Like Tree6Likes
Old 12-01-2004, 03:57 PM   #8986
I bought the stiff chasis and the top deck but I'm running Foams on carpet, and that is what the stiff chasis is for!
DJG24 is offline   Reply With Quote
Old 12-01-2004, 04:18 PM   #8987
How did they do this mod? Just with a drill? I run a 2.0mm on asphalt its been really hooked up recently.
Originally posted by Skill
Yes, that mod is supposed to stop the chassis holding a tweak.
Mossie is offline   Reply With Quote
Old 12-01-2004, 04:25 PM   #8988
rc-zombies's Avatar
yes...just a drill... start with a small bit and work it up from there until it's big enough for the screw head... by doing this you lessen you chances of delaminating the CF. then CA the hole.
Old 12-01-2004, 04:29 PM   #8989
thanks rc-zombies.
Cheers,
Mossie
Old 12-01-2004, 05:59 PM   #8990
ChadCapece's Avatar
Thumbs up
I just used my body reamer. It worked out perfectly.
ChadCapece is offline   Reply With Quote
Old 12-01-2004, 06:06 PM   #8991
gijoe64's Avatar
Trader Rating: 30 (100%+)
Cool
First I know about the DHI CUP setup for rubber tires on carpet but has anyone tried or is running rubber tires on carpet? I would like some setup information with rubber tires on carpet I am using CS27 tires but I think I have to much traction still and my car doesn't flow through the corners.
gijoe64 is offline   Reply With Quote
Old 12-01-2004, 06:08 PM   #8992
Kenneth Tan's Avatar
gijoe,
what springs are you using?
Kenneth Tan is offline   Reply With Quote
Old 12-01-2004, 06:25 PM   #8993
gijoe64's Avatar
Cool
White and red pro 4 springs
Old 12-01-2004, 06:28 PM   #8994
gijoe64's Avatar
I want to try 500wt oil Tamiya all 4 corners and red in the front and yellow in the rear.
Old 12-01-2004, 07:11 PM   #8995
on haras car what are the purple things that go under his screws on the top deck which go into his steering poles?
Cheers,
Mossie
Old 12-01-2004, 10:23 PM   #8996
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
Cheers,
Mossie
countesunk washers. they let you use a flathead screw. basically an aesthetic washer system. instead of an ugly buttonhead or caphead screw with a washer underneath it you get s cool looking integrated washer look, with contrast.
just sexy washers
washers are important when you do the upperdeck mod discussed above. provide more hold down power for the upper deck since you loose that whne you drill the upper deck.
floodo1 is offline   Reply With Quote
Old 12-02-2004, 12:03 AM   #8997
RCGaryK's Avatar
If you guys have changed out the bearings, whose are you using?
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 12-02-2004, 12:25 AM   #8998
Merciless's Avatar
Send a message via ICQ to Merciless
Speedtech's ceramic's are popular
Anyone able to post a KILLER carpet set-up ??
Foam tyres too please
Merciless is offline   Reply With Quote
Old 12-02-2004, 01:36 AM   #8999
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Squat GOLD Racing Bearings... the most friction free bearing I have ever used....just a tad bit better than the ceramics I had
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 12-02-2004, 02:02 AM   #9000
azenis's Avatar
did that not stuff the blade on the reamer?
Nige
X-Ray T4 '14 | 3Racing Sakura D3 CS | Durango DEX410v4 | HPI Blitz | Tamiya WR-02 VW Bus
azenis is offline   Reply With Quote
