Old 12-25-2004, 11:53 PM   #9406
RCknight's Avatar
Default I'm reading all about....
diff gear problems and cvds issues. Is this just from hitting things with a oneway or spool?
RCknight is offline   Reply With Quote
Old 12-26-2004, 01:01 AM   #9407
dontfeelcold's Avatar
Trader Rating: 20 (100%+)
Originally posted by Pro4
What happened to the X-Ray???
nothing.
Did you have any problems when putting the top deck on your car?
dontfeelcold is offline   Reply With Quote
Old 12-26-2004, 01:53 AM   #9408
Tzotzo's Avatar
Could some please post the part nummber for 0 rear hubs?
Tzotzo is offline   Reply With Quote
Old 12-26-2004, 03:07 AM   #9409
Pro4's Avatar
Originally posted by dontfeelcold
nothing.
No. I had no problems at all...I'm assuming your talking about tweak?
Pro4 is offline   Reply With Quote
Old 12-26-2004, 07:28 AM   #9410
Yep. It seems that no matter which order I do the upper deck screws up in it tweaks the chassis in a really bad way and that includes the bearing carrier for the spurgear bearing, the centre support post and the steering rack posts.
Old 12-26-2004, 07:54 AM   #9411
tc3 racer sc's Avatar
Originally posted by 429racer
http://www.hpieurope.com/graphics/se...witzCarpet.pdf
just to let you know that race was done on rubber tires not foam but set up may still wrk
tc3 racer sc is offline   Reply With Quote
Old 12-26-2004, 08:25 AM   #9412
TOEBSTER2's Avatar
Originally posted by tc3 racer sc
a good start is the andy moore set up at clevland u can find most his set up on hpi europe i used and car was good
Thanks for the help.
Crookid Creations
TOEBSTER2 is offline   Reply With Quote
Old 12-26-2004, 09:09 AM   #9413
Trader Rating: 17 (100%+)
Well thanks for correcting me on that one! I accidently posted the wrong link and that is why I put the Cleveland setup down below. Didn't feel like editing just in case someone asks for a rubber tire setup on carpet like we have seen before!
429racer is offline   Reply With Quote
Old 12-26-2004, 02:57 PM   #9414
I was just browsing on the Rainbow 10 stock list and came across these two items:
4003440000001,HYBRID,5000YEN,GR-H001 PRO4 UPPER MOUNT BRACE ,
4003440000002,HYBRID,3000YEN,GR-H002 PRO4 SIDE WINDER BODY BRACE,
Does anybody know what they are and if so, are they worthwhile?
thanks
g4t2 is offline   Reply With Quote
Old 12-26-2004, 09:26 PM   #9415
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
thanks
im just guessing, but the first part is probably a graphite inner upper camber link brace plate.
the second part is probably a graphite plate to hold the top of the body posts.
but i could easily be wrong
floodo1 is offline   Reply With Quote
Old 12-26-2004, 11:11 PM   #9416
RCknight's Avatar
Default Thad.....
any idea when then the steering knuckles will be out? The ones that will have extra material.
Old 12-27-2004, 03:36 AM   #9417
Nipple's Avatar
The Camber link brace is similar to HPI's new release.
Nipple is offline   Reply With Quote
Old 12-27-2004, 04:16 AM   #9418
azenis's Avatar
Default spacer washers
Can anyone tell me, the washers used for wheel spacers, are they available seperately? I am missing them off one of my cars and dont really want to spend US$29 for a complete hex set...
Nige
X-Ray T4 '14 | 3Racing Sakura D3 CS | Durango DEX410v4 | HPI Blitz | Tamiya WR-02 VW Bus
azenis is offline   Reply With Quote
Old 12-27-2004, 06:36 AM   #9419
Default Heat Sink Motor Mount
Hi guys and girls
I am wanting to know how many of you are using after market heat sink motor mounts and what are your thoughts on them ?
We run 27t stock outdoors in rather warm conditions at the best of times...
Cheers
Michael
sweet'n'sour is offline   Reply With Quote
Old 12-27-2004, 11:42 AM   #9420
StewartFan20's Avatar
Default Foam Tire Question
I am making the leap from stock rubber to stock foam with my Pro4 and I have a couple of questions.
First, what size of tire do people start off with? Do I need to re-true the tires every so often?
Second, what is the minimum size of foam tire that can be used?
Third, Has anyone tried the Parma foams on the Pro4? I have read somewhere that he ID of the wheel is smaller that most wheels and I wanted to make sure that the wheel would fit? Also, will 28mm width fit?
Hope everyone had a Merry Christmas and have a Happy New Year!
Devil Dog Racing | HobbyTown USA (Kansas City,North) | Fastlane Raceway | Matrix Tires
Someday, I hope to be the man my dog thinks I am.
StewartFan20 is offline   Reply With Quote
SEO by vBSEO 3.5.0
