Like Tree5Likes
Old 12-13-2004, 12:48 AM   #9196
jayrodracer's Avatar
Default BMI CHASSIS & TEAM BOMBER CARBON FIBER SHAFT
I HAVE A BRAND NEW BMI 3MM CHASSIS AND TOP DECK PLUS A TEAM BOMBER CARBON FIBER SHAFT FOR THE PRO 4, WANT TO SELL CHEAP MAKE ME AN OFFER.....ALSO NOT INCLUDED IN PIC I HAVE THE BMI SHOCK TOWERS..........CHECK IT OUT!!!!
jayrodracer is offline   Reply With Quote
Old 12-13-2004, 12:48 AM   #9197
Has anyone tried the new thicker TC4 dogbones, do they fit
rudster is offline   Reply With Quote
Old 12-13-2004, 12:49 AM   #9198
HERES ANOTHER SHOT!!!!
Old 12-13-2004, 02:55 AM   #9199
Default track width
i was wondering if anyone has messed around with the track width of the car i.e. adding or removing shims on the axle between the wheel hex and the wheel..... does a wider car equal more stability? does a wider rear end relitive to the front yeild more overall steering? thanks........
Old 12-13-2004, 11:28 AM   #9200
Company Representative
Tres's Avatar
R/C Tech Charter Subscriber
Trader Rating: 14 (100%+)
Here is Dan Gomez's base set-up for carpet that a few asked for.....
Tre's
TnT-Fx Custom Graphics
www.tnt-fx.com
Tres is offline   Reply With Quote
Old 12-13-2004, 11:43 AM   #9201
JohnB's Avatar
Default Andy Moore setup
Those that are running Mod, with foam tires on carpet, give Andy Moore's Cleveland setup a try that was posted last week. I ran it last Saturday and the car AWESOME. The setup I was running was real close except the roll center settings. Those made a big difference as my car had TONS of corner speed.
The only problem I had was all the other cars in the track had to slow down for some corners and I kept rear ending them when I was lapping. Even a sweeper at the end of the straight that everyone else was slowing for I was taking at full tilt
take care
john
JohnB is offline   Reply With Quote
Old 12-13-2004, 01:39 PM   #9202
tc3stocker's Avatar
Send a message via AIM to tc3stocker Send a message via Yahoo to tc3stocker
anybody know of a good place to go and look at pictures of peoples modded Pro 4's? i would like to see some before I make mine.
tc3stocker is offline   Reply With Quote
Old 12-13-2004, 03:32 PM   #9203
robk's Avatar
Trader Rating: 22 (100%+)
"i was wondering if anyone has messed around with the track width of the car i.e. adding or removing shims on the axle between the wheel hex and the wheel..... does a wider car equal more stability? does a wider rear end relitive to the front yeild more overall steering? thanks........"
Wider rear: usually more steering, more reactive.
I tend to think making the car wider all around frees it up, but I can't confirm that for sure.
Old 12-13-2004, 06:54 PM   #9204
Send a message via AIM to Proteus
Just out of curiosity...why such a high roll center? Isn't 5mm just a bit too much?
Proteus is offline   Reply With Quote
Old 12-13-2004, 07:52 PM   #9205
JohnB's Avatar
Yes I have a little. I even stopped using the stock clamp on hex and just use a Associated hex. They are thicker and don't require any shims to make it wide. I does seem to free it up a little. Good for carpet.
take care
john
Old 12-13-2004, 10:42 PM   #9206
hey do u race at mimis track in gathersburg md.? just had to ask asfter seeing your location.
Old 12-13-2004, 11:02 PM   #9207
Yeah....have you raced there before?
Old 12-14-2004, 04:57 AM   #9208
coastaltony's Avatar
Default Re: BMI CHASSIS & TEAM BOMBER CARBON FIBER SHAFT
How much do you want for the Team Bomber Shaft?
Meucci pool cue collector
coastaltony is offline   Reply With Quote
Old 12-14-2004, 05:36 AM   #9209
5mm would be too high. The roll center is actually .5mm or 1/2 mm using the thick chassis. So if you have the stock chassis use 1mm to make op for the chassis thickness difference. I thought I wrote .5 on the sheet, maybe when tres retyped it he forgot the decimal point.
On the subject of wider, you'll notice my setup says Gas hubs. I use the gas hubs because they are wider than the Aluminum ones and allow more contact with the rim. I also use 1 thick shim athe the wheel to add even more width.
DJG24 is offline   Reply With Quote
Old 12-14-2004, 09:53 AM   #9210
kewdawg's Avatar
Default Ti screws
Originally posted by rc-zombies
if you guys decide to outfit your cars with Ti screws... I highly recommend getting the Jwerks screws. made of 64 grade Ti. super strong and lightweight.
rc-zombies, where can we get those Jwerks screws?
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
