Like Tree5Likes
Old 01-11-2005, 09:39 AM   #9631
rc-zombies's Avatar
Originally posted by coastaltony
REVEREND
Any idea when HPI in the USA will have a spool available?
they have been available for over a month or 2 now...
Old 01-11-2005, 09:43 AM   #9632
Solara's Avatar
Trader Rating: 16 (100%+)
Originally posted by Erik Shauver
[RANT]
Tweak
First of all, how is this "tweak" being measured?
-MIP Tweak Station?
-X-Acto down the center + Lift method?
-4 corner scales?
-Track feel?
-"eyeball" method?
Second, how often do you maintain your car?
-Did you strip down the car and check that the arms move freely (especially after crashes, aluminum can bend easily i.e. pivot blocks)?
-Have you cleaned or inspected your bearings recently?
-Have you set your droop screws (With a gauge? Included or otherwise)?
-Are the gearbox screw holes loose (in the slightest, and there are 18 of them x 2) or stripped?
-Have you checked your steering for freeness of movement?
-Have you checked the entire steering assembly for freeness of movement?
-Are you using setup tools (camber gauges, ride height gauges, calipers, toe gauges, etc)?
-Do any parts show signs of wear or are visibly worn out?
Original Build-up…
-Did you CA the edges of ALL graphite parts (especially the shock tower edges where they meet the gearbox)?
-Have you balanced your car from left to right with additional weight? (Either a string method or Hudy balancing tools in the existing smaller holes on the chassis bottom side)
-Did you pinch all ball cups until you obtain free movement (Upper links? Steering links? Sway Bar Links?).
-Are your shocks built to the same length?
-Have you set your endpoints of steering for equal throw in both directions?
-Are the steering tie rods set to even lengths? With Calipers? With the “eyeball” method?
-Do you have a method to setting up your car (including the use of setup tools)?
-Did you tap the holes in the graphite parts? Did you tap the holes with screws? Were the screws going in at an off angle (not parallel to the axis of the hole)? Do you tighten the screws with “brute” force, or with finesse?
If you are experiencing a different left to right feel on the track, a half turn or so of droop in the rear can make all of the difference. If your car is on a 4 corner scale setup, you can see that very small turns on the preload collars make a very big difference to the corner weights. If your car is on a MIP type tweak station, for crying out loud adjust the pre-load collars until it evens out (There is no need for them to be equally set all the way around, overall balance is the key).
Tweak is an over used word in R/C…
Definition:
3 : to make small adjustments in or to <tweak the controls>; especially : FINE-TUNE
By definition it points to the end user… You need to find your root problem. If your setup gauges show that something is off, adjust until it is right (Fine Tune the droop, the pre-load collars, the weight distribution, link lengths, etc). If your car feels imbalanced, adjust until it feels balanced, regardless of symmetry (Fine Tune). If your car requires maintenance, put in the wrench time. Simply twisting the chassis in your hands does no good.
If you want to consider the intransitive sense, meaning something more like to pull; then the chassis is bending or straining abnormally. This is most often caused by stripped screw holes or screws that are overly tightened. Both of these can allow more than normal chassis plate movement or create binding points on areas that are supposed to float or move.
[/RANT]
Erick..........THAT, already printed as my TWEAK CHECK LIST....and after reading the first few lines, I have already gave up, in a good way, cause I think I will live with that little tweak and just drive, a perfect level setting on my Pro 4 2ill never get me to the A main, so that really doesn't matter for me, but, very educational to know HOW to check tweak.
However, I want to ask this....I am uisng the MIP tweak station and see my front has a little tweak on 1 side, to make the front balanced, like you mentioned, I coiled down the left coilover 1 extra round then coiled UP the right coilover 1 extra round....and THAT, made my front balanced...
But....the ride height of the front is differnet left and right....Is that something important? Or there is no perfect solution, I gain something but lose something deal...?
Still newbie in electric racing....need a lot of help, thanks Erick.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 01-11-2005, 09:49 AM   #9633
Solara's Avatar
Erik, REVEREND!
Any idea when HPI in the USA will have a spool and 2mm chassis available?
2mm chassis....
http://www2.towerhobbies.com/cgi-bin...?&I=LXHFL7&P=0
Solid front diff....SPOOL
http://www2.towerhobbies.com/cgi-bin...68&FVPROFIL=++
Old 01-11-2005, 12:31 PM   #9634
Setting the tweak with the MIP tweak station will ensure that you have equal pressure on the front and rear tires from left to right. Yes, your ride height may be a little off but thats because you're car's not equally balance from left to right. Adding some preload on one side and taking it away on the other side will equalize the weight on each tire.
Kdonks is offline   Reply With Quote
Old 01-11-2005, 01:25 PM   #9635
coastaltony's Avatar
Does HPI put out a carbon fibre main shaft? Part number?
Meucci pool cue collector
coastaltony is offline   Reply With Quote
Old 01-11-2005, 01:52 PM   #9636
purplepro3's Avatar
#31404
purplepro3 is offline   Reply With Quote
Old 01-11-2005, 02:51 PM   #9637
Thanks guys
Old 01-11-2005, 04:35 PM   #9638
robk's Avatar
Trader Rating: 22 (100%+)
Eli from Cleveland
Old 01-11-2005, 04:42 PM   #9639
Company Representative
Tres's Avatar
R/C Tech Charter Subscriber
Trader Rating: 14 (100%+)
robk: Thanks!
Tre's
TnT-Fx Custom Graphics
www.tnt-fx.com
Tres is offline   Reply With Quote
Old 01-11-2005, 06:02 PM   #9640
Send a message via Yahoo to nomaak
yes!!! very much appreciated!!!!!!
nomaak is offline   Reply With Quote
Old 01-11-2005, 06:42 PM   #9641
tony2's Avatar
my tweak is measure at the front of the chassis at the widest part. all i do is place the chassis on a peice of glass with the wheels off.
I tighten all screws on the top deck and chassis is perfectly flat, however if i twist the chassis with the smallest amount of effort, the chassis will hold the twist, and hence the tweak.
the car is brand new i have triple checked all parts, so it cant be that, but two other guys one a multiple national champ have the same problem,
i have a feeling it is the machineing of the top deck. because i can take the top deck off the car and it wont hold the tweak. but as soon as the top deck is screwed on.......
i have tryed to loosen individual screws to see if it is any particular screw that is causing it, all as i worked out that it is in the rear 6 screws.
any other suggestions??
tony2 is offline   Reply With Quote
Old 01-11-2005, 06:43 PM   #9642
tony2's Avatar
what would you guys think tghe advantage of the carbon main drive shaft over the alloy one is??
Old 01-11-2005, 08:26 PM   #9643
rc-zombies's Avatar
LIghter..and faster acceleration.
Old 01-11-2005, 08:33 PM   #9644
ghoppa's Avatar
Trader Rating: 50 (98%+)
just wondering about this car??????
how is it "right out of the box"? (for med size track, asphalt, rubber tires)
any nessesary "purchases" (hop-ups, additions) needed to be competitive??? (I run a TC4 right now....)
be honest.....
ghoppa is offline   Reply With Quote
Old 01-11-2005, 08:35 PM   #9645
I thought that I read some were about changing to asc diff parts?What is changed do you just change all the parts (diff screw t nut spring thrust washers balls ect ect to asc) or is there something else that I need to change
no1uno is offline   Reply With Quote
