Like Tree6Likes
Old 11-20-2004, 05:59 AM   #8776
JohnB's Avatar
R/C Tech Charter Subscriber
Default Re: Tweak
Originally posted by JohnB
For those of you who use a tweak station regularly, have you notice you have to always add pressure to the right front and left rear?
JohnB is offline   Reply With Quote
Old 11-20-2004, 06:14 AM   #8777
Trader Rating: 17 (100%+)
Anyone know of where I can get the 0 degreee pivoting blocks?
429racer is offline   Reply With Quote
Old 11-20-2004, 06:19 AM   #8778
JohnB's Avatar
Most of the large mail order places carry HPI parts. Tower Hobbies, Stormer Hobbies, KT Hobbies are all places I've ordered from.
Old 11-20-2004, 06:27 AM   #8779
gacjr0's Avatar
Trader Rating: 15 (100%+)
re: breakage at our track
I don't think you can take much form the amount of breakage at our track. Maybe the teams should come to Idaho for durability testing . I know of a Tc3 that never breaks there too.
From what I've seen of the other cars hitting yours and Gus's (when you're lapping them) the Pro 4 has no durability problem.
gacjr0 is offline   Reply With Quote
Old 11-20-2004, 07:06 AM   #8780
StewartFan20's Avatar
Originally posted by Entropy
100 spur, someone mentioned.
I am using a 100 tooth spur. I read where someone is using 104 tooth spur.
I alos found that running the larger spur, and keeping the same gear ratio (larger pinion), the motor runs cooler.
Devil Dog Racing | HobbyTown USA (Kansas City,North) | Fastlane Raceway | Matrix Tires
Someday, I hope to be the man my dog thinks I am.
StewartFan20 is offline   Reply With Quote
Old 11-20-2004, 07:19 AM   #8781
Aurra Sing's Avatar
I'm using a 100t Kimbrough spur, but it's right at the edge of the bottom of my 2.5mm chassis.
Aurra Sing is offline   Reply With Quote
Old 11-20-2004, 08:54 AM   #8782
pro4racer's Avatar
so i can say its safe to use a 100t spur gear with out any modding
does hpi make a 100t derlin one for the pro4
thnks for all ur replys
pro4racer is offline   Reply With Quote
Old 11-20-2004, 09:17 AM   #8783
ernestf's Avatar
Send a message via ICQ to ernestf
pro4racer - yes, HPI makes the white spur gear, 100T 64 pitch. I have used it on mine for quite sometime.
ernestf is offline   Reply With Quote
Old 11-20-2004, 09:33 AM   #8784
pro4racer's Avatar
ernestf thnks for that
when u are using ur 100t spur are u using the standard stock chassis or did u have to mod it for the spur to fit in or is it a straight fit
thanks
Old 11-20-2004, 09:46 AM   #8785
I'm running a Kimbrough 100t spur with the 3mm chasis, but I do know it works with the stock 2.5mm chasis also.
DJG24 is offline   Reply With Quote
Old 11-20-2004, 09:47 AM   #8786
RCGaryK's Avatar
<---102 RW spur
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 11-20-2004, 09:48 AM   #8787
Brian McGreevy's Avatar
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
I'm running a 104 with the BMI 3 mm chassis. I had to bevel the edges of the spur opening in the chassis and topdeck to get it to fit. The biggest spur you can fit in the car will usually be the fastest, as it will let the motor run cooler (and thus more powerfully) with the same ratio.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 11-20-2004, 09:57 AM   #8788
Erik Shauver's Avatar
Default Spur Clearance
Here's a quick reference chart. I'd give yourself about 0.3mm to 0.5mm clearance unless you have measured the exact thickness of your chassis and are running on a very smooth surface. The chart uses exact chassis thicknesses whereas actual chassis thickness will vary slightly.
-E
Erik Shauver is offline   Reply With Quote
Old 11-20-2004, 12:22 PM   #8789
pro4racer's Avatar
hi erik i take it that the numbers in red are not to be used as these will exceed the thickness of the chassis
is that right.
thanks
Old 11-20-2004, 12:24 PM   #8790
Does 1 rear hub exist for the PRO4 (#)
What is the sizi for the rear hub bearings?
Hugo is offline   Reply With Quote
