Old 12-05-2004, 11:28 AM   #9061
Trader Rating: 2 (75%+)
Default Re: Re: Re: Batt protection bar
I notice if the battery packs aren't build correctly they will be prone to come out of the car in accidents. Gluing cells of your packs together also helps.
BTW- Nice to finally see your pictures Trinity2!!
PUNISHER is offline   Reply With Quote
Old 12-05-2004, 12:20 PM   #9062
ChadCapece's Avatar
Default Re: Re: Re: Re: Batt protection bar
If the packs are unglued they are less likely to come out since they can comform to the battery slots. Now if they get out of alignment, yet they will come out.
ChadCapece is offline   Reply With Quote
Old 12-05-2004, 12:25 PM   #9063
Trinity2's Avatar
Yeah, i have a Trinity`s battery jig for that job and i usually use Team Orion silver bone batterybars whose are quite thick than normally (?), so they keep cells in strong line.
I never use glue between the cells, i don`t know why?
And - nice to finally get out my pics
Trinity2 is offline   Reply With Quote
Old 12-05-2004, 09:35 PM   #9064
Trader Rating: 16 (94%+)
has anyone had any problems with the servo saver on their pro4?
the other night I noticed my steering was binding up? the steering plate was hitting on the pivot block... anyway stripped the car the next morning and the area where the spring cap (75143b) screws onto the servo saver (75143a) had deformed by about 1mm, its hard to describe, I should of taken pics...
anyway, when i went to remove the cap the end of the servo saver literally snapped off... was it a faulty part or did I not assemble it correctly?
(the car hasnt taken any hard hits, and i've only run it in 540 and 27t sofar)
domo is offline   Reply With Quote
Old 12-05-2004, 09:43 PM   #9065
robk's Avatar
Trader Rating: 22 (100%+)
Your f/r block is most likely bent as well. They start rubbing the steering plate if they bend from a hit, etc.
robk is online now   Reply With Quote
Old 12-05-2004, 09:57 PM   #9066
nope checked that, it was straight, the only thing out of shape was the servo saver...
Old 12-05-2004, 10:22 PM   #9067
jayrodracer's Avatar
Default thad thanks man
have u ran anti dive in the front before if so what did it do for ya??
jayrodracer is offline   Reply With Quote
Old 12-05-2004, 10:35 PM   #9068
RCGaryK's Avatar
Has anyone played with changing the front C-hubs yet? just wondering what you've done and what you found.
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 12-06-2004, 12:40 AM   #9069
Vegetto's Avatar
Default Hara Twister 2 ESC?
Hey guys,
Does anyone know where I can get my hands on Hara's Twister 2 ESC?
Thanks guys
Vegetto is offline   Reply With Quote
Old 12-06-2004, 12:47 AM   #9070
Trinity2's Avatar
Post
I did that same though, because one of my friend told at he normally use 2* caster in carpet and 4* in asphalt track
Maybe i`ll try that next weekend clubrace.
Old 12-06-2004, 12:51 AM   #9071
Trinity2's Avatar
Post Re: Hara Twister 2 ESC?
Originally posted by Vegetto
Hey guys,
Thanks guys
Hey Vegetto
Rcmodel. hk sell them.... and price is 215$
Old 12-06-2004, 05:16 AM   #9072
pro4racer's Avatar
hi
can anyone give me some tips to get better rear end grip for a dusty wooden floor surface.
thanks
pro4racer is offline   Reply With Quote
Old 12-06-2004, 05:22 AM   #9073
Company Representative
Tres's Avatar
R/C Tech Charter Subscriber
Trader Rating: 14 (100%+)
what is your current set-up?
Where does it need more grip, entry, mid or exit?
Tre's
TnT-Fx Custom Graphics
www.tnt-fx.com
Tres is offline   Reply With Quote
Old 12-06-2004, 06:30 AM   #9074
pro4racer's Avatar
my current setup is stock but with the gold springs on bak and silver on front.
it needs more grip at the rear i think as when i come out of a corner it just spins right out and when on the power it spins of to the right.
thnks for ur reply
Old 12-06-2004, 06:41 AM   #9075
Eirik's Avatar
pro4racer,
Try to put the gold springs up front and the Silver in the back, this should make a huge difference!!
You can also go to bigger hole pistons as this will give you more traction from the suspension......
Eirik is offline   Reply With Quote
SEO by vBSEO 3.5.0
