Old 12-09-2004, 09:49 AM   #9151
tc3stocker's Avatar
Send a message via AIM to tc3stocker Send a message via Yahoo to tc3stocker
TC4 or Pro 4, the Pro 4 is starting to win me over, I have to have a shaft car to go with all the Losi's, just to keep it balanced, what do yall think
tc3stocker is offline   Reply With Quote
Old 12-09-2004, 09:59 AM   #9152
rc-zombies's Avatar
plastic vs carbon fiber?... broken parts or durability?
snail vs rabbit?
pro4 is your best choice....
Old 12-09-2004, 10:08 AM   #9153
rc-zombies's Avatar
Originally posted by Nexus
rczom...where did you pick that piece up?
got it from RcModel in HK...shipping was only a few dollars..
For $20.00 you get the complete 4 plates... front & rear...
http://www.powers-international.com/...xcel/eh001.htm
Old 12-09-2004, 11:37 AM   #9154
Erik Shauver's Avatar
Originally posted by Jeff Werner
Erik- What method is used on the Moore carpet setup to get the droop settings/measures listed? .2 is pretty small....lol
Thanks for the help.
Jeff
The simplest way would be to glue a 0.2mm washer (well 0.2mm total after gluing) to the zero of a droop guage/ block set. Alternatively, set the droop to zero and the give the screw a 1/8th turn or so, as even as possible per side.
Edit: However, I want to double check with Andy... as most carpet/ foam tire droop is measured over ride height... whereas rubber tire guys may do it from the guage only since the tires stay roughly the same throughout their life.
Erik Shauver is offline   Reply With Quote
Old 12-09-2004, 02:11 PM   #9155
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Erik....or anyone else for that matter what are the hole sizes in relation to the number on the Stock shock pistions.....IE....#1 is a 1.5mm hole.....I dont know if that is correct but I want to know if there is a way to get that information. Thanks
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 12-09-2004, 02:46 PM   #9156
JohnB's Avatar
R/C Tech Charter Subscriber
Here is what I have on file:
HPI pistons
#1 =1.3mm holes
#2=1.2mm
#3=1.1mm,
#4= 1.0mm,
#5=0.8mm(3 holes)
JohnB is offline   Reply With Quote
Old 12-09-2004, 02:48 PM   #9157
Kevin K's Avatar
thanks thats what I was looking for....
Old 12-09-2004, 03:02 PM   #9158
S15Racer's Avatar
Getting back into racing after about a 2 month hiatus and found a problem. I had taken my car out to the hs parking lot and ran round with my firend tamiya and went colided a few times, not the point. The point is that some how I managed to break the aluminum servo saver shaft again! The last time I broke it was the last time I raced! And it broke in the exact same place to, about 5-7 threads up from the bottom. I built and adjusted the servo saver to factory specs so what could be causing this? Is it just something that happens in really hard collisions or what?
one other quick question, whats the best way to disassemble the ball bearings on the pro 4 to clean them? I've just been prying on the shields but this bends them slightly and I cant figure out how to get those little snap rings out to allow the shields to come out untouched.
S15Racer is offline   Reply With Quote
Old 12-09-2004, 03:32 PM   #9159
ChadCapece's Avatar
I've never heard of that before. Did your car jump into that air and land on the bottom of the chassis?
ChadCapece is offline   Reply With Quote
Old 12-09-2004, 04:15 PM   #9160
robk's Avatar
Trader Rating: 22 (100%+)
Remove the sheilds with a sharp exacto knife. The end of the ring should look like this:
___ ___
___\ \___
You should be able to catch one of the pointy parts of the ring and pry it out. It may take a few tries.
Old 12-09-2004, 04:24 PM   #9161
[i]
one other quick question, whats the best way to disassemble the ball bearings on the pro 4 to clean them? I've just been prying on the shields but this bends them slightly and I cant figure out how to get those little snap rings out to allow the shields to come out untouched. [/B]
I dont know if this is what was asked but I dont know how to get the bearings out of the knuckles and hubs I feel im going to damage them if I force them out. How do people get them out?
Cheers,
Mossie
Mossie is offline   Reply With Quote
Old 12-09-2004, 04:32 PM   #9162
ChadCapece's Avatar
Large flat head screwdriver. It needs to be wide enough to span the gap between one inner race to the other.
Old 12-10-2004, 12:37 AM   #9163
Send a message via AIM to loosenut
Hey guys is version 1.1 the lastest? Also is there a standard kit w/o titanium screws and another kit w/ titanium screws? The reason I ask is because I was goign to order a pro4 from champs jap. but the dude emailed me with two prices one w/o ti screws and one with? Confused me..cause I thought HPI only had a kit that comes with everything?
G
Tekno SCT410//B44.x Avid Chasis//B5M//HW 3656 - 4700 kv// HW V10//MT-4
loosenut is offline   Reply With Quote
Old 12-10-2004, 12:38 AM   #9164
Also...are their any other things I should order along with the kit? Any optional upgrades that are necessary?
g
Old 12-10-2004, 12:45 AM   #9165
Pro4's Avatar
G
I didn't think any of the pro4 kits came with titanium screws
Pro4 is offline   Reply With Quote
