Old 01-03-2004, 07:20 AM   #886
Barry White's Avatar
Cool New Kai pics,
Barry White is offline   Reply With Quote
Old 01-03-2004, 09:40 AM   #887
OutlawPro3's Avatar
Black-Knight,
where did you get the fan for the speedo? I'd like to get one of those for my Pro3 with Novak brushless.
Revo 3.3 Platinum Edition
OutlawPro3 is offline   Reply With Quote
Old 01-03-2004, 09:54 AM   #888
utieh's Avatar
Default Re: New Kai pics,
Originally posted by Barry White
can't get bored watching it!
One of my friend will order soon one kit. Since he doesn't want to spend money on 64dP pinion gears, he was interested to know the diameter of the stock spur gear or an approx. 48dp teeth number.
thanks
utieh is offline   Reply With Quote
Old 01-03-2004, 12:10 PM   #889
Kenshin's Avatar
Actually, I find it quite ugly. It's like a big mess of carbon fiber. I like the cleaner lines of the the stock kit. they've had better kits. Just my .02
Kenshin is offline   Reply With Quote
Old 01-03-2004, 02:58 PM   #890
pucho's Avatar
Send a message via AIM to pucho
Default Re: Re: New Kai pics,
thanks
Probably a 72-76 like on a TC3
pucho is offline   Reply With Quote
Old 01-03-2004, 03:08 PM   #891
utieh's Avatar
Default Re: Re: Re: New Kai pics,
thanks
Old 01-03-2004, 03:21 PM   #892
racer's Avatar
anyone have problems assembling the rear drive axle?
after following the instuctions and using the proper spacers i can not install the rear drive cup due to insufficient space.
the c-clip that holds the spur gear in place does not allow the cross pin to be fully inserted into the hole.
any help would be appreciated.
Thanks!
racer is offline   Reply With Quote
Old 01-03-2004, 04:19 PM   #893
black-knight's Avatar
R/C Tech Charter Subscriber
Thanks!
When i was building mine i did have to double check this step twice. The cross pin will fit, it's just a tighter as a result of shims. I used small pliers to fix the pin into place. Once together u will see that its all ok.
Black-Knight - None shall pass!
www.nbhc.com.au - www.facebook.com/smaracing
black-knight is offline   Reply With Quote
Old 01-04-2004, 08:06 PM   #894
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
anyone have more testimonials as to how this car performs on the track? car looks sweet but id also like to get feedback on how the thing drives/handles. would also like to hear if there are stuff that need to be improved (there are usually a couple in every car) and how "tough" the car is compared to other tourers out there. does it have any gear stripping problems like some other shaft cars out in the market? sorry for all the questions. i may get a new TC mid 2004 when i gather up enough funds for one and the pro4 is a likely candidate. but id like to get the whole picture about this ride - good and bad points. thanks!
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 01-04-2004, 11:49 PM   #895
Send a message via ICQ to lawndoggie Send a message via Yahoo to lawndoggie
I am also considering the pro4, I looked at the parts yesterday on the pro4, I noticed they're very light, which means (stiff) i.e good for running, no so good during hard impact.
I am new to RC, perhaps pro 4 is too pro for me? I need to have something that can withstand resonabe force impact....
suggestions?
lawndoggie is offline   Reply With Quote
Old 01-05-2004, 12:44 AM   #896
PRO4 is the best , tons of steering without sliding, smooth drivetrain, stiff chassis
If you run modified, bevel gear may be brake if you crash but it still driveable.
Kingcrab is offline   Reply With Quote
Old 01-05-2004, 01:52 AM   #897
I conducted a good session of testing with my Pro4 yesterday, along with a 6T hacker, so the car got a good work out.
Car steers great, if the rear does slide it's very progressive and controllable. I ran kit setup, except for 40w oil in front and 30w in the rear. I used Sorex 32 compound tires.
The 1 issue i encountered with the car was that the rear diff kept loosening it self, i'll be rebulding the diff tonight and using a little thread lock on the diff nut.
Old 01-05-2004, 09:30 AM   #898
rc-zombies's Avatar
Default Square option parts
Well it had to happen sooner or later...the first of many option parts are being released by Square RC.
>Front and rear graphite body post support
>Front aluminum knuckles
>Rear Aluminum hubs.
http://www.rc-square.com/parts22.htm
From Tobee Craft:
nothing listed yet..just part no.:
http://www3.kcn.ne.jp/~tobee/pro4.htm
Old 01-06-2004, 05:22 AM   #899
snoopy's Avatar
They really don't waste time making hop-ups these days........
snoopy is offline   Reply With Quote
Old 01-06-2004, 06:37 AM   #900
JusBox's Avatar
Well when you can make 40 dollars on a 10 cents piece of aluminum, why the heck not? I may just have to start my own line of hopups.
JusBox is offline   Reply With Quote
SEO by vBSEO 3.5.0
