Like Tree6Likes
Old 12-27-2004, 11:52 AM   #9421
Merciless's Avatar
Send a message via ICQ to Merciless
Default Re: Foam Tire Question
Originally posted by StewartFan20
I am making the leap from stock rubber to stock foam with my Pro4 and I have a couple of questions.
First, what size of tire do people start off with? Do I need to re-true the tires every so often?
Second, what is the minimum size of foam tire that can be used?
Third, Has anyone tried the Parma foams on the Pro4? I have read somewhere that he ID of the wheel is smaller that most wheels and I wanted to make sure that the wheel would fit? Also, will 28mm width fit?
Hope everyone had a Merry Christmas and have a Happy New Year!
Yes you should really be re-trueing the tires (i'd say every other meeting)
Alot of people true them to 60mm before even using them from new (but not me, thats to expensive)
Parma'f fit just great Cyan/Magenta works a treat 28mm
You should really stat working out your gearing as RollOut to as it changes dramaticly with tyre size
Merciless is offline   Reply With Quote
Old 12-27-2004, 12:10 PM   #9422
StewartFan20's Avatar
Default Re: Re: Foam Tire Question
Thanks for the info, this is a great help.
I have been looking for/developing a rollout chart. I was just curious as to the minimum tire size that can be used before the tires need to be thrown away.
Devil Dog Racing | HobbyTown USA (Kansas City,North) | Fastlane Raceway | Matrix Tires
Someday, I hope to be the man my dog thinks I am.
StewartFan20 is offline   Reply With Quote
Old 12-27-2004, 12:19 PM   #9423
JohnB's Avatar
R/C Tech Charter Subscriber
I use to be with the "run them full size" group. But now I cut all tires down to 59-60mm to start with. Usually a tire will chunk before you can run it down all the way anyways. The car just handles better. You may have some traction rolling issues with full size tires. You can run them clear down to nothing as long as they still handle good.
I just started using Parma's. They are 63mm new, so they definietly need cut. I think TRC's are 61mm new, don't remember what Jaco's are. So far the Parma's work find and no clearance problems. However I run my shock on the inner hole and haven't tried the outside hole with the tires.
Just put on Andy Moores' Cleveland setup and you'll be flying!.
take care
john
JohnB is offline   Reply With Quote
Old 12-27-2004, 02:30 PM   #9424
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Default Re: Heat Sink Motor Mount
Originally posted by sweet'n'sour
Hi guys and girls
I am wanting to know how many of you are using after market heat sink motor mounts and what are your thoughts on them ?
We run 27t stock outdoors in rather warm conditions at the best of times...
Cheers
Michael
Michael....I have the Heat Sink mount from Square and I have not had any issues with it so far. Does it keep the motor cooler I dont know as I have a fan on my motor so Im not sure how much cool it will keel the motor but every little bit will help.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 12-27-2004, 09:22 PM   #9425
StewartFan20
62mm /57mm is the optimium size to get the best results.You get what you pay for.You can run them big but the car has to much rotating mass.Check out this rollout chart
www.gearchart.com/index.cfm sneaky:
Barger is offline   Reply With Quote
Old 12-28-2004, 01:13 PM   #9426
Chrisgt2's Avatar
Send a message via MSN to Chrisgt2 Send a message via Yahoo to Chrisgt2
Where can I find the best/cheapest hopups for the Pro 4....???? Lookin for a set of purple screws, found nearly everything else....Speedtech is the only good place I've found
Hot Bodies Pro 5
*Sponsors*
Hot Bodies, Speed Passion, Team Scream Racing, Rockstar Paint
Franchise Racing Products
The Raceway - Beaver, PA
Chrisgt2 is offline   Reply With Quote
Old 12-28-2004, 01:19 PM   #9427
Aurra Sing's Avatar
All Speed Hobbies had a lot of Pro4 parts too
Aurra Sing is offline   Reply With Quote
Old 12-28-2004, 01:20 PM   #9428
seaball's Avatar
Send a message via Yahoo to seaball
has voganski joined the purple mafia? and will he be attending the novak?
- cball
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 12-28-2004, 01:24 PM   #9429
rc-zombies's Avatar
I don't recommend aluminum purple screws... they will break and give you alot of headaches trying to get them out... I highly recommend the Jwerks Ti screws... AllSpeed Hobbies has them in stock... the best Ti screws I've ever used. does not strip or break.
Old 12-28-2004, 01:29 PM   #9430
Chrisgt2's Avatar
I've never used anything but aluminum........I dont crash often so breaking isnt an issue, not to sound egotistical, I only want them for the color really.....the car is very light as it is.
I plan on using them for my top half of the car so the steel screws will keep the weight low and I can use lead in strategic places
Hot Bodies Pro 5
*Sponsors*
Old 12-28-2004, 01:32 PM   #9431
Trader Rating: 37 (100%+)
chris v.
what's up...
i believe kev and rob bought their screws from this site...
http://www.fastener-express.com/
i know a lot of around here also order parts from kraig at www.kthobbies.com
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 12-28-2004, 01:36 PM   #9432
Chrisgt2's Avatar
Thanks Anthony.....those screws are really cheap....
Hot Bodies Pro 5
*Sponsors*
Old 12-28-2004, 02:57 PM   #9433
CypressMidWest's Avatar
Yeah, you don't crash much, but when you do you make it count!!!!! LOL!!!
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 12-28-2004, 04:38 PM   #9434
Chrisgt2's Avatar
HAHA, cant help it Ian......speed kills
Hot Bodies Pro 5
*Sponsors*
Old 12-28-2004, 05:39 PM   #9435
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
Originally posted by Nexus
chris v.
what's up...
ive been using fastener express for years now. quality screws at a very good price
in fact fastener express screws are what have been used in all KGB Racing kits since the beginning
floodo1 is offline   Reply With Quote
