Like Tree5Likes
Old 11-27-2004, 09:28 PM   #8926
hey guys
does anyone got their 28mm foam tires to work.
I am using 26mm right now and it works great. However I got a bunch of 28mm tires and I don't really want to waste them.
thanks
yeuc001 is offline   Reply With Quote
Old 11-28-2004, 07:55 AM   #8927
Trader Rating: 37 (100%+)
Originally posted by yeuc001
hey guys
thanks
28mm work no problem........pretty much everyone in the midwest with a pro4 on foam uses 28mm jace, trc, parma, tm racing, ect.
Looks like one Pro4 is in the A Main at the Indoor Championships this weekend in Stock Foam....
-- STOCK TOURING - A Main -- (Yellow)
Qual
1 23/5:05.37 STEPHEN SOBOTTKA
2 23/5:05.78 DAVE JOHNSON
3 23/5:06.96 RAY DARROCH
4 23/5:07.71 JEFF CUFFS
5 23/5:08.96 ANDREW ELLIS
6 23/5:09.14 MIKE PULFER --------HPI Pro4
7 23/5:09.36 CHUCK LONERAGAN
8 23/5:09.67 CHRIS MAZZOLA
9 23/5:09.93 AARON BOMIA
10 23/5:10.03 BOBBY FLACK
Andy Moore is in the B Main of Modified.
MOD TOURING - B Main -- (Green)
11 25/5:08.22 ANDY MOORE ---------- HPI Pro4
12 25/5:09.10 ANDREW GRAY
13 25/5:10.45 RYAN CAVALIERI
14 25/5:11.01 CHRIS DOSECK
15 25/5:11.11 WALTER HENDERSON
16 25/5:11.38 DAN MILES
17 25/5:11.96 JARED SCOTT
18 24/5:00.22 JON ORR
19 24/5:00.26 ERIC DESROSIERS
20 24/5:01.15 HUBERT HONIGL
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 11-28-2004, 09:22 AM   #8928
Jason's Avatar
Hey this is robk-
Right now Mike Pulfer is in the a stock, Eli Ezirow and Junior Norton are in the Masters tc a. Mike said they laid the front and rear shocks in the 3rd hole in. 2mm under the mounts front and rear. The track really has no really tight 180s and a lot of cornerspeed is needed. Mike P said the way to keep the rear tires from lifting is lay the rear shocks in. 80wt front and 50 wt rear with #3 pistons. Losi white and blacvk springs--30lb and 25lb respectively.
No swaybars!!
Jason is offline   Reply With Quote
Old 11-28-2004, 01:05 PM   #8929
sonicboom141's Avatar
Send a message via AIM to sonicboom141
what servos and motor are you guys choosing? im new and just wondering, it looks fun
sonicboom141 is offline   Reply With Quote
Old 11-28-2004, 05:38 PM   #8930
ChadCapece's Avatar
HiTech 625MG
Orion V2 Touring 12x1
ChadCapece is offline   Reply With Quote
Old 11-28-2004, 07:04 PM   #8931
Send a message via AIM to Proteus
Originally posted by Jason
Hey this is robk-
No swaybars!!
When you get a chance....can we get the full setup? Thanks
Good Job to all the Pro4 drivers
Jeff
Proteus is offline   Reply With Quote
Old 11-28-2004, 11:43 PM   #8932
hey guys
how do you get the 28mm to work.
When I install them, they are scribbing the rear shocks ends plus it will scribed the front shocks bottom it you try to make a really tight turn.
the shims doesn't give enough clearence at all.
I have tried but they just don't work.
by the way, thanks for the tight carpet setup.
wow there is a big difference between the front shock oil and rear shock oil. does this kind of difference help the acceleration or something ?
thanks guys
Old 11-29-2004, 02:12 AM   #8933
jayrodracer's Avatar
Default BMI PRO4 CHASSIS
RCMIKE
its brand new i will post a pic tommarow....im probably looking for like 60 bucks with the top deck as well....super thick for carpet...dialed!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
jayrodracer is offline   Reply With Quote
Old 11-29-2004, 04:29 AM   #8934
VerOn_Pat's Avatar
Default ??
Regarding the spacers in the front knuckles that are between the bearings. can i use spacers instead of the bushings?
VerOn_Pat is offline   Reply With Quote
Old 11-29-2004, 01:10 PM   #8935
tc3 racer sc's Avatar
hey guys
thanks guys
i had that problem too what i done is put the spaCER BCK ON THE CAR and had no problem wth the jaco rims but wth the old yellow trc rims i had the problem on front/ bck the new blk trc rims were just fine i ran them at the indoor champs this past week end
tc3 racer sc is offline   Reply With Quote
Old 11-29-2004, 01:12 PM   #8936
Qual
also to note eli escrow one the master race at the champs with a pro 4 it the first champs win wth the car i saw it my self very smooth
Old 11-29-2004, 01:43 PM   #8937
Hey this is robk-
No swaybars!!
i ran same weight oil i also ran o block in the front1.5 mil in nfront under f/r block 2degree block yellow springs shock 2 hole under camber link 5.5 shocks mounted inner on arm rear shocks mounted on tower 3 hole copper springs 3.5 under camber link under f/r block.5 mil under rear block 1.5 wth 2degree block could hve went to 3 block wth black sway bar and car ran real well andy moore har a similar set up same springs but ran a 3 degree block in the rear at the indoor champs i had fun at the champs
Old 11-29-2004, 01:45 PM   #8938
Default hpi pro 4 win master class at indoor champs
eli escrow one the master race at the indoorchamps could any one get his setup please i saw the race he was very smooth and fast so eli if u on here post ur set up thxs reggie
Old 11-29-2004, 01:47 PM   #8939
Default where that hpi rollo out chart what page
loking for hpi roll out page thxs for carpet
Old 11-29-2004, 09:01 PM   #8940
Default camber link length
has anyone messed around with the camber link lenghth, running it in the outer hole on the chassis mount?? what effect does it have?? did u try the front and rear or just one or what?? thanks
