Old 11-25-2004, 09:15 AM   #8896
X2
X2's Avatar
Default AE plastic CVD's
They will definatly work, Ive got one temporarily on my car now.
They are great for stock racing when being used in the back (wouldent recomend in the front unless you have a diff), as they are lighter then the alloy versions. Also, the pin that goes into the diff outdrive is a touch shorter, so when you have an accident, instead of the CVD pulling one of the little purple rings that go around the diff out drive off, the bone comes out and the ring stays on, no more lost rings and the pin is still long enough to not do any exess wear to the out drive
X2 is offline   Reply With Quote
Old 11-25-2004, 03:51 PM   #8897
jayrodracer's Avatar
Default speedtech spools
someone posted somehting about a steel spool...does anyone have a part no.? they are out of titanium ones apparently...
jayrodracer is offline   Reply With Quote
Old 11-25-2004, 04:24 PM   #8898
I have been running the TC3 composite outdrives on my PRO 4 with a 19 turn Spec motor and they work great and because the dogbone is slightly smaller you dont have to remove the diff ring to fit on a standard diff.
VerOn_Pat
If you find one wheel binding check the spacer between the bearings in the hub. If it wears slightly when the wheel is tightened up the bearings will bind. Just use the 0.2mm shims with the plastic spacer.
Steve B is offline   Reply With Quote
Old 11-25-2004, 05:03 PM   #8899
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
VerOn_Pat
yeah its def better to overshim than under
floodo1 is offline   Reply With Quote
Old 11-25-2004, 06:05 PM   #8900
rcmike's Avatar
Trader Rating: 38 (100%+)
Default Price of a pro4 kit
Anyone have a hobbyshop that will mailorder one at a good price? Thx Seems 290 is going rate
rcmike is offline   Reply With Quote
Old 11-25-2004, 06:20 PM   #8901
RCknight's Avatar
Default Skill...
where can I look at the PRP chassis. I was looking at the BMI one and it looks nice.
RCknight is offline   Reply With Quote
Old 11-25-2004, 06:32 PM   #8902
Send a message via Yahoo to Doug Gaut
Here ya go.
http://www.teamprpracing.com/
Doug Gaut is offline   Reply With Quote
Old 11-25-2004, 06:33 PM   #8903
RCknight's Avatar
Default Does the Pro 4 come with good...
bearings?
Old 11-25-2004, 06:38 PM   #8904
It has the best bearings that I have ever received in a kit to this day! I do not know if there are any better bearings on the market short of ceramic bearings.
Old 11-25-2004, 07:06 PM   #8905
i have a brand new bmi chassis....i would trade for a titanium or steel spool and or some parts
Old 11-25-2004, 11:00 PM   #8906
HPI Pro4 spool is now available from Towerhobbies at $14.79 each
Also, in reply to an earlier posting on the Delrin outdrives...I have been using a set with a spool (using Losi XXX-S friction pads) for the past 3-4 months and have never broken them. This is the set that was purchased at Apex hobbies in the U.K by a friend.
sanman-G35sc is offline   Reply With Quote
Old 11-25-2004, 11:25 PM   #8907
You used just the aftermarket white delrin hpi outdrives for a spool and it didnt break??....have u tried the stock composite ones??
Old 11-25-2004, 11:54 PM   #8908
Trader Rating: 36 (100%+)
Default Re: Price of a pro4 kit
http://www.kthobbies.com
279.99
kt has awesome prices and great service. they also stock a ton of pro4 spare and option parts.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 11-26-2004, 12:04 AM   #8909
Pro4's Avatar
www.speedtechrc.com
I think the price is $277.99.
very reliable service
Pro4 is offline   Reply With Quote
Old 11-26-2004, 12:09 AM   #8910
SpeedTech's Avatar
Default Re: Re: Price of a pro4 kit
Originally posted by Pro4
www.speedtechrc.com
Pro4,
Thank you for your recommandation We should have more Pro4 kits by Monday of next week, and we just received our shipment of more Tobee Craft hop-ups for the Pro4 as well.
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
