Like Tree5Likes
Old 11-15-2004, 12:44 AM   #8626
RCknight's Avatar
Default I'm thinking of getting a Pro 4.
What are the pros and cons of this car. Is it durable? Is it better than a TC4?
RCknight is offline   Reply With Quote
Old 11-15-2004, 01:36 AM   #8627
Wannabe's Avatar
Hi guys,
just asking for future references that how long will you all think the Pro 4 is going to be famous and competitive?
Cheers ,
Ken
Wannabe is offline   Reply With Quote
Old 11-15-2004, 01:42 AM   #8628
Originally posted by Wannabe
Hi guys,
Cheers ,
Ken
Until there is another revolution in the design of the tc.
I'd say a few years yet.
Cheers,
Mossie
Mossie is offline   Reply With Quote
Old 11-15-2004, 01:43 AM   #8629
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Hi guys,
Cheers ,
Ken
4~Ever
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 11-15-2004, 06:05 AM   #8630
JohnB's Avatar
R/C Tech Charter Subscriber
Originally posted by DJG24
I wanted to try Thad Garners carpet setup on the HPI site but I can't figure out what the spring rate on the Trinity purple springs is and I also don't even know where to begin with the iris green rear springs. Last what are the .8 3 hole pistons and the 1.1 2 hole pistons are. Are the .8 3 holes the number 5's that come with the kit? Any help would be great.
Hello. I just keep running the Associated springs also. They are readily available in my area. I've been running copper (25 lbs) rear and purple front (30 lbs) for carpet. Sometimes purple rear also or yellow (35 lbs) front.
The pistons are like this
#1 - 1.3mm
#2 - 1.2mm
#3 - 1.1mm
#4 - 1.0mm
#5 - .8 mm (3 hole)
take care
john
JohnB is offline   Reply With Quote
Old 11-15-2004, 08:08 AM   #8631
Solara's Avatar
Trader Rating: 16 (100%+)
Hi guys,
Cheers ,
Ken
I didn't know PRO 4 is not famous in the 190mm elect scene at all....? Roar National title, some indoor carpet title, Japan touring title....Pro 4 does not win all of those but defintiely top 3 finsih.
Lately, where are the Losi and the TC3...? I only see Pro 4 and Xray at the top rank finsihes...
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 11-15-2004, 08:14 AM   #8632
Trader Rating: 37 (100%+)
Erik Shauver or if anyone knows for sure...
Can you explain the relationship of "Inboard Toe" settings and the regular "Front Toe"?
examples...
what if i run 1deg Inboard and 0deg Front toe?
or any other combo.
thanks.
i understand the higher the Inboard Toe setting the more aggressive the car handles but how does that work in relation to the actual Front Toe of the wheels?
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 11-15-2004, 09:17 AM   #8633
Erik Shauver's Avatar
Nexus: Like any suspension adjustment, almost everything effects everything else, so the adjustment of the inboard toe will have a very slight effect on the outboard toe setting. However, in this case, you set the two different adjustments independently. Use the inboard toe to adjust mid-corner steering response and use the outboard toe to adjust either straight line stability (toe in) or initial turn in (toe out). Also, any time you make a pivot block change, you will need to recheck your static outboard toe. Hopefully, this is what you were looking for.
-E
Erik Shauver is offline   Reply With Quote
Old 11-15-2004, 09:49 AM   #8634
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
are the delrin diff halves a little thicker? seems like i had to remove some shims when i switched them over last night...
one thing i like about this car... it has maybe the free-est driveline. with the bearings sprayed out, and gears shimmed- spins fo-ev-a!
anyone have the part # for the lite driveshaft? i am trying to get the lightest rotating mass i can.
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 11-15-2004, 10:58 AM   #8635
kentech's Avatar
Arrow Hara's JMRCA chassis
More pictures here; http://www2.diary.ne.jp/user/131693/
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 11-15-2004, 11:03 AM   #8636
rc-zombies's Avatar
the chassis doesn't look like it's woven graphite... new chassis?
Old 11-15-2004, 11:05 AM   #8637
I couldn't find it.....could someone post it on here
mtc3od is offline   Reply With Quote
Old 11-15-2004, 11:21 AM   #8638
ChadCapece's Avatar
Looked like new chassis and ball cups. They say HPI molded on in the side.
ChadCapece is offline   Reply With Quote
Old 11-15-2004, 11:22 AM   #8639
rc-zombies's Avatar
actually the ball cups are not new...they came out with them when the PRo3 was released. I did not like them...they developed alot of slop quickly.
Old 11-15-2004, 11:29 AM   #8640
The chassis looks like fiberglass..........
Might be to get even more flex, over the 2mm/2mm carbon chassis combo!
Erlend is offline   Reply With Quote
