Like Tree6Likes
Old 12-25-2004, 07:32 AM   #9391
Trinity2's Avatar
Post
Thad or somebody else. Have you try Andy Moore`s Carpet world cup setup? What you think?
Jarrod: I use Hara`s Roar nats setup in carpet with little modifications ie original: one-way up front, 1.4mm front stabilizer and 2.5mm main chassis, and i like it
Our indoor clubtrack is highbite and technical.
Now i look a different setup and want to try that Andy`s setup before we started new indoor season next mounth.
Trinity2 is offline   Reply With Quote
Old 12-25-2004, 11:29 AM   #9392
TOEBSTER2's Avatar
Hey guys, I just picked up a new Pro4 and want to set it up for foam. Does anyone know a good starting point or know where to get Andy Moore's set up for the carpet nats.
Thanks for any help.
Crookid Creations
TOEBSTER2 is offline   Reply With Quote
Old 12-25-2004, 12:09 PM   #9393
tc3 racer sc's Avatar
a good start is the andy moore set up at clevland u can find most his set up on hpi europe i used and car was good
tc3 racer sc is offline   Reply With Quote
Old 12-25-2004, 03:16 PM   #9394
Trader Rating: 17 (100%+)
http://www.hpieurope.com/graphics/se...witzCarpet.pdf
429racer is offline   Reply With Quote
Old 12-25-2004, 03:17 PM   #9395
http://www.hpieurope.com/graphics/se..._Cleveland.pdf
Old 12-25-2004, 04:08 PM   #9396
azenis's Avatar
Any good setups for foams on bumpy/rough asphalt?
Merry Christmas all
Nige
X-Ray T4 '14 | 3Racing Sakura D3 CS | Durango DEX410v4 | HPI Blitz | Tamiya WR-02 VW Bus
azenis is offline   Reply With Quote
Old 12-25-2004, 05:47 PM   #9397
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
I have a bit of a problem with my Pro4. When I do the uper deck screws that hold in the steering rack posts and the bearing holder on the motor mount, the chassis doesn't tweak. When I do up the other 8 screws that hold the top deck to the diff cases the chassis gets a big bend in it. Any suggestions as to what to do?
dontfeelcold is offline   Reply With Quote
Old 12-25-2004, 09:46 PM   #9398
Trader Rating: 23 (100%+)
Hi All,
How can I tell the different between the 73501 Ring Gear version 1 and version 1.1 gears?
And can I use the aluminum backing plate that came with my kit for the 1.1 gears?
Thanks.
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 12-25-2004, 10:04 PM   #9399
The back of the gears is different, the 1.1 is beefed up. And you can use the alloy backing plate, its designed to go with the new gears on teh oneway.
Old 12-25-2004, 10:12 PM   #9400
Thanks.
I purchased a few replacement gears from my LHS but have no idea which version they are.
So can use the alloy backing plate with the old gears as well?
TEAMORCA.SHOP
Old 12-25-2004, 10:16 PM   #9401
RCGaryK's Avatar
Only with the PRP backplate. The HPI one is too thick for the old gear
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 12-25-2004, 10:39 PM   #9402
Send a message via Yahoo to Doug Gaut
Mark, the easiest way to tell is to look at the pinion gear. The large part of the gear on the older ones had nothing behind it compared to the larger part on the new ones that are molded with a solid back to them. Clear as mud I bet. The older version ring gear will have a slight bevel to them on the backside but the new ones are flat for a small area then have a deep bevel to them. The version 1.1 gear alum brace will not work on the older version gears but the PRP brace works so you can be covered that way if you have older gears as well.
Doug
Doug Gaut is offline   Reply With Quote
Old 12-25-2004, 11:02 PM   #9403
farls3589's Avatar
Send a message via AIM to farls3589
does anyone know how long it takes them to ship the updated gears and stuff.
farls3589 is offline   Reply With Quote
Old 12-25-2004, 11:21 PM   #9404
Doug
Looks like all the gears I got from my LHS are 1.1's. Just in case, I have picked up PRP units in case I need to run the old gears.
Thanks for the info.
TEAMORCA.SHOP
Old 12-25-2004, 11:48 PM   #9405
Pro4's Avatar
What happened to the X-Ray???
Pro4 is offline   Reply With Quote
