Hpi Pro 4
#9286
" Also on the BMI chassis set should I do the upper deck mod or not? Any help would be appreciated."
Is your car tweaked? have you run it yet?
The tweak mod seems to be popular with people who race asphalt with the stock chassis. Since you bought a BMI, which should be 3mm, I'm assuming you race carpet. If that's the case, you probably want to hold off on that until you determine if the car is tweaking itself all the time. Even then, you should make sure it's the chassis.
#9287
tcdrvr I had tweak with the stock chassis never did the mod put on the BMI didn't have any tweak and I race out door asphalt
car handles greatas is no mods to the chassis
#9288
Originally posted by Skill
My car also seems to have a lot of play in the steering, it seems to be coming from the steering plate and the bearings, I wonder if there is any way to stop this??
#9291
Twister 2
Hey guys,
I'm thinking about getting a KO PROPO Hara Twister 2 ESC does anyone know how good this ESC is?
Thanks for your time guys.
#9292
Re: Twister 2
Originally posted by Vegetto
Hey guys,
Hey guys,
it's identical to the VSF-1
#9293
Re: Twister 2
Hey guys,
Hey guys,
i have to admit that the twister series is so mcuh better looking but you've got to be on crack to justify paying the xtra money.
get vfs-1 y0
#9294
I have a question saw a picture of someones car and they had the purple spacers (1or 2 mm) glued onto the front hub carrier .What is the purpose of this ? is to help adjust steering or throw.
#9295
evening all
what is the effect of altering the inboard toe (ie the angle of the inner lower front hinge pins)?
thanks
thanks
#9296
#9297
Originally posted by Carbon_Fibre3
evening all
evening all
#9298
Front bevel gears breaking - help!
I'm sure this has been covered before but I don't usually visit this thread so appeciate your help.
My son has been racing a new Pro 4 and each of the past two race days he has broken 2 sets of ring and pinion gears in the front (he's using the one-way). His hits have not been hard so this breakage seems severe. We've run out of gears and he'll go back to racing his Schumacher, which has been bulletproof.
Need a fix! He's shimmed it according to the instructions (kit came with the updated gears and supplement sheet). Another racer who runs his Pro 4 in mod and had a lot more hits hasn't broken any gears.
Thanks for any help.
#9300
he did and the gear lash is tighter. didn't fix the problem.
