Old 12-31-2004, 01:49 AM   #9451
Skill's Avatar
Default Re: Drive Cups
Originally posted by StewartFan20
Does anyone know if there are Delrin drive cups availible for the Pro4?
I would like to get away from the graphite ones. I have already broke two of them and don't want to by out drives just to get the drive cups.
Titanium Racing should be producing some delrin prop outdrives in the near future, I have had some on order for about 3 months now with no luck, but I'm sure they will come along.
If you go to www.titaniumracing.com and email them they will send you a pro 4 flyer with all their pro 4 products on.
Skill is offline   Reply With Quote
Old 12-31-2004, 07:50 PM   #9452
rcmike's Avatar
Trader Rating: 40 (100%+)
Default parts
www.allstarhobbies.com Is a good place
rcmike is offline   Reply With Quote
Old 01-02-2005, 08:26 AM   #9453
jt6
jt6's Avatar
Send a message via ICQ to jt6 Send a message via AIM to jt6
Question for anyone running the Andy Moore Cleveland setup.....
I downloaded the setup sheet but have noticed that the rear inner camber link position is blank. Any idea which one he was using? Just curious. I plan on trying both either way...Thanks.
jt6 is offline   Reply With Quote
Old 01-02-2005, 10:14 AM   #9454
tc3 racer sc's Avatar
Default finally broke after many runs/ banging
i just got to say the pro4 is a very strong car after about 4/5 mth of running outdoor/and carpet i finally broke a c-hub i hve hit many walls push into walls nver broke and i was running carpetalso im planning to chnge chassis to a 3.0 what the biggest spur i can put on
tc3 racer sc is offline   Reply With Quote
Old 01-02-2005, 10:15 AM   #9455
u can check a few pages bck i think eric post it
Old 01-02-2005, 11:45 AM   #9456
JohnB's Avatar
R/C Tech Charter Subscriber
Yes, I really like the setup, look back through the pages about week or a little more and it was discussed. I'm running a short link (outter hole on the inner mount). I think there's a post about a couple setting that weren't on the page though.
take care
john
JohnB is offline   Reply With Quote
Old 01-02-2005, 03:21 PM   #9457
jt6
jt6's Avatar
Thanks. I will go back and find them......
Old 01-02-2005, 03:23 PM   #9458
Default servo question?
In my Pro-4 I am using a GT7 ESC, and a JR 310S reciever. My servo is huge, what do you guys run for a steering servo that is small but still has good speed and torque?
csilve is offline   Reply With Quote
Old 01-02-2005, 03:58 PM   #9459
JohnB's Avatar
Default Re: servo question?
Should be standard servo size. I use a Airtronics 94357.
take care
john
Old 01-02-2005, 05:07 PM   #9460
Ya I figured it out. I had a JR 4750 servo in my old TC and when I figured out that it was causing glitching I switched it with a Hitec HS-605BB.
From the back of the mounting tabs to the back of the servo it measures 30mm and standard servos measure 25mm. I did not know this when I switched everything over to my Pro4. I removed the Hitec servo tonight and will pick-up a new one this week. I have looked at other Hitec servos and they all look like the same case size as mine. I am going to try another manufacturer, anybody have any suggestions?
Old 01-02-2005, 05:51 PM   #9461
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
Futaba S9550
same servo jimmy jacobsen runs on his tamiya to free up room. its only 1" in depth (the direction you have a problem with) whereas normal full size are ~1.6" (overall, including the part in front of the tabs). its really getting to be popular because it works well, and its very small, making room to keep everything on the chassis
floodo1 is offline   Reply With Quote
Old 01-02-2005, 07:26 PM   #9462
rc-zombies's Avatar
I'm running the Fut S9451 digital servo... std size servo should fit
and leave plenty of space for the ESC and Receiver. I ran the GT7 and have no problem with space... how big is your receiver?
Old 01-02-2005, 07:43 PM   #9463
rcmike's Avatar
Default Radio interference help
In my pro4, after i put electronics in,new servo 737,used Gt7,new synthesized airtonics reciev, at idle-no interference,give it power and just a very little frt wheels jiggle off and on,but just enough to notice it while looking at car. A fellow racer at my local track may think its the capacitor on the Gt7,said that if it got hurt in any way previously before, that the insides may be causing the glitch. I have done all the checks that i knew of but has anyone heard of the bad capacitor story on the GT7?? Thanks..Others at the track have their electronic in their pro4 the same way as me,but not necessay the same brand stuff.
Old 01-02-2005, 10:55 PM   #9464
hit is this the guy i tlk to at goldsboro yesterdy running pro4 in spec class how ru this is reggie
Old 01-03-2005, 01:35 AM   #9465
Ooj
Send a message via ICQ to Ooj Send a message via MSN to Ooj
Does anyone know what the difference between the standard lower arms spare part and the high traction set is?
From what I can see they are the same - the high traction arm set is just a bundled package pair of the standard set. Can anyone confirm or disprove this?
Ooj is offline   Reply With Quote
