Like Tree6Likes
Old 01-19-2005, 01:12 PM   #9766
JohnB's Avatar
R/C Tech Charter Subscriber
Default Re: Shock dampening
Originally posted by StewartFan20
What has the bigger impact on shock dampening? Piston hole size or oil weight?
I'd say both. The piston hole size has to do with "pack". That is the speed which oil can travel through the holes. When it reaches a certain speed it almost locks up. I think that comes into play more in off road and jumping, but it effects on road as well.
You need to keep in mind the weight of the shock spring and dampening of the shock must be close or when you find a combination you like try to maintain it. If you go to heavier springs, you probably need to increase you dampening as well. It all plays together.
Not sure on HPI pistons, but when I ran Associated one piston size to the next was approximately 5 wt. of oil change. So if you went from a #2 to #3 piston you drop down 5 wt. in oil to have the same dampening effect. HPI pistons seem a little closer together between hole size so I would guess maybe only 2-1/2 wt. of oil between, but I'm sure, maybe Eric can answer that.
take care
john
JohnB is offline   Reply With Quote
Old 01-19-2005, 01:16 PM   #9767
JohnB's Avatar
Originally posted by Kevin K
I have the Futaba 9550 its great and the extra room it gives you lets you mount your electronics anyway you want.
Kevin, how is the speed of it? I think the 94357 I'm running now is .07 or something like that.
take care
john
Old 01-19-2005, 02:15 PM   #9768
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
The Speed is fine....its .11 plenty fast IMO. Surikarn(sp) used it to win the worlds so it cant be that bad. Its very good servo and the best that I have used so far.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 01-19-2005, 02:40 PM   #9769
I also run the 9550 in my pro4 and I absolutely love it. It seems faster than the specs imply, when you're driving. It's been rock solid since day one. It hasn't developed any slop at all. In fact I've never even removed it from the car.
Bodido is offline   Reply With Quote
Old 01-19-2005, 02:48 PM   #9770
JohnB's Avatar
Agreed, that sounds plenty fast, thanks
Old 01-19-2005, 04:44 PM   #9771
Twin-Kyle's Avatar
Futaba S9451....Works GREAT!!!
Twin-Kyle is offline   Reply With Quote
Old 01-19-2005, 05:07 PM   #9772
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
9550 is super popular. its proven to work in pretty much all cars, by TONS of people.
but tamiya drivers as a whole use it a LOT due to the space it saves them. surikarn, jacobsen etc
floodo1 is offline   Reply With Quote
Old 01-19-2005, 08:21 PM   #9773
Pro4's Avatar
Surikarn is a HPI man now!
Pro4 is offline   Reply With Quote
Old 01-19-2005, 08:46 PM   #9774
cooliomojo-CEBU's Avatar
have some problems getting the ball bearings to fit the ball dif..... is this a common problem? it seems that the drive axle is too big. or is it the ball bearings being too small? need help....will use car by this weekend.
cooliomojo-CEBU is offline   Reply With Quote
Old 01-20-2005, 06:34 AM   #9775
Default HELP
I need some help. I can not get the front end of the car to lower. The shock collars are all the way down. I'm running them 3 hole out on shock tower and in on arm and losi whites. The back no problem.
tqboy is offline   Reply With Quote
Old 01-20-2005, 06:57 AM   #9776
jt6
jt6's Avatar
Send a message via ICQ to jt6 Send a message via AIM to jt6
You do mean that the shock collars are all the way up right??
How big are your tires?
jt6 is offline   Reply With Quote
Old 01-20-2005, 07:00 AM   #9777
Default HELP
Yes shock collars are alll the way up. I'm running rubber. The backs are fine but the front I can not get it to go less than 7mm for height.
Old 01-20-2005, 07:00 AM   #9778
Juzzie's Avatar
Default Re: HELP
The ring on the shocks that rotates on the thread, is meant to be a the top for the car to sit low. it is only meant to be heading towards the bottom, if you are trying to raise the car.
Juzzie is offline   Reply With Quote
Old 01-20-2005, 07:06 AM   #9779
Juzzie's Avatar
rubber tyres should be at around about 62 - 63mm rolling diamater.
the shock mounting position should be on the outer on the bottom, and on the 2nd outer on the top.
Apart fromt his, if you have done this, then you need to shorten the linkage arm that adjusts the camber. and recheck the droop settings. 6 at the front, and 5 at the rear is a consistent setting for me.
Old 01-20-2005, 07:44 AM   #9780
floodo1's Avatar
i know im just talking about when he ran tamiya
