Hpi Pro 4
#9691
The Evicerator
How should I gear when using a new diff as opposed to an old one?
#9693
#9694
Don't know whether i'm just back luck, or it's just me but:
Tried that and snapped the center screw
tried that and guess what!!! i'm so lucky that even with only 10% chance, i snapped the center screw (again!)
Yes i think i know it now
and my final question:
How should I gear if i've two HPI stickers on the chassis?
3.) Hold the left rear tire and gradually feed in some throttle. Do this for 5~10 seconds. Do NOT use more than 1/8th throttle.
7.) Now, try to rotate the right rear tire. If it slips (rotates at all), your diff is too loose and needs to be tightened. Caution: if you try to use too much force on a properly tightened diff, you can cause the bevel gears to jump teeth (you will hear a popping noise, scary, but 9 times out of 10 causing no damage).
Note: You can set your diff looser than this, but this is always a good starting point and you can then tune to taste. If your diff is too loose, you will melt and/ or break parts.
#9695
can a spool be made to work on a tight carpet track? tha one-way is just too much. i can't get a consistant "feel" in the car so i glued the one-way up. with all the problems i had my first time with the car...i must say that it is very durable. the only thing i broke was the servo case. (not gears) i think my servo-saver was too tight.
after taxes i plan on getting more speed parts and tires for it. of all the tracks i've visited and raced..all the top drives said to use jaco plaid/purples. first get the tires, then work on set-up. i've been using "nitro" tires with varied succes. ($15 a pair as apposed to $22 a pair) but sometimes ya just gotta BUY speed. LOL
#9697
Originally posted by jt6
Hey Pete, if you try the spool let me know how it works!
#9698
I also experience loosening of the diffs. It started out in the rear then I started experiencing the same in the front. Already had 2 races wherein I was running 2nd or 3rd place. Every after final heat run, I inspect the diff and find that it is becoming loose. I therefore tighten every after a run. In the last final heat, am still running 2nd or 3rd then suddenly the center diff screw head breaks and makes me DNF the last final heat, thus dropping my standing.
Bought 2 new diffs, ceramic nitride balls, and Version 1.1 diff gears. B4, the suspect was that the lock nut was damaged. Hopefully with these 2 new diffs, I won't have the same problems.
I am very happy with the PRO4 - am one of those from our club that is sticking it out with pro4 and not shifting to XRAY - if not only for these diff problems.
My setting for diff tightening is simple.
Rear - tighten til it stops. go back 1/2 turn.
Front - tighten til it stops/ go back 1/4 turn.
I have a race tonight again for MOD - hopefully my new diffs work properly this time.
Question, with ceramic nitride balls, the diffs a definitely more plush and smooth. Do I follow the same tightening setting above? Seems too loose now - or is it just because it is smoother?
#9699
what the biggest gear i can run on 3.0 chasis
what the biggest gear and clearance i can run on a 3.o chasis also after many months of banging and get knock around i been breaking in the past 2 weeks a-arm and c-hubs but still love it
pete dont mess with the one way let the car come to you just be patience
#9700
Re: Moore's setup up
Originally posted by JohnB
On our track with Moore's setup I went to 2* caster block, Rear camber link at #2 in and out, and rear shock in one hole from outside (#3 maybe???) That really locked in the balance with lots of steering on and off power. That's with mod though. Stock might changes things a little.
I couldn't do the up-travel limiting though. Took away way to much rear bite. I can see how it would probably be good for big races where the traction gets so high, just not good for club racing.
take care
john
take care
john
#9701
Trader Rating: 32 (100%+)
Re: what the biggest gear i can run on 3.0 chasis
#9702
#9703
regg...too late bud. the oneway is epoxied shut. now i have a heavy spool. i've done this mod too ALL my rs4 cars and it helped a lot. let's see if i can make it 5 for 5.
spool on carpet is a bit difficult to hook uo but it's gotta be better than a one-way.
#9704
by "tighten till it stops" you mean using a normal screw driver and "normal force"? cos i can tighten it till it (the center screw) snaps easily with it stops
I think there is really something wrong with the diffs. Will let you know what happens to me tonight with my new diffs. With my old diffs, I even tried putting a very small drop of turbo glue in the lock nut but it still loosened and finally snapped the screw head off.
Dunno really why the design of the diff screw was made to be like that:
The screw head is big. Even the space where you put the screw driver is a bit wide. With a big screw head and a small bodt or neck, I think it is really prone to breaking off.
If you'd look at other car-makes, the center diff screw is small. The screw head is also a hex-type. Actually tried using the center diff screw of the ntc3. It fits but the length is a tad short for the lock nut to reach the screw threads.
#9705
Jhernandez,
A local at my track was having the same problem you are having with the diffs. He replaced the diff hardware with associated tc3 parts and has not had a problem since. It loosens because the diff catches on the screw and it just backs off when running.
