Like Tree6Likes
Old 12-21-2004, 03:13 PM   #9331
Default Drive Shafts
Ive been running the square titanium drive shafts for a bout a month and they are great .
I tried TC3 composite ones they are good and cheap but the pin still rips through quite easy and the aluminium one have been re-drilled that many times they look like a culinder because at 10 each they are tooooooooo exspensive to keep replacing.
Since I have run the square titanium ones no problems.
Steve B is offline   Reply With Quote
Old 12-21-2004, 03:47 PM   #9332
I have yet to run them. Won't be able to run till the beginning of the new year. The tracks around here are closed for the holidays.
Originally posted by 1fastdude
The Titanium axles the only a few people that responded to quickly. Yes I'm going to the Novak race, Johhny.
Downforce is offline   Reply With Quote
Old 12-21-2004, 03:58 PM   #9333
Pro4's Avatar
Default Re: standard shock oil
Originally posted by azenis
Can anyone tell me what weight the standard kit oil is that comes with a pro4?
50 wgt
Pro4 is offline   Reply With Quote
Old 12-21-2004, 11:40 PM   #9334
Trader Rating: 23 (100%+)
Looking for a spool assembly for this car. Any suggestions?
Thanks.
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 12-22-2004, 12:41 AM   #9335
kewdawg's Avatar
Originally posted by Frank McKinney
I've spent some time looking for the Trinity and IRS (it's not "Iris" as shown on the setup sheet) spring ratings but can't find them through Google yet.
You should be able to find the Trinity Purple springs (called: "congo" springs) here: http://www.shopatron.com/product/pro....0.56.723.0.0.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 12-22-2004, 01:27 AM   #9336
Pro4's Avatar
Thanks.
Speedtech sells spools for the Pro4 made by Titanium Racing.
Check out there website:
www.speedtechrc.com
Old 12-22-2004, 01:41 AM   #9337
Frank McKinney's Avatar
Don't use them unless you hit nothing and enjoy taking your front diff case apart to replace the Delrin outdrives....It's a nice design but susceptible to damage. The HPI one is ace.
Minimal signature to save screen space! Big sigs suX0r
Frank McKinney is offline   Reply With Quote
Old 12-22-2004, 01:43 AM   #9338
Hi Frank,
How is the wear on aluminum HPI Spool? Does anyone make a steel unit?
TEAMORCA.SHOP
Old 12-22-2004, 01:56 AM   #9339
I've only used it for one race meeting, about 5 runs and no noticeable wear so far. The thing is so light (it's hollow btw) that you won't want to try a steel spool I'm sure! The weight difference between the actual spool and an epoxied one-way is unbelievable. No one that I know of makes a steel version.
What the hell are you doing up so late anyway? Early start to the racing?
Old 12-22-2004, 02:01 AM   #9340
Pro4's Avatar
Yes i totally agree. I got one about a month ago and I have broken 3 outdrives. The things don't just break, they crumble.
Old 12-22-2004, 02:38 AM   #9341
pro4racer's Avatar
ok thanks j-p for your help will do that/
cheerrs
pro4racer is offline   Reply With Quote
Old 12-22-2004, 04:42 AM   #9342
ChadCapece's Avatar
Hi Frank,
I've used the aluminium spool, and it was really nice. I noticed very little wear (I used grease in the outdrives). The aluminium spool is sooooo light. It even out accelerated the one-way, due to the less rotating mass.
ChadCapece is offline   Reply With Quote
Old 12-22-2004, 05:07 AM   #9343
Skill's Avatar
Has anyone broken any gears with the spool? I'm thinking of getting one but I don't want to sacrifice reliability...
I wonder how long it'll be before HPI release a spool backing plate just like they did with the one-way?
Skill is offline   Reply With Quote
Old 12-22-2004, 05:59 AM   #9344
The way the gear attaches to the spool is the reverse of the way the gear attaches to the one-way, so the spool itself acts as the backing plate. You don't need to aluminium circular bit that comes with the 1.1 gears. The gear also attaches with 4 screws instead of 3.
I've run several packs at Don Valley (not sure if you've been there Skill) for the Mirage British Indoor Winter Series with the alum. spool and haven't broken any gears.
Old 12-22-2004, 06:56 AM   #9345
Rick Vessell's Avatar
I am coming to Novak. Dunno if I'll be able to make it up for practice before tho'. How's that new body work Eli?
Rick Vessell is offline   Reply With Quote
