a wooden barrier with an 8x1 with throttle on you can will break a bevel gear. It depends on the track barriers and how much you hit them.
AMGRacer is offline   Reply With Quote
Old 01-23-2005, 02:12 PM   #9801
Default Free drive train
Hi!!
Do you guys all manage to get 9-10 secs of free spinning with your drivetrain, using stock bearings??
I know the pro4 has are very efficient drive train but I thought that to get that much spinning you needed the team drivers kit or ceramic bearings......is it just how you manage to get the proper mesh??
THANKS!!!!!!!!!!!!!!!!
Old 01-23-2005, 02:28 PM   #9802
AMGRacer's Avatar
Default Re: Free drive train
Hi!!
Built right with a little running on the kit to free it up a bit mine spins for 7-9 seconds with a bone stock kit. This car is awesome from the box.
Old 01-23-2005, 03:18 PM   #9803
Mal
Registered User
I'm sure it all depends on how hard you spin the tires, the weight of the tires, the mesh of the gears and if you cleaned the grease of the bearings. . One person's 8 seconds maybe better than another persons 8 seconds. There are lots of variables.
Mal is offline   Reply With Quote
Old 01-23-2005, 04:04 PM   #9804
scoobydo's Avatar
Yeah Seriously!
Are you Counting "One.. Alligator, Two..)
Or
You actaully having somebody run a stop watch for you?
It all depends. One mans 8 seconds is another mans 5 alligators!
scoobydo is offline   Reply With Quote
Old 01-23-2005, 07:16 PM   #9805
Send a message via Yahoo to nomaak
Default pivot blocks
is anyone here still racing with the stock pivot blocks? or have you changed to 0 in the front and 2 in the rear. i think the stock 2.5 is too aggressive for the front. why would a company distribute a car with parts in it that are utterly useless to the average joe? and what's with the front one-way? NOBODY YSES THIS STUFF!!!!
nomaak is offline   Reply With Quote
Old 01-23-2005, 07:17 PM   #9806
is anyone here still racing with the stock pivot blocks? or have you changed to 0 in the front and 2 in the rear. i think the stock 2.5 is too aggressive for the front. why would a company distribute a car with parts in it that are utterly useless to the average joe? and what's with the front one-way? NOBODY USES THIS STUFF!!!!
Old 01-23-2005, 07:17 PM   #9807
Old 01-23-2005, 07:18 PM   #9808
Old 01-23-2005, 08:25 PM   #9809
Mal
Registered User
90% of the world races on rubber tires. A one-way is still one of the ways to get a rubber tire set-up even faster. I race with a one-way in my car most of time on carpet and outside on asphalt.
Old 01-23-2005, 08:31 PM   #9810
Trader Rating: 36 (100%+)
i am running the 2.5 block up front and my car steers nicely w/ rubber tires on carpet......both diff and oneway depending on the layout.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
