Old 12-16-2004, 04:27 PM   #9256
JohnB's Avatar
R/C Tech Charter Subscriber
Originally posted by robk
Here's another question for Erik S., or maybe Thad:
i saw his car at Cleveland, and it did look smooth, effortless to drive and fast. I'm just trying to get at what the thought behind this is, so i can add it into my thinking when I'm at the track.
Rob, I'm not Erik or Thad, but when I ran this setup the last race my car had more corner speed than it's ever had, or more than any car I've driven for that matter. Even a guy watch at the track said he hasn't seen a car with that much corner speed. It just stays very flat and changes direction with no effort or hesitation.
Like I said before the roll center and shock up limiters was the biggest change from my previous setup. It makes a huge difference.
And yes, the car was SOOOOOOOO easy to drive. It should be illigal
take care
john
JohnB is offline   Reply With Quote
Old 12-16-2004, 04:29 PM   #9257
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
For the guys running Andy's set up from Cleveland. What number piston are you using in the front and rear?
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is online now   Reply With Quote
Old 12-16-2004, 05:58 PM   #9258
robk's Avatar
Trader Rating: 22 (100%+)
Thank you for the help, gentlemen!
Old 12-16-2004, 06:58 PM   #9259
ChadCapece's Avatar
Default Re: New to the Pro4
Originally posted by g4t2
Hi guys, after a while of running a TRF415, I've decided to try a pro 4. should be ordering it in the next couple of days, but have a few Q's I hope you can help me with. Firstly, I'm ordering the "1.1" kit, what does this mean? I'm also ordering a front diff set, but what other parts are worthwhile buying? I will be running it on carpet with rubber tyres. I'm on a bit of a budget and therefore am not too bothered about 'bling' purple buts, just stuff which actually make a difference to performance. thanks in advance to any help.
For carpet the best hopups are the 3mm chassis, BRP TC3 front bumper, ream out the gear box holes(see previous pages) for tweak free chassis. I can't think of anything esle that is reasonably priced.
ChadCapece is offline   Reply With Quote
Old 12-16-2004, 07:51 PM   #9260
Send a message via AIM to Proteus
Default Re: Re: New to the Pro4
What are you reaming out? I don't think anything is binding on my car....could you be a little more specific?
Proteus is offline   Reply With Quote
Old 12-16-2004, 07:55 PM   #9261
ChadCapece's Avatar
scroll back about 10 pages. there are diagrams of what to do. basically, you need to do is ream out the holes of the topdeck to the gearbox where the longer screws are. Then replace them with button head screws that don't make contact w/ the upper deck.
do a search for upper deck mod
Old 12-16-2004, 07:56 PM   #9262
ChadCapece's Avatar
here's my upper deck
Old 12-16-2004, 07:58 PM   #9263
ChadCapece's Avatar
delete
Old 12-16-2004, 10:34 PM   #9264
Carbon_Fibre3's Avatar
when these lads refer to teflon washers on up travel limiting..
are they referring to the same teflon washers as used in shock construction (not literally instead of puttin them in the shock .. but as well as )??
Carbon_Fibre3 is offline   Reply With Quote
Old 12-17-2004, 07:15 AM   #9265
I miss understood you post. I thought your were talking about reamming out the gearbox so that the bearings would not bind.
Old 12-17-2004, 09:04 AM   #9266
Send a message via Yahoo to Doug Gaut
Carbon_Fibre3,
Yes, they are the same washers as what guides the shock shafts. You can buy them in a package with the snap rings. Dont forget to install the o-ring on top of the washers as well to cushion the bottom of the shock if you clip a dot or something like that.
Doug Gaut is offline   Reply With Quote
Old 12-17-2004, 09:09 AM   #9267
Skill's Avatar
With the 3mm chassis and upper deck I see no need to ream out the holes on the upper deck to eliminate tweak. I've been running my PRP chassis kit for quite a while not and I've not had it tweak at all, the stock chassis and top deck however did tweak sometimes.
Skill is offline   Reply With Quote
Old 12-17-2004, 03:25 PM   #9268
JohnB's Avatar
#4 front w/ 70 wt. and #2 rear w/ 50 wt.. the rear feels a little soft, I might bump that up to 60 wt. next time out.
The setup up sheet says 3 hole piston in front but that's a .8mm I don't think I'd run 70 wt. oil with the 3 hole anyway. I tried 60wt. oil with the 3 hole and it was really stiff. Our track is a little to bumpy for it anyways, Cleveland was probably a lot smoother.
take care
john
Old 12-17-2004, 03:29 PM   #9269
JohnB's Avatar
Default Moore's Cleveland setup sheet.
Oh yea, the sheet doesn't show rear camber link location. I'd like to know where he was running his. I'm running #2 inner mount and #2 on the hub. I like the feel of the turn in with that combination.
Old 12-17-2004, 04:14 PM   #9270
Kevin K's Avatar
Thanks JohnB.....I know that the pistons that he showed on the set up sheet were drilled but I wanted to know what normal pistons worked. Thanks for the input.
SEO by vBSEO 3.5.0
