Old 11-08-2004, 10:44 AM   #8476
rc-zombies's Avatar
Most likely a Ferrite magnet without the casing.
Old 11-08-2004, 11:41 AM   #8477
Nipple's Avatar
Well I have a friend who went to japan and came across a funny product by an unheard of brand, SEO Tuned.
This product looks just like an small piece of bandage (very expensive bandage ). And it is supposed to be wrapped around motor -ve wire and battery +ve wire. And after we did that, Magic happens.......when we drive the motor, the arcing reduced by half.
I don't know if it's the same thing on Hara's car or just something to cool the wires as what some website says.
Nipple is offline   Reply With Quote
Old 11-08-2004, 11:57 AM   #8478
Solara's Avatar
Trader Rating: 16 (100%+)
We have to have something to COOL the wire down now...? WOw....when are these options going to stop? LOL
Anyhow......can someone tell me where can we get those COLD AIR INTAKE scoop that everyone at the worlds are running? You know, that clear plastic thingy that wil ram the cold air toward the motor........Hara has it, Surikarn, Easton, even Masami has it....(I think it is a outdoor thing...)......all except belt car and TC4s.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 11-08-2004, 12:00 PM   #8479
rc-zombies's Avatar
Anyhow......can someone tell me where can we get those COLD AIR INTAKE scoop that everyone at the worlds are running? You know, that clear plastic thingy that wil ram the cold air toward the motor........Hara has it, even Masami has it....(I think it is a outdoor thing...)
ebay for $3.00
Old 11-08-2004, 12:04 PM   #8480
Solara's Avatar
ebay for $3.00
Cool..........that is probably the cheapest HARA or WORLDS drivers option parts that I can find (beside stickers)....LOL
Old 11-08-2004, 12:20 PM   #8481
Nipple's Avatar
It doesn't need to draw cool air to cool the motor.
(In simple term) The air scope (notice the shape) can increase convection (All the thermodynamics and heat transfer S*@T, I will not go into that) thus cooling the motor.......
Old 11-08-2004, 12:25 PM   #8482
Nipple's Avatar
I believe not many USA drivers will go buy a Jap RC Mag.
But in one of the issue, they talked about all the different options to cool the motor/batt/esc....
And they setup an experiment to test the diference.
Below is a link to a website where they translate the data and summary in English.
http://www.imminentrc.com/1.htm
Old 11-08-2004, 12:30 PM   #8483
Lost Aggresiva's Avatar
Originally posted by JohnB
Does anyone know what is on Hara's wires? Thad?
I've been wondering that too. I saw another picture of the car, and those whatchamacallits were over the tubes where the wires solder on.
Must be new kickey fast option...
Lost Aggresiva is offline   Reply With Quote
Old 11-08-2004, 02:25 PM   #8484
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
It looks like Blue shop towles wraped around the wires. Maybe they were soaked with water and then slid over where they solder on to the motor so they keep the leads from getting so hot they un-solder. Just a guess.....his car wasnt the only car that had them on them.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is online now   Reply With Quote
Old 11-08-2004, 02:37 PM   #8485
tunerjetta29's Avatar
Just curious, has anyone ever tried running a front 1-way and solid rear in an electric? I really like the way both my 1/8th and TC handle with the setup, but ive never heard of anyone running and electric TC with that setup??
tunerjetta29 is offline   Reply With Quote
Old 11-08-2004, 03:28 PM   #8486
Trader Rating: 2 (75%+)
Default 1/8th vs 1/10th
The reason why most people don't use a one-way with a solid rear diff set-up on their 1/10 cars is because it dosen't perform like a 1/8th scale nitro car. The 1/8th scale car has larger tires in the rear that makes the car very stable and easier to drive then 1/10th cars.
PUNISHER is offline   Reply With Quote
Old 11-08-2004, 05:24 PM   #8487
racer's Avatar
for those who have been running the HPI or Jet aluminum camber link supports for the Pro 4.
does anyone know if there is a difference in thickness between the two?
how does it fit compared to the stock counterpart?
has anyone bent their camber link yet? or how is it holding up?
any help/input would greatly be appreciated!
Thanks!
racer is offline   Reply With Quote
Old 11-08-2004, 05:54 PM   #8488
tc3 racer sc's Avatar
Default pro 4 on carpet first time
well i ran the pro 4 on carpet i tried the andy moore set up white springs/pink and setup he has, i had my front shock in the outer hole on the a-arm and notice i was scrubbing against my foam tire rim so i shaved some carbon off the front sterring knuckle and still was not getting full turn and wheels lock up, so i check my cvd pins it started to come out so i though that was the problem, i fix it and still had the problem what can be wrong and also i put the woven shaft in i kept hearing ticking noise i check my front diff nothing wrong , im lost and cant find the problem
tc3 racer sc is offline   Reply With Quote
Old 11-08-2004, 06:05 PM   #8489
Entropy's Avatar
I don't know about you guys, but soldering on the wires onto a V2 endbell takes more effort and more often than not, the wires heat up to a point where they become too hot to hold, I'm wondering whether this is just an aid so that you can hold the wires onto the motor long enough to stick without burning your fingers.
Entropy is offline   Reply With Quote
Old 11-08-2004, 06:09 PM   #8490
Kevin K's Avatar
That maybe but why wouldnt they just use pilers like most people do. And it is a real pain in the azz to solder a V2 motor in while its in the car. I think it has something to do with the motors getting so hot that they un-solder from the extreame heat....especially if they have to use brakes.
